- #include <stdio.h>
- #include <string.h>
- #define Null 0
- char over=0; //結(jié)束標(biāo)志
- //結(jié)構(gòu)體類型定義
- struct MenuItem
- char MenuCount; //結(jié)構(gòu)體數(shù)組的元素個(gè)數(shù)
- char *DisplayString; //當(dāng)前LCD顯示的信息
- void (*Subs)(); //執(zhí)行的函數(shù)的指針.
- struct MenuItem *Childrenms; //指向子節(jié)點(diǎn)的指針
- struct MenuItem *Parentms; //指向父節(jié)點(diǎn)的指針
- //函數(shù)聲明
- void Nop(void);
- void DoSomething(struct MenuItem *manyou);
- void GameOver(void);
- void Locate(struct MenuItem *manyou);
- void Run(struct MenuItem *manyou);
- //結(jié)構(gòu)體聲明
- struct MenuItem m0_main[4];
- struct MenuItem m1_file[5];
- struct MenuItem m1_edit[4];
- struct MenuItem m1_view[2];
- struct MenuItem m2_font[3];
- struct MenuItem m1_help[3];
- //結(jié)構(gòu)體實(shí)現(xiàn)
- struct MenuItem m0_main[4]=
- {4,"file",Nop,m1_file,Null},
- {4,"edit",Nop,m1_edit,Null},
- {4,"view",Nop,m1_view,Null},
- {4,"help",Nop,m1_help,Null},
- struct MenuItem m1_file[5]=
- {5,"open",DoSomething,Null,m0_main},
- {5,"save",DoSomething,Null,m0_main},
- {5,"save as",DoSomething,Null,m0_main},
- {5,"print",DoSomething,Null,m0_main},
- {5,"exit",GameOver,Null,m0_main},
- struct MenuItem m1_edit[4]=
- {4,"undo",DoSomething,Null,m0_main},
- {4,"redo",DoSomething,Null,m0_main},
- {4,"copy",DoSomething,Null,m0_main},
- {4,"paste",DoSomething,Null,m0_main},
- struct MenuItem m1_view[2]=
- {2,"font",Nop,m2_font,m0_main},
- {2,"color",DoSomething,Null,m0_main},
- struct MenuItem m2_font[3]=
- {3,"songti",DoSomething,Null,m1_view},
- {3,"heiti",DoSomething,Null,m1_view},
- {3,"youyuan",DoSomething,Null,m1_view},
- struct MenuItem m1_help[3]=
- {3,"index",DoSomething,Null,m0_main},
- {3,"online",DoSomething,Null,m0_main},
- {3,"about",DoSomething,Null,m0_main},
- //函數(shù)實(shí)現(xiàn)
- printf("Now we at %s\n" ,manyou->DisplayString);
- (*(manyou->Subs))(manyou);
- void Nop(void)
- printf("we have done %s\n" ,manyou->DisplayString);
- over=1;
- printf("Now Game is Over ");
- getchar();
- //主函數(shù)
- int main(int argc, char *argv[])
- char charin; //輸入的字符
- char menuid[3]={0,0,0}; //某一級的菜單的偏移量的記錄數(shù)組
- char i=0; //上面數(shù)組的下標(biāo)值
- struct MenuItem *manyou; //漫游,在菜單中漫游
- manyou=&m0_main[0]; //開始的位置
- Locate(manyou); //輸出
- while (!over) //如果還沒完
- charin=getchar(); //讀取鍵盤字符
- switch (charin) //根據(jù)字符跳轉(zhuǎn)
- case '0': //到同級菜單的后一項(xiàng)
- menuid[i]++;
- if (menuid[i]>manyou->MenuCount-1) menuid[i]=0;//可以看到MenuCount項(xiàng)是必要的
- Locate(manyou+menuid[i]);
- break;
- case '1': //到同級菜單的前一項(xiàng)
- if (menuid[i]==0) menuid[i]=manyou->MenuCount-1;//可以看到MenuCount項(xiàng)是必要的
- else menuid[i]--;
- break;
- case '+': //到下一級菜單,無下級時(shí)執(zhí)行某功能
- if ((manyou+menuid[i])->Childrenms !=Null)
- manyou=(manyou+menuid[i])->Childrenms;
- i++;
- menuid[i]=0;
- else
- Run(manyou+menuid[i]);
- break;
- case '-': //到上一級菜單,無上級時(shí)給出些提示
- if ((manyou+menuid[i])->Parentms !=Null)
- manyou=(manyou+menuid[i])->Parentms;
- i--;
- else
- printf("You are at the top of menu");
- break;
- default: break;
- return 0;
復(fù)制代碼 |
