本帖最后由 chenmoni 于 2017-4-23 08:11 編輯
我參照別人的電路圖和程序做的旋轉(zhuǎn)LED 燈一直亮著不變。求高手指點(diǎn),是不是程序有問題。
#include<reg52.h>
sbit D1=P3^2;
sbit D2=P3^4;
sbit D3=P1^0;
sbit D4=P0^7;
void delay();
void xing();
void zhunbei();
uchar code hanzi1[];
uchar code hanzi2[];
uchar code hanzi3[];
uchar code hanzi4[];
uchar code hanzi5[];
uchar code hanzi6[];
uchar code hanzi7[];
uchar code hanzi8[];
uchar code hanzi9[];
uchar code hanzi10[];
uchar code hanzi11[];
uchar code hanzi12[];
uchar code hanzi13[];
uchar code hanzi14[];
uchar code hanzi15[2][64];
uchar code hanzi16[2][64];
uchar code hanzi17[];
uchar code hanzi18[];
uchar code hanzi19[];
uchar code hanzi20[];
uchar code hanzi21[];
uchar code hanzi22[];
uchar cc,bb,mm,dd,tt,kk,kk1,kk2;kk4;
uint kk3,jj,aa;
zhunbei();
if(D1==0)
if(kk==11)
if(cc>112)
if(kk4<7)
kk4++;
kk2++;
if(kk4==7)
kk4=6;
kk2=14;
for(aa=kk4;aa<kk2;aa++)
P0=hanzi19[aa];
P1=hanzi20[aa];
D3=D4=0;
delay();
xing();
if(kk==1)
mm=cc=0;
bb=bb+1;
if(bb==95)
bb=94;
dd++;
if(dd==97)
dd=96;
for(aa=dd;aa<=bb;aa++) //////////////無論何時(shí)何地
P0=hanzi3[aa];
P1=hanzi4[aa];
delay();
P0=0xff;
P1=0xff;
if(kk==2)
dd=bb=0;
cc++;
if(cc==95)
cc=94;
mm++;
if(mm==97)
mm=96;
for(aa=mm;aa<=cc;aa++) //////////////無論身在何方
P0=hanzi5[aa];
P1=hanzi6[aa];
delay();
P0=0xff;
P1=0xff;
if(kk==3)
mm=cc=0;
bb++;
if(bb==127)
bb=126;
dd++;
if(dd==129)
dd=128;
for(aa=dd;aa<=bb;aa++) /////我愿把無數(shù)的思念
P0=hanzi7[aa];
P1=hanzi8[aa];
delay();
P0=0xff;
P1=0xff;
if(kk==4)
dd=bb=0;
cc++;
if(cc==111)
cc=110;
mm++;
if(mm==113)
mm=112;
P0=hanzi9[aa]; ///////////////////////化作無限的祝福
P1=hanzi10[aa];
delay();
P0=0xff;
P1=0xff;
if(kk==5)
mm=cc=0;
bb++;
if(bb==111)
bb=110;
dd++;
if(dd==113)
dd=112;
for(aa=dd;aa<=bb;aa++) ////////祝你健康快樂!
P0=hanzi11[aa];
P1=hanzi12[aa];
delay();
P0=0xff;
P1=0xff;
if(kk==6)
dd=bb=0;
cc++;
if(cc==40)
cc=39;
for(aa=0;aa<=cc;aa++)
P0=hanzi13[aa]; ///////////////////////(*^__^*) 嘻嘻……
P1=hanzi14[aa];
delay();
P0=0xff;
P1=0xff;
if(kk==7)
cc=0;
bb++;
if(bb==59)
bb=58;
dd++;
if(dd==7)
dd=0;
mm++;
if(mm==2)
mm=0;
for(aa=0;aa<=bb;aa++) ////////↖(^ω^)↗
P0=hanzi15[mm][aa];
P1=hanzi16[mm][aa];
delay();
P0=0xff;
P1=0xff;
if((kk==8)||(kk==9)||(kk==10))
dd=bb=0;
kk3++;
if(kk3==383)
kk3=382;
if(kk3>176)
jj++;
for(aa=jj;aa<=kk3;aa++)
P0=hanzi21[aa]; ///////////////////////每當(dāng)...........
