查看: 8600|回復(fù): 7
51單片機(jī)正弦波發(fā)生器(1~100KHZ) 用DAC0832+定時器中斷實(shí)現(xiàn) 帶proteus仿真
ID:140725 發(fā)表于 2017-3-17 22:58 | 顯示全部樓層 |閱讀模式
下面給出一個設(shè)計實(shí)例,在實(shí)例中通過定時器中斷和DAC0832結(jié)合的方式來產(chǎn)生1~100KHZ的正弦波,幅度為0-Vcc/2。
首先按照下面的公式建立一個正弦波樣本表,樣表中將一個正弦波周期分成128個點(diǎn),每個點(diǎn)按7位量化(127對應(yīng)最高幅度Vcc/2):
f(x) = 64 + 63 * sin(2πx/180) x∈[0…127]
程序中使用16位定時器0產(chǎn)生取樣中斷,及定時器0的中斷時間即為正弦波的采樣周期。(T=1/(f*64))。本例中將正弦波分成64個采樣點(diǎn)輸出,及每隔兩個點(diǎn)要從采樣樣本中取出一個數(shù)DAC0832的輸入。
單片機(jī)源程序:
  1. #define SIN_GLOBAL 1
  2. #include "sin.h"
  3. //正弦波128個采樣點(diǎn)寄存數(shù)組
  4. code uchar Sin[128] = {
  5.                         64,67,70,73,76,79,82,85,88,91,94,96,99,102,104,106,
  6.                                                 109,111,113,115,117,118,120,121,123,124,125,126,126,
  7.                                                 127,127,127,127,127,127,127,126,126,125,124,123,121,
  8.                                                 120,118,117,115,113,111,109,106,104,102,99,96,94,91,
  9.                                                 88,85,82,79,76,73,70,67,64,60,57,54,51,48,45,42,39,
  10.                                                 36,33,31,28,25,23,21,18,16,14,12,10,9,7,6,4,3,2,1,
  11.                                                 1,0,0,0,0,0,0,0,1,1,2,3,4,6,7,9,10,12,14,16,18,21,23,
  12.                                                 25,28,31,33,36,39,42,45,48,51,54,57,60
  13.                       };
  14. /**********************************************************
  15. *函數(shù)名稱:Timer0_init(double timer0Delay)
  16. *函數(shù)功能:定時器0初始化
  17. *函數(shù)入口:timer0Delay,定時器定時時間,單位為毫秒
  18. *函數(shù)出口:無
  19. **********************************************************/
  20. void Timer0_init(double timer0Delay)
  21. {
  22.    double time;
  23.    double timeTemp;
  24.    timer0TH0=0x00;
  25.    timer0TL0=0x00;
  26.    timeTemp=0x00;
  27.    time=(double)(((double)12)/((F_CPU)/1000000));
  28.    if(((double)255)*time>timer0Delay)
  29.     {
  30.        timer0TH0=0x00;
  31.            timer0TL0=(uchar)(256ul-timer0Delay/time);
  32.     }
  33.    else
  34.     {
  35.           while(timeTemp>timer0Delay)
  36.           {
  37.            timeTemp+=time;
  38.            timer0TH0++;
  39.           }
  40.           timer0TH0--;
  41.           timeTemp=timeTemp-((double)timer0TH0)*time;
  42.           timer0TL0=(uchar)(256ul-timeTemp/time);
  43.     }
  44.    TMOD|=0x01;                               //GATE=0,TR=1運(yùn)行;C/T=1,counter,0,timer;01十六進(jìn)制
  45.    TH0=timer0TH0;
  46.    TL0=timer0TL0;
  47.    TR0=1;                                         //timer0 控制位,為1時啟動timer0
  48.    ET0=1;                                    //timer0 中斷使能
  49. }
  50. /**********************************************************
  51. *函數(shù)名稱:dac0832_init(void)
  52. *函數(shù)功能:D/A轉(zhuǎn)換芯片dac0832初始化
  53. *函數(shù)入口:無
  54. *函數(shù)出口:無
  55. **********************************************************/
  56. void dac0832_init(void)
  57. {
  58.   sinCodeCount=0;
  59.   DAC0832=Sin[0];
  60. }
  61. /**********************************************************
  62. *函數(shù)名稱:writeDAC0832(uchar dacDate)
  63. *函數(shù)功能:向D/A轉(zhuǎn)換芯片dac0832數(shù)據(jù)口寫數(shù)據(jù)
  64. *函數(shù)入口:dacDate
  65. *函數(shù)出口:無
  66. **********************************************************/
  67. void writeDAC0832(uchar dacDate)
  68. {
  69.   DAC0832=dacDate;
  70. }
下載:
正弦波發(fā)生器.rar (20.14 KB, 下載次數(shù): 182)
ID:217225 發(fā)表于 2017-7-4 22:28 | 顯示全部樓層
程序有問題  求指導(dǎo)
ID:396689 發(fā)表于 2018-10-24 21:53 來自觸屏版 | 顯示全部樓層
程序報錯啊
ID:407843 發(fā)表于 2018-10-26 21:24 | 顯示全部樓層
測式AD好東西
ID:592753 發(fā)表于 2019-8-8 13:33 | 顯示全部樓層
沒有main函數(shù)
ID:281113 發(fā)表于 2019-10-20 09:09 | 顯示全部樓層
看一看
ID:774573 發(fā)表于 2024-1-18 15:54 | 顯示全部樓層
這個問題解決了嗎
ID:1126601 發(fā)表于 2024-7-25 08:52 | 顯示全部樓層
正弦波的頻率怎么調(diào)的?
