音頻解碼模塊看過來,福利福利,VS1003&1053音頻解碼模塊
2017-3-30 16:49 上傳
VS1003中文數(shù)據(jù)手冊.pdf:
2017-3-30 16:51 上傳
2017-3-30 16:51 上傳
mp3文件的數(shù)據(jù)格式_中文:
2017-3-30 16:51 上傳
單片機(jī)源程序:
- * MP3模塊測試程序
- * 用途:MP3模塊測試程序
- * vs1003 的硬件測試程序,主控芯片為STC12LE5A60S2
- * 其他的微處理器(帶SPI接口的)只需稍加修改即可適用
- * 對于不帶硬SPI接口的微處理器可以用IO進(jìn)行SPI的時(shí)序模擬
- * 作者 日期 備注
- * Huafeng Lin 20010/09/10 新增
- * Huafeng Lin 20010/09/10 修改
- #include "vs1003.h"
- #include "MusicDataMP3.c"
- #include <intrins.h>
- #define uchar unsigned char
- #define uint unsigned int
- #define ulong unsigned long
- #define bool bit
- #define true 1
- #define flase 0
- //針對SD卡讀寫板調(diào)整引腳
- #define uint8 unsigned char
- sbit MP3_XRESET = P3^2;
- #define Mp3PutInReset() { MP3_XRESET = 0; }
- #define Mp3ReleaseFromReset() { MP3_XRESET =1; }
- sbit MP3_XCS = P3^3;
- #define Mp3SelectControl() { MP3_XCS = 0; }
- #define Mp3DeselectControl() { MP3_XCS = 1; }
- sbit MP3_XDCS = P3^4;
- #define Mp3SelectData() { MP3_XDCS = 0; }
- #define Mp3DeselectData() { MP3_XDCS = 1; }
- sbit MP3_DREQ = P3^5;
- sbit c_SPI_SI = P1^5;
- sbit c_SPI_SO = P1^6;
- sbit c_SPI_CLK = P1^7;
- #define Macro_Set_SI_High() c_SPI_SI = 1
- #define Macro_Set_SI_Low() c_SPI_SI = 0
- #define Macro_Set_CLK_High() c_SPI_CLK = 1
- #define Macro_Set_CLK_Low() c_SPI_CLK = 0
- void LCD_write_english_string(unsigned char X,unsigned char Y,char *s);
- //#define SPIWait() { while((S0SPSR & 0x80) == 0); }//等待SPI將數(shù)據(jù)發(fā)送完畢
- //#define SPI_RESULT_BYTE S0SPDR
- //extern long volatile timeval; //用于延時(shí)的全局變量
- //1ms Delayfunction
- //void Delay(uchar ucDelayCount)
- void wait(uchar ucDelayCount)
- uchar ucTempCount;
- uchar uci;
- for(ucTempCount=0; ucTempCount<ucDelayCount; ucTempCount++)
- // uci = 200; //Err
- // uci = 250; //OK
- uci = 230;
- while(uci--)
- _nop_();
- //#define wait(x) Delay(x)
- /* 函數(shù)名稱 : MSPI_Init */
- /* 函數(shù)功能 : 初始化SPI接口,設(shè)置為主機(jī)。 */
- /* 參數(shù) : 無 */
- /* 返回值 : 無 */
- void MSPI_Init(void)
- PINSEL0 = (PINSEL0 & 0xFFFF00FF) | 0x00005500; //選擇 SPI
- S0SPCCR = 0x08; // SPI 時(shí)鐘設(shè)置
- S0SPCR = (0 << 3) | // CPHA = 0,
- (0 << 4) | // CPOL = 0,
- (1 << 5) | // MSTR = 1,
- (0 << 6) | // LSBF = 0,
- (0 << 7); // SPIE = 0,
- c_SPI_SO = 1;
- MP3_DREQ = 1;
- /* 函數(shù)名稱 : InitPortVS1003 */
