- //開機次數(shù)記憶
- #include<reg52.h>
- #define uchar unsigned char
- #define uint unsigned int
- bit write=0; //寫24C02的標志;
- sbit sda=P2^0;
- sbit scl=P2^1;
- sbit dula=P2^6;
- sbit wela=P2^7;
- sbit RST=P2^5; //時鐘
- sbit CS_DA =P2^4 ; //HJ-1G DAC
- sbit JD=P0^6;
- sbit FM=P2^3;
- uchar sec,tcnt;
- uchar code table[]={
- 0x3f,0x06,0x5b,0x4f,
- 0x66,0x6d,0x7d,0x07,
- 0x7f,0x6f,0x77,0x7c,
- 0x39,0x5e,0x79,0x71};
- void ioin() //IO口繼電器、數(shù)碼管鎖存函數(shù)
- wela=1;
- P0 = 1;
- JD = 0;
- wela=0;
- dula=1;
- P0=0;
- dula=0;
- void delay()
- void delay1ms(uint z)
- uint x,y;
- for(x=z;x>0;x--)
- for(y=110;y>0;y--);
- void start() //開始信號
- sda=1;
- delay();
- scl=1;
- delay();
- sda=0;
- delay();
- void stop() //停止
- sda=0;
- delay();
- scl=1;
- delay();
- sda=1;
- delay();
- void respons() //應答
- uchar i;
- scl=1;
- delay();
- while((sda==1)&&(i<250))i++;
- scl=0;
- delay();
- void init()
- RST=0; //總線時鐘低電評
- CS_DA =0 ;
- sda=1;
- delay();
- scl=1;
- delay();
- void write_byte(uchar date)
- uchar i,temp;
- temp=date;
- for(i=0;i<8;i++)
- temp=temp<<1;
- scl=0;
- delay();
- sda=CY;
- delay();
- scl=1;
- delay();
- scl=0;
- delay();
- sda=1;
- delay();
- uchar read_byte()
- uchar i,k;
- scl=0;
- delay();
- sda=1;
- delay();
- for(i=0;i<8;i++)
- scl=1;
- delay();
- k=(k<<1)|sda;
- scl=0;
- delay();
- return k;
- void write_add(uchar address,uchar date)
- start();
- write_byte(0xa0);
- respons();
- write_byte(address);
- respons();
- write_byte(date);
- respons();
- stop();
- uchar read_add(uchar address)
- uchar date;
- start();
- write_byte(0xa0);
- respons();
- respons();
- start();
- write_byte(0xa1);
- respons();
- date=read_byte();
- stop();
- return date;
- void display(uchar bai_c,uchar sh_c) //顯示程序
- dula=0;
- P0=table[bai_c]; //顯示第一位
- dula=1;
- dula=0;
- wela=0;
- P0=0x7e;
- wela=1;
- wela=0;
- delay1ms(5);
- dula=0;
- P0=table[sh_c]; //顯示第二位
- dula=1;
- dula=0;
- wela=0;
- P0=0x7d;
- wela=1;
- wela=0;
- delay1ms(5);
- void main()
- ioin();
- init();
- sec=read_add(2); //讀出保存的數(shù)據(jù)賦于sec
- if(sec>100) //防止首次讀取出錯誤數(shù)據(jù)
- sec=0;
- TMOD=0x01; //定時器工作在方式1
- ET0=1;
- EA=1;
- TH0=(65536-50000)/256; //對TH0 TL0賦值
- TL0=(65536-50000)%256; //使定時器0.05秒中斷一次
- TR0=1; //開始計時
- while(1)
- display(sec/10,sec%10);
- if(write==1) //判斷計時器是否計時一秒
- write=0; //清零
- write_add(2,sec); //在24c02的地址2中寫入數(shù)據(jù)sec
- void t0() interrupt 1 //定時中斷服務函數(shù)
- TL0=(65536-50000)%256; //重裝計數(shù)初值
- tcnt++; //每過50ms tcnt加一
- if(tcnt==20) //計滿20次(1秒)時
- tcnt=0; //重新再計
- sec++;
- write=1; //1秒寫一次24C02
- if(sec==100) //定時100秒,再從零開始計時
- sec=0;
復制代碼 |
