查看: 2867|回復(fù): 0
51單片機自動澆花源程序
ID:190777 發(fā)表于 2017-4-18 12:49 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
//程序頭函數(shù)
#include<reg52.h>
//宏定義
#define uintunsigned int
#define ucharunsigned char
#defineData_ADC0809 P1
//管腳聲明
sbit Feng =P3^0;
//ADC0809
sbit ST=P3^3;
sbit EOC=P3^4;
sbit OE=P3^2;
//按鍵
sbit Key1=P3^5;
sbit Key2=P3^6;
sbit Key3=P3^7;
//顯示數(shù)組        0-9+F
ucharData_[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x71,0x3f};
sbit Wei1 =P2^7;
sbit Wei2 =P2^6;
sbit Wei3 =P2^5;
sbit Wei4 =P2^4;
//函數(shù)聲明
extern ucharADC0809();
voidDisplay(uchar X,uchar Data);
void delay(uintt);
//干燥度變量
uchar temp=0;
//警界值變量
uchar FF=125;
//顯示模式
uchar Mode=0;
uchar p;
           //正常模式
           if(Mode==0)
                 //讀取AD值
                 temp=ADC0809();
                 for(p=0;p<30;p++)
                 Display(0,temp);
                 //判斷是否報警
                 if(temp>FF)
                      Feng=0;
                      Feng=1;
           //調(diào)整模式
                 Display(1,FF);
           //功能鍵
           if(Key3==0)
                 Feng=0;
                 delay(100);
                 while(Key3==0)
                      if(Mode==0)
                            Display(0,temp);
                            Display(1,FF);
                 if(Mode==0)
                      Mode=1;
                      Mode=0;
                 Feng=1;
           //增加
           if(Key2==0&&Mode==1)
                 Feng=0;
                 delay(100);
                 while(Key2==0)
                            Display(1,FF);
                 FF++;
                 if(FF==251)
                      FF=250;
                 Feng=1;
           //減少
           if(Key1==0&&Mode==1)
                 Feng=0;
                 delay(100);
                 while(Key1==0)
                            Display(1,FF);
                 FF--;
                 if(FF==0xff)
                      FF=0;
                 Feng=1;
//ADC0809讀取信息
uchar ADC0809()
      uchar temp_=0x00;
      //初始化高阻太
      OE=0;
      //轉(zhuǎn)化初始化
      ST=0;
      //開始轉(zhuǎn)換
      ST=1;
      ST=0;
      //外部中斷等待AD轉(zhuǎn)換結(jié)束
      while(EOC==0)
      //讀取轉(zhuǎn)換的AD值
      OE=1;
      temp_=Data_ADC0809;
      OE=0;
      return temp_;
//延時
void delay(uintt)
      uint i,j;
      for(i=0;i<t;i++)
           for(j=0;j<10;j++);
//顯示      X表示狀態(tài)     Data表示數(shù)據(jù)
      Wei1=1;
      Wei2=1;
      Wei3=1;
      Wei4=1;
      P0=0xff;
      //正常模式
      if(X==0)
           P0=~Data_[11];
      //非正常
           P0=~Data_[10];
      Wei1=0;
      Wei2=1;
      Wei3=1;
      Wei4=1;
      delay(10);
      Wei1=1;
      Wei2=1;
      Wei3=1;
      Wei4=1;
      P0=~Data_[Data/100];
      Wei1=1;
      Wei2=0;
      Wei3=1;
      Wei4=1;
      delay(10);
      Wei1=1;
      Wei2=1;
      Wei3=1;
      Wei4=1;
      P0=~Data_[Data/10%10];
      Wei1=1;
      Wei2=1;
      Wei3=0;
      Wei4=1;
      delay(10);
      Wei1=1;
      Wei2=1;
      Wei3=1;
      Wei4=1;
      P0=~Data_[Data%10];
      Wei1=1;
      Wei2=1;
      Wei3=1;
      Wei4=0;
      delay(10);
      Wei1=1;
      Wei2=1;
      Wei3=1;
      Wei4=1;
