#include<reg52.h>
#include<intrins.h>
typedef unsigned char U8;
typedef unsigned int U16;
typedef signed char S8;
#define lcddb P0 //1602數(shù)據(jù)總線
sbit lcden=P3^4; //en端
sbit rs=P3^5; //rs端
sbit rw=P3^6; //rw端
//sbit dula=P2^6;
//sbit wela=P2^7;
uchar code table1[]="ch20";
uchar code table2[]=" 0x05mg/m ";
uchar num1; //存儲(chǔ)通道采集的數(shù)據(jù)
void delay(uint x) //延時(shí)函數(shù)
uint a,b;
for(a=x;a>0;a--)
for(b=114;b>0;b--);
void delay1(uint x)
uint a,b;
for(a=x;a>0;a--)
for(b=100;b>0;b--);
void read_busy()
uchar busy;
lcddb = 0xff; //復(fù)位數(shù)據(jù)總線
rs = 0; //拉低rs
rw = 1; //拉高rw
do
lcden = 1; //使能en
busy = lcddb; //讀回?cái)?shù)據(jù)
lcden = 0; //拉低使能以便于下次產(chǎn)生上升沿
while(busy & 0x80); //判斷狀態(tài)字bit7位是否為1,為1側(cè)表示忙,程序等待
void write_com(uchar com) //向1602寫指令
// read_busy(); //判斷忙,忙則
P0 = com;
rs = 0;
rw = 0;
lcddb = com;
lcden = 0;
delay(10);
lcden = 1;
delay(10);
lcden = 0;
void write_date(uchar date) //向1602寫數(shù)據(jù)
P0=date;
rs=1;
lcden=0;
delay(10);
lcden=1;
delay(10);
lcden=0;
void init() //lcd初始化
rw=0;
write_com(0x38); //顯示模式設(shè)置:16×2顯示,5×7點(diǎn)陣,8位數(shù)據(jù)接口
delay(20);
write_com(0x0f); //顯示模式設(shè)置
delay(20);
write_com(0x06); //顯示模式設(shè)置:光標(biāo)右移,字符不移
delay(20);
write_com(0x01); //清屏幕指令,將以前的顯示內(nèi)容清除
delay(20);
uchar a;
init();
write_com(0x80); //將第一個(gè)字符寫在向右偏移17個(gè)字符處,為后面的由右向左劃入做準(zhǔn)備。
delay(20);
for(a=0;a<14;a++)
write_date(table1[a]); //向1602寫入第一個(gè)數(shù)據(jù)
delay(20);
write_com(0xc0);
delay(50);
for(a=0;a<14;a++)
write_date(table2[a]); //向1602寫入第二個(gè)數(shù)據(jù)
delay(40);
while(1);