- /* 函數(shù)功能 : MCU與vs1003接口的初始化 */
- /* 參數(shù) : 無 */
- /* 返回值 : 無 */
- void InitPortVS1003(void)
- MSPI_Init();//SPI口的初始化
- // IODIR &= 0xfffeffff; //其他接口線的設(shè)置,其中dreq 為輸入口
- // IODIR |= MP3_XRESET | MP3_XCS | MP3_XDCS;//xRESET,xCS,xDS均為輸出口
- // IOSET |= MP3_XRESET | MP3_XCS | MP3_XDCS;//xRESET,xCS,xDS默認(rèn)輸出高電平
- MP3_DREQ = 1; //置為輸入
- MP3_XRESET = 1;
- MP3_XCS = 1;
- MP3_XDCS = 1;
- //uint8 SD_SPI_ReadByte(void);
- //void SD_SPI_WriteByte(uint8 ucSendData);
- //#define SPI_RecByte() SD_SPI_ReadByte()
- //#define SPIPutChar(x) SD_SPI_WriteByte(x)
- #if 1
- /* 函數(shù)名稱 : SPIPutChar */
- /* 函數(shù)功能 : 通過SPI發(fā)送一個(gè)字節(jié)的數(shù)據(jù) */
- /* 參數(shù) : 待發(fā)送的字節(jié)數(shù)據(jù) */
- /* 返回值 : 無 */
- void SPIPutChar(unsigned char ucSendData)
- // S0SPDR = c;
- // while((S0SPSR & 0x80) == 0); //等待SPI將數(shù)據(jù)發(fā)送完畢
- uchar ucCount;
- uchar ucMaskCode;
- ucMaskCode = 0x80;
- for(ucCount=0; ucCount<8; ucCount++)
- Macro_Set_CLK_Low();
- if(ucMaskCode & ucSendData)
- Macro_Set_SI_High();
- else
- Macro_Set_SI_Low();
- Macro_Set_CLK_High();
- ucMaskCode >>= 1;
- ** 函數(shù)名稱: INT8U SPI_RecByte() Name: INT8U SPI_RecByte()
- ** 功能描述: 從SPI接口接收一個(gè)字節(jié) Function: receive a byte from SPI interface
- ** 輸 入: 無 Input: NULL
- ** 輸 出: 收到的字節(jié) Output: the byte that be received
- static uchar SPI_RecByte(void)
- uchar ucReadData;
- uchar ucCount;
- ucReadData = 0;
- ucReadData <<= 1;
- //降低時(shí)鐘頻率
- if(c_SPI_SO)
- ucReadData |= 0x01;
- return(ucReadData);
- #endif
- /* 函數(shù)名稱 : Mp3WriteRegister */
- /* 函數(shù)功能 : 寫vs1003寄存器 */
- /* 參數(shù) : 寄存器地址,待寫數(shù)據(jù)的高8位,待寫數(shù)據(jù)的低8位 */
- /* 返回值 : 無 */
- void Mp3WriteRegister(unsigned char addressbyte, unsigned char highbyte, unsigned char lowbyte)
- Mp3DeselectData();
- Mp3SelectControl();//XCS = 0
- SPIPutChar(VS_WRITE_COMMAND); //發(fā)送寫寄存器命令
- SPIPutChar(addressbyte); //發(fā)送寄存器的地址
- SPIPutChar(highbyte); //發(fā)送待寫數(shù)據(jù)的高8位
- SPIPutChar(lowbyte); //發(fā)送待寫數(shù)據(jù)的低8位
- Mp3DeselectControl();
- /* 函數(shù)名稱 : Mp3ReadRegister */
- /* 參數(shù) : 寄存器地址 */
- /* 返回值 : vs1003的16位寄存器的值 */
- unsigned int Mp3ReadRegister(unsigned char addressbyte)
- unsigned int resultvalue = 0;
- uchar ucReadValue;
- SPIPutChar(VS_READ_COMMAND); //發(fā)送讀寄存器命令
- SPIPutChar((addressbyte)); //發(fā)送寄存器的地址