P1=hanzi22[aa];
delay();
P0=0xff;
P1=0xff;
xing();
if(kk==11)
kk3=kk1=0;
mm=0;
cc++;
if(cc==120)
cc=119;
for(aa=cc;aa<=128;aa++)
P0=hanzi17[aa]; ///////////////////////箭頭
P1=hanzi18[aa];
delay();
P0=0xff;
P1=0xff;
D3=D4=0;
void zhunbei()
TMOD=0x11;//設(shè)置定時(shí)器0為工作方式1
TH0=0;
TL0=0;
EA=1;//開總中斷
ET0=1;//開定時(shí)器0中斷
TR0=1;//啟動定時(shí)器0
kk2=8;
kk1=0;
dd=0;
bb=0;
kk=1;
void xing()
for(aa=16;aa>0;aa--)
P0=hanzi1[aa];
P1=hanzi2[aa]; ////心型
delay();
P0=0xff;
P1=0xff;
void delay()//延時(shí)
uint x;
for(x=15;x>1;x--);
void time0() interrupt 1
TH0=0;
TL0=0;
tt++;
if(tt==255)
tt=0;
kk++;
if(kk==12)
kk=1;
kk2=8;
cc=0;
mm=0;
kk1=0;
dd=0;
bb=0;
kk4=0;
cc=0;
jj=0;
uchar code hanzi1[]={0xFF,0xF1,0xE0,0xE0,0xE0,0xF0,0xF0,0xF8,0xFC,0xF8,0xF0,0xF0,0xE0,0xE0,0xE0,0xF1};
uchar code hanzi2[]={0xFF,0xFF,0x7F,0x3F,0x1F,0x0F,0x07,0x03,0x01,0x03,0x07,0x0F,0x1F,0x3F,0x7F,0xFF};
uchar code hanzi3[]={0xFF,0xFD,0xBD,0xBD,0xBD,0xBC,0x81,0xBD,0xBC,0xBD,0xBD,0xBD,0xFD,0xFD,0xFF,0xFF,
0xFD,0xFD,0xBD,0xCC,0xFF,0xFD,0xFB,0xF6,0xCF,0x3F,0xCF,0xF6,0xFB,0xFD,0xFD,0xFF,
0xFF,0xFE,0xF9,0xE0,0x1F,0xDF,0xD8,0xDB,0xDB,0xD8,0xDF,0xDF,0xC0,0xDF,0xDF,0xFF,
0xFF,0xC0,0xDE,0xDE,0xDE,0xC0,0xFF,0xF7,0xF7,0xF7,0xF7,0xF7,0x00,0xF7,0xF7,0xFF,
0xFB,0xFB,0xFB,0x00,0xFB,0xFB,0xFE,0xE0,0xFE,0xFD,0x00,0xFB,0xF7,0xF0,0xFF,0xFF};
uchar code hanzi4[]={0xFE,0xFD,0xFB,0xF7,0xCF,0x3F,0xFF,0xFF,0x03,0xFD,0xFD,0xFD,0xFD,0xF1,0xFF,0xFF,
0xFF,0xFF,0xFF,0x01,0xFB,0xF7,0xFF,0x03,0xDD,0xBD,0x7D,0xFD,0xFD,0xF1,0xFF,0xFF,
0x7F,0xFF,0xFF,0x00,0xFF,0xFF,0x0F,0xDF,0xDF,0x0F,0xFD,0xFE,0x01,0xFF,0xFF,0xFF,
0xFF,0x03,0xF7,0xF7,0xF7,0x03,0xFF,0xFF,0x7F,0x9F,0xFD,0xFE,0x01,0xFF,0xFF,0xFF,
0xF7,0xF3,0xF7,0x0F,0xEF,0xEF,0xFF,0x03,0xFD,0xFD,0x05,0xBD,0xDD,0x3D,0xE1,0xFF};
uchar code hanzi5[]={0xFF,0xFD,0xBD,0xBD,0xBD,0xBC,0x81,0xBD,0xBC,0xBD,0xBD,0xBD,0xFD,0xFD,0xFF,0xFF,
0xFF,0xFF,0xFF,0xC0,0xD5,0x95,0x55,0xD5,0xD5,0xD5,0xD5,0xC0,0xFF,0xFE,0xFD,0xFF,
0xEF,0xEF,0xEE,0xEC,0xE3,0xCF,0x2F,0xEF,0xEF,0xE8,0xEF,0xEF,0xEF,0xEF,0xEF,0xFF,
0xEF,0xEF,0xEF,0xEF,0xEF,0xE0,0x6E,0x8E,0xEE,0xEE,0xEE,0xEE,0xEF,0xEF,0xEF,0xFF};
uchar code hanzi6[]={0xFE,0xFD,0xFB,0xF7,0xCF,0x3F,0xFF,0xFF,0x03,0xFD,0xFD,0xFD,0xFD,0xF1,0xFF,0xFF,
0xFD,0xBD,0xBD,0x3B,0xBB,0xBB,0xB7,0xB7,0xAF,0x9D,0xBE,0x01,0x7F,0xFF,0xFF,0xFF,
0xBF,0x7F,0xFF,0x00,0xFD,0x7D,0x7D,0x7D,0x7D,0x01,0x7D,0x7D,0x7D,0x7D,0xFD,0xFF,
0xFF,0xFE,0xFD,0xFB,0xE7,0x1F,0xFF,0xFF,0xFD,0xFE,0xFD,0x03,0xFF,0xFF,0xFF,0xFF};
