查看: 4338|回復(fù): 0
51單片機舵機驅(qū)動程序
ID:191208 發(fā)表于 2017-4-19 14:17 | 顯示全部樓層 |閱讀模式
        #include<reg52.h>
        #include <intrins.h>
        sbit Sevro_moto_pwm  = P2^0        ;   //接舵機信號端輸入PWM信號調(diào)節(jié)速度
        unsigned char push_val_left=0;
           int pwm_val_left  = 0;//變量定義
        int pwm_val_left1  = 0;//變量定義
        unsigned long S=0;
        unsigned long S1=0;
        unsigned long S2=0;
        unsigned long S3=0;
        unsigned long S4=0;
        unsigned int  time=0;                       //時間變量
        unsigned int  timer=0;                        //延時基準(zhǔn)變量
        unsigned char timer1=0;                        //掃描時間變量
/*                    PWM信號產(chǎn)生控制舵機                               */
/*調(diào)節(jié)push_val_left的值改變電機轉(zhuǎn)速,占空比            */
void delay(void)
unsigned int i,j;
for(i=0;i<=500;i++)
   for(j=110;j>0;j--);
void pwm_Servomoto(void)
    if(pwm_val_left<=push_val_left)        //0
               Sevro_moto_pwm=1;
               Sevro_moto_pwm=0;
          if(pwm_val_left>=200)
           pwm_val_left=0;
void pwm_Servomoto1(void)
    if(pwm_val_left1<=20)  //135
               Sevro_moto_pwm=1;
               Sevro_moto_pwm=0;
         if(pwm_val_left1>=200)
           pwm_val_left1=0;
///*TIMER1中斷服務(wù)子函數(shù)產(chǎn)生PWM信號*/
void time1()interrupt 3   using 2
     TH1=(65536-100)/256;          //100US定時
         TL1=(65536-100)%256;
                          //定時器100US為準(zhǔn)。在這個基礎(chǔ)上延時
         pwm_val_left++;
         pwm_val_left1++;
      //         S1++;
     pwm_Servomoto();
    // pwm_Servomoto1();
void main(void)
        TMOD=0X11;
        TH0=0;
        TL0=0;
        TR1= 1;
        ET1= 1;
        ET0= 1;
        EA = 1;
    //unsigned char push_val_left=15;          //舵機歸中
        while(1)                       /*無限循環(huán)*/
       push_val_left=5;
          // delay();
           delay();
            push_val_left=20;
        //        delay();
                delay();