- // SPIPutChar(0xff); //發(fā)送讀時(shí)鐘
- // resultvalue = (SPI_RESULT_BYTE) << 8;//讀取高8位數(shù)據(jù)
- ucReadValue = SPI_RecByte();
- resultvalue = ucReadValue<<8;
- // resultvalue |= (SPI_RESULT_BYTE); //讀取低8位數(shù)據(jù)
- resultvalue |= ucReadValue;
- return resultvalue; //返回16位寄存器的值
- /* 函數(shù)名稱 : Mp3SoftReset */
- /* 函數(shù)功能 : vs1003軟件復(fù)位 */
- /* 參數(shù) : 無 */
- /* 返回值 : 無 */
- void Mp3SoftReset(void)
- Mp3WriteRegister (SPI_MODE, 0x08, 0x04); //軟件復(fù)位
- wait(1); //延時(shí)1ms
- while (MP3_DREQ == 0); //等待軟件復(fù)位結(jié)束
- Mp3WriteRegister(SPI_CLOCKF, 0x98, 0x00);//設(shè)置vs1003的時(shí)鐘,3倍頻
- Mp3WriteRegister (SPI_AUDATA, 0xBB, 0x81); //采樣率48k,立體聲
- Mp3WriteRegister(SPI_BASS, 0x00, 0x55);//設(shè)置重音
- Mp3SetVolume(10,10);//設(shè)置音量
- //向vs1003發(fā)送4個(gè)字節(jié)無效數(shù)據(jù),用以啟動(dòng)SPI發(fā)送
- Mp3SelectData();
- SPIPutChar(0);
- SPIPutChar(0);
- SPIPutChar(0);
- SPIPutChar(0);
- /* 函數(shù)名稱 : Mp3Reset */
- /* 函數(shù)功能 : vs1003硬件復(fù)位 */
- /* 參數(shù) : 無 */
- /* 返回值 : 無 */
- void Mp3Reset(void)
- Mp3PutInReset();//xReset = 0 復(fù)位vs1003
- wait(200);//延時(shí)100ms
- SPIPutChar(0xff);//發(fā)送一個(gè)字節(jié)的無效數(shù)據(jù),啟動(dòng)SPI傳輸
- Mp3DeselectControl(); //xCS = 1
- Mp3DeselectData(); //xDCS = 1
- Mp3ReleaseFromReset(); //xRESET = 1
- wait(200); //延時(shí)100ms
- while (MP3_DREQ == 0);//等待DREQ為高
- Mp3SetVolume(50,50);
- Mp3SoftReset();//vs1003軟復(fù)位
- bool CheckVS1003B_DRQ(void)
- bool bResult;
- bResult =MP3_DREQ;
- return(bResult);
- /* 函數(shù)名稱 : VsSineTest */
- /* 函數(shù)功能 : vs1003正弦測試,將該函數(shù)放在while循環(huán)中, */
- /* 如果能持續(xù)聽到一高一低的聲音,證明測試通過 */
- /* 參數(shù) : 無 */
- /* 返回值 : 無 */
- void VsSineTest(void)
- Mp3PutInReset(); //xReset = 0 復(fù)位vs1003
- wait(200);
- Mp3WriteRegister(SPI_MODE,0x08,0x20);//進(jìn)入vs1003的測試模式
- while (MP3_DREQ == 0); //等待DREQ為高
- Mp3SelectData(); //xDCS = 1,選擇vs1003的數(shù)據(jù)接口
- //向vs1003發(fā)送正弦測試命令:0x53 0xef 0x6e n 0x00 0x00 0x00 0x00
- //其中n = 0x24, 設(shè)定vs1003所產(chǎn)生的正弦波的頻率值,具體計(jì)算方法見vs1003的datasheet
- SPIPutChar(0x53);
- SPIPutChar(0xef);
- SPIPutChar(0x6e);
- SPIPutChar(0x24);
- SPIPutChar(0x00);
- SPIPutChar(0x00);
- SPIPutChar(0x00);
- SPIPutChar(0x00);
- // wait(500);
- wait(250);
- wait(250);
- Mp3DeselectData();//程序執(zhí)行到這里后應(yīng)該能從耳機(jī)聽到一個(gè)單一頻率的聲音
