查看: 2753|回復(fù): 0
求各路大神看看,stm32超聲波測距,main里面一調(diào)用senor_using串口調(diào)試助手什么也沒有
ID:167020 發(fā)表于 2017-3-25 18:51 | 只看該作者 回帖獎勵 |正序瀏覽 |閱讀模式
#include "stm32f10x.h"
#include <stdio.h>
int overcount=0;
void RCC_Configuration(void);
void NVIC_Config(void);
void USART1_Configuration(void);
void UART_PutChar(USART_TypeDef* USARTx, char Data);
void UART_PutStr (USART_TypeDef* USARTx, char *str);
float Senor_Using(void);
void CH_SR04_Init(void);
void delay1ms(unsigned int x)
        unsigned char a,b;
        for(a=x;a>0;a--)
                for(b=100;b>0;b--);
void delay_us(u32 Number)
    u32 i=0;
     while(Number--){
      i=12; while(i--);
int main(void)
        RCC_Configuration();
        USART1_Configuration();
        NVIC_Config();
        CH_SR04_Init();
        UART_PutChar(USART1,Senor_Using());     //一調(diào)用senor_using串口調(diào)試助手就什么也輸不出來,不調(diào)用的話至少會輸出hello!
        while(i)
                        UART_PutStr ( USART1, "hello!");
                        delay1ms(1000);
        //----------ê1óÃía2¿RC¾§Õñ-----------
        RCC_DeInit();                        //3õê¼»ˉÎaè±ê¡Öμ
        RCC_HSEConfig(RCC_HSE_ON);        //ê1Äüía2¿μĸßËùê±Öó
        while(RCC_GetFlagStatus(RCC_FLAG_HSERDY) == RESET);        //μè′yía2¿¸ßËùê±Öóê1Äü¾íD÷
        FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);        //Enable Prefetch Buffer
        FLASH_SetLatency(FLASH_Latency_2);                //Flash 2 wait state
        RCC_HCLKConfig(RCC_SYSCLK_Div1);                //HCLK = SYSCLK
        RCC_PCLK2Config(RCC_HCLK_Div1);                        //PCLK2 =  HCLK
        RCC_PCLK1Config(RCC_HCLK_Div2);                        //PCLK1 = HCLK/2
        RCC_PLLConfig(RCC_PLLSource_HSE_Div1,RCC_PLLMul_9);        //PLLCLK = 8MHZ * 9 =72MHZ
        RCC_PLLCmd(ENABLE);                        //Enable PLLCLK
        while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
  RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);        //Select PLL as system clock
        while(RCC_GetSYSCLKSource()!=0x08);                //Wait till PLL is used as system clock source
        //---------′ò¿aÏàó|íaéèê±Öó--------------------
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO, ENABLE);        //ê1ÄüAPB2íaéèμÄGPIOAμÄê±Öó
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1,ENABLE);
        RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOB, ENABLE);
                RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
        oˉêyÃû£oUSART1_Configuration
        êä  èë:
        êä  3ö:
        1|ÄüËμÃ÷£o
        3õê¼»ˉ′®¿úó2¼té豸£¬ÆôóÃÖD¶Ï
        ÅäÖÃ2½Öè£o
        (1)′ò¿aGPIOoíUSART1μÄê±Öó
        (2)éèÖÃUSART1ὸö1ü½ÅGPIOÄ£ê½
        (3)ÅäÖÃUSART1êy¾Y¸ñ꽡¢2¨ìØÂêμè2Îêy
        (4)ê1ÄüUSART1½óêÕÖD¶Ï1|Äü
        (5)×îoóê1ÄüUSART11|Äü
        USART_InitTypeDef USART_InitStructure;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
        /* μú42½£oÅäÖÃUSART12Îêy
            - BaudRate = 115200 baud
            - Word Length = 8 Bits
            - One Stop Bit
            - No parity
            - Hardware flow control disabled (RTS and CTS signals)
            - Receive and transmit enabled
    USART_InitStructure.USART_BaudRate = 9600;
    USART_InitStructure.USART_WordLength = USART_WordLength_8b;
    USART_InitStructure.USART_StopBits = USART_StopBits_1;
    USART_InitStructure.USART_Parity = USART_Parity_No;
    USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
    USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
    USART_Init(USART1,&USART_InitStructure);
    USART_Cmd(USART1,ENABLE);
                        NVIC_InitTypeDef NVIC_InitStructer;
                        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
                        NVIC_InitStructer.NVIC_IRQChannelPreemptionPriority=0;
                        NVIC_InitStructer.NVIC_IRQChannelSubPriority=0;
                        NVIC_InitStructer.NVIC_IRQChannel=TIM2_IRQn;
                        NVIC_InitStructer.NVIC_IRQChannelCmd=ENABLE;
                        NVIC_Init(&NVIC_InitStructer);
                GPIO_InitTypeDef GPIO_InitStructer;
                TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStructer;
                /*TRIG????*/
                GPIO_InitStructer.GPIO_Speed=GPIO_Speed_50MHz;
                GPIO_InitStructer.GPIO_Mode=GPIO_Mode_Out_PP;
                GPIO_InitStructer.GPIO_Pin=GPIO_Pin_8;
                GPIO_Init(GPIOB, &GPIO_InitStructer);
                /*ECOH????*/
                GPIO_InitStructer.GPIO_Mode=GPIO_Mode_IN_FLOATING;
                GPIO_InitStructer.GPIO_Pin=GPIO_Pin_9;
                GPIO_Init(GPIOB, & GPIO_InitStructer);
                TIM_DeInit(TIM2);
                TIM_TimeBaseInitStructer.TIM_Period=999;
                TIM_TimeBaseInitStructer.TIM_Prescaler=71; //????72
                TIM_TimeBaseInitStructer.TIM_ClockDivision=TIM_CKD_DIV1;//???
                TIM_TimeBaseInitStructer.TIM_CounterMode=TIM_CounterMode_Up;
                TIM_TimeBaseInit(TIM2,&TIM_TimeBaseInitStructer);
                TIM_ITConfig(TIM2,TIM_IT_Update,ENABLE);
                NVIC_Config();
                TIM_Cmd(TIM2,DISABLE);
                                float length=0,sum=0;
                                u16 tim;
                                int i=0;
                                while(i!=5)
                                GPIO_SetBits(GPIOB, GPIO_Pin_8);
                                delay_us(20);
                                GPIO_ResetBits(GPIOB, GPIO_Pin_8);;
                                while(GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_9)==RESET);
                                TIM_Cmd(TIM2,ENABLE);
                                i+=1;
                                while(GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_9)==SET);
                                tim=TIM_GetCounter(TIM2);
                                length=(tim+overcount*1000)/58.0;
                                sum=length+sum;
                                TIM2->CNT=0;
                                overcount=0;
                                delay1ms(100);
                                length=sum/5;
                                return length;
void TIM2_IRQHandler(void)
                        if(TIM_GetITStatus(TIM2,TIM_IT_Update)!=RESET)
                        TIM_ClearITPendingBit(TIM2,TIM_IT_Update);
                        overcount++;
    USART_SendData(USARTx, Data);
    while(USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET);
    while (0 != *str)
        UART_PutChar(USARTx, *str);
        str++;