- //退出正弦測試
- Mp3SelectData();
- SPIPutChar(0x45);
- SPIPutChar(0x78);
- SPIPutChar(0x69);
- SPIPutChar(0x74);
- SPIPutChar(0x00);
- SPIPutChar(0x00);
- SPIPutChar(0x00);
- SPIPutChar(0x00);
- // wait(500);
- wait(250);
- wait(250);
- //再次進(jìn)入正弦測試并設(shè)置n值為0x44,即將正弦波的頻率設(shè)置為另外的值
- Mp3SelectData();
- SPIPutChar(0x53);
- SPIPutChar(0xef);
- SPIPutChar(0x6e);
- SPIPutChar(0x44);
- SPIPutChar(0x00);
- SPIPutChar(0x00);
- SPIPutChar(0x00);
- SPIPutChar(0x00);
- // wait(500);
- wait(250);
- wait(250);
- //退出正弦測試
- Mp3SelectData();
- SPIPutChar(0x45);
- SPIPutChar(0x78);
- SPIPutChar(0x69);
- SPIPutChar(0x74);
- SPIPutChar(0x00);
- SPIPutChar(0x00);
- SPIPutChar(0x00);
- SPIPutChar(0x00);
- // wait(500);
- wait(250);
- wait(250);
- void test_1003_PlayMP3File();
- void TestVS1003B(void)
- Mp3Reset();
- VsSineTest();
- Mp3SoftReset();
- test_1003_PlayMP3File();
- //寫寄存器,參數(shù),地址和數(shù)據(jù)
- void VS1003B_WriteCMD(unsigned char addr, unsigned int dat)
- VS1003B_XDCS_H();
- VS1003B_XCS_L();
- VS1003B_WriteByte(0x02);
- //delay_Nus(20);
- VS1003B_WriteByte(addr);
- VS1003B_WriteByte(dat>>8);
- VS1003B_WriteByte(dat);
- //delay_Nus(200);
- VS1003B_XCS_H();
- Mp3WriteRegister(addr,dat>>8,dat);
- //讀寄存器,參數(shù) 地址 返回內(nèi)容
- unsigned int VS1003B_ReadCMD(unsigned char addr)
- unsigned int temp;
- unsigned char temp1;
- VS1003B_XDCS_H();
- VS1003B_XCS_L();
- VS1003B_WriteByte(0x03);
- //delay_Nus(20);
- temp= VS1003B_ReadByte();
- temp=temp<<8;
- temp1= VS1003B_ReadByte();
- temp=temp|temp1;;
- VS1003B_XCS_H();
- return temp;
- return(Mp3ReadRegister(addr));
- //寫數(shù)據(jù),音樂數(shù)據(jù)
- void VS1003B_WriteDAT(unsigned char dat)
- // VS1003B_XDCS_L();
- // VS1003B_WriteByte(dat);
- // VS1003B_XDCS_H();
- // VS1003B_XCS_H();
- Mp3SelectData();
- SPIPutChar(dat);
- //開啟環(huán)繞聲
- void VS1003B_SetVirtualSurroundOn(void)
- uchar ucRepeatCount;
- uint uiModeValue;
- ucRepeatCount =0;
- while(1)//寫時(shí)鐘寄存器
- uiModeValue = VS1003B_ReadCMD(0x00);
- if(uiModeValue & 0x0001)
- break;
- else
- uiModeValue |= 0x0001;
- VS1003B_WriteCMD(0,uiModeValue);
- ucRepeatCount++;
- if(ucRepeatCount++ >10 )break;
- //關(guān)閉環(huán)繞聲
- void VS1003B_SetVirtualSurroundOff(void)
- uint uiModeValue;
- ucRepeatCount =0;
- break;
- else
- ucRepeatCount++;
- //增強(qiáng)重音
- //入口參數(shù) 1.強(qiáng)度0-15
- // 2.頻率0-15 (X10Hz)
- void VS1003B_SetBassEnhance(uchar ucValue, ucFrequencyID)
- uint uiWriteValue;
- uint uiReadValue;
- ucRepeatCount =0;
- uiWriteValue = VS1003B_ReadCMD(0x02);
- uiWriteValue &= 0xFF00;
- uiWriteValue |= ucValue<<4;
- uiWriteValue &= (ucFrequencyID & 0x0F);
- VS1003B_WriteCMD(2,uiWriteValue);
- uiReadValue = VS1003B_ReadCMD(0x02);
- if(uiReadValue == uiWriteValue)
- break;
- ucRepeatCount++;
- uint uiVolumeCount; //當(dāng)前音量值
- //VS1003初始化,0成功 1失敗
- unsigned char VS1003B_Init()
- unsigned char retry;
- PORT_INI();
- DDRB|=0xa0;
- VS1003B_DDR &=~(1<<VS1003B_DREQ);
- //delay_Nus(50);
- VS1003B_XCS_H();
- VS1003B_XDCS_H();
- VS1003B_XRESET_L();
- VS1003B_Delay(0xffff);
- VS1003B_XRESET_H();//使能芯片
- VS1003B_SPI_Low();//先以低頻操作
- VS1003B_Delay(0xffff);//延時(shí)
- Mp3Reset();
- retry=0;
- while(VS1003B_ReadCMD(0x00) != 0x0800)//寫mode寄存器
- VS1003B_WriteCMD(0x00,0x0800);
- if(retry++ >10 )break;//{PORTB|=_BV(PB1);break;}
- retry=0;
- /*while(VS1003B_ReadCMD(0x02) != 0x75)//寫mode寄存器
- VS1003B_WriteCMD(0x02,0x75);
- retry=0;
- while(VS1003B_ReadCMD(0x03) != 0x9800)//寫時(shí)鐘寄存器
- VS1003B_WriteCMD(0x03,0x9800);
- retry=0;
- // while(VS1003B_ReadCMD(0x0b) != 0x1111)//設(shè)音量
- // VS1003B_WriteCMD(0x0b,0x1111);
- // if(retry++ >10 )break;
- while(VS1003B_ReadCMD(0x0b) != uiVolumeCount)//設(shè)音量
- VS1003B_WriteCMD(0x0b,uiVolumeCount);
- // VS1003B_SPI_High();//提高速度,全速運(yùn)行
- if(retry > 10)return 1;
- return 0;
- //VS1003軟件復(fù)位
- void VS1003B_SoftReset()
- VS1003B_WriteCMD(0x00,0x0804);//寫復(fù)位
- // VS1003B_Delay(0xffff);//延時(shí),至少1.35ms
- wait(2);
- void VS1003B_Fill2048Zero()
- unsigned char i,j;
- for(i=0;i<64;i++)
- if(CheckVS1003B_DRQ())
- Mp3SelectData();
- for(j=0;j<32;j++)
- VS1003B_WriteDAT(0x00);
- unsigned int data_pointer;unsigned char i;
- unsigned int uiCount;
- uiCount = sizeof(MusicData);
- data_pointer=0;
- VS1003B_SoftReset();
- while(uiCount>0)
- for(i=0;i<32;i++)
- VS1003B_WriteDAT(MusicData[data_pointer]);
- data_pointer++;
- uiCount -= 32;
- VS1003B_Fill2048Zero();
2017-3-30 16:53 上傳
2017-3-30 16:49 上傳
下載:
VS1003B MP3解碼模塊 載咪頭 STM32單片機(jī)開發(fā)板.rar
(6.28 MB, 下載次數(shù): 65)
2017-3-30 16:24 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