uchar code hanzi7[]={0xFB,0xDB,0xDB,0xDB,0x80,0x3B,0xBB,0xFB,0xFB,0x00,0xFB,0xBB,0xCB,0xFA,0xFB,0xFF,
0xFF,0xFF,0x80,0xBF,0xBF,0xA0,0xAA,0xAA,0x8A,0xAA,0xAA,0xAA,0xA0,0xBF,0xBF,0xFF,
0xF7,0xF7,0xF7,0x00,0xF7,0xF6,0xFF,0x80,0xBE,0xBE,0x80,0xBE,0xBE,0x80,0xFF,0xFF,
0xF6,0xB5,0xD3,0xF7,0x00,0xF7,0xD3,0xB5,0xFE,0xF1,0x0E,0xEF,0xEF,0xE0,0xEF,0xFF,
0xFF,0xE0,0xCF,0x2F,0xEF,0xEF,0xE0,0xFD,0xF3,0x0E,0xEF,0xEF,0xEF,0xE0,0xFF,0xFF,
0xFF,0xFF,0x80,0xB6,0xB6,0xB6,0xB6,0x80,0xB6,0xB6,0xB6,0xB6,0x80,0xFF,0xFF,0xFF,
0xFD,0xFD,0xFB,0xFB,0xF6,0xEE,0xD6,0x38,0xDE,0xEE,0xF6,0xFB,0xFB,0xFD,0xFD,0xFF};
uchar code hanzi8[]={0xFF,0xEF,0xED,0xDE,0x01,0xBF,0x7D,0xFD,0xFB,0x37,0xCF,0xD7,0xBB,0x7D,0xE0,0xFF,
0xFE,0xF9,0x07,0xFE,0xD9,0xBF,0x79,0xDE,0xEE,0x12,0xFE,0x7C,0xBF,0xD7,0xF9,0xFF,
0xDF,0xDD,0xBE,0x01,0x7F,0xFF,0xFF,0x03,0xFD,0xFD,0xFD,0xFD,0xFD,0x7D,0xF1,0xFF,
0xBE,0xA6,0x95,0x39,0xBB,0xB5,0x8E,0xFF,0xFE,0xFD,0x33,0xCF,0x33,0xFD,0xFE,0xFF,
0xFF,0x01,0x7B,0x7B,0x7B,0x7B,0x01,0xFF,0xFF,0xFF,0x3D,0xFE,0xFD,0x03,0xFF,0xFF,
0xFD,0xE3,0x7F,0xFF,0xC3,0xFD,0xFD,0xBD,0xCD,0xFD,0xFD,0xF1,0x5F,0xEF,0xF3,0xFF,
0xFD,0xF3,0xFF,0xFF,0xE3,0xFD,0xFD,0xDD,0xA5,0x7D,0xFD,0xF1,0xFF,0xEF,0xF3,0xFF};
uchar code hanzi9[]={0xFF,0xFE,0xF9,0xE0,0x1F,0xFF,0xFF,0xFF,0x00,0xFD,0xFB,0xF7,0xEF,0xDF,0xFF,0xFF,
0xFF,0xFE,0xF9,0xE0,0x1F,0xFD,0xF3,0x0F,0xE0,0xEE,0xEE,0xEE,0xEE,0xEF,0xEF,0xFF,
0xFF,0x80,0xBB,0xA5,0x9E,0xFF,0x80,0xB6,0xB6,0xB6,0xB6,0xB6,0x80,0xFF,0xFF,0xFF,
0xEF,0xEF,0x6E,0x88,0xE6,0xFF,0x81,0xBD,0xBC,0xBD,0xBD,0xBC,0xBD,0x81,0xFF,0xFF,
0xEF,0x6F,0x8C,0xE2,0xEF,0xFF,0xBF,0xA1,0xAD,0xAD,0xAD,0xAD,0xAD,0xA1,0xBF,0xFF,
uchar code hanzi10[]={0x7F,0xFF,0xFF,0x00,0xFF,0xDF,0xBF,0x7F,0x03,0xFD,0xFD,0xFD,0xFD,0xFD,0xE1,0xFF,
0x7F,0xFF,0xFF,0x00,0xFF,0xFF,0xFF,0xFF,0x00,0xEF,0xEF,0xEF,0xEF,0xEF,0xFF,0xFF,
0xFF,0x00,0xDF,0xEF,0x1F,0xFF,0x00,0xFD,0xFB,0x3F,0xCF,0xD7,0xBB,0x7D,0xFD,0xFF,
0xBF,0x7F,0xFF,0x00,0xFE,0x3D,0xFB,0xE7,0x1F,0xFF,0xFF,0x03,0xFD,0xFD,0xE1,0xFF,
0xBF,0x7F,0x00,0xFF,0x3F,0xFF,0x00,0x6D,0x6D,0x6D,0x01,0x6D,0x6D,0x6D,0x00,0xFF};
uchar code hanzi11[]={0xEF,0xEF,0x6E,0x88,0xE6,0xFF,0x81,0xBD,0xBC,0xBD,0xBD,0xBC,0xBD,0x81,0xFF,0xFF,
0xFF,0xFE,0xF9,0xE0,0x1F,0xFD,0xFB,0xE7,0x0F,0xEF,0xEC,0xEF,0xEF,0xEB,0xE7,0xFF,
0xFE,0xF9,0xE0,0x1F,0xEF,0xEC,0xE3,0xF7,0xD5,0xD5,0x00,0xD5,0xD5,0xC1,0xF7,0xFF,
0xFF,0xFF,0xC0,0xDD,0xD5,0xD5,0xD5,0x55,0x80,0xD5,0xD5,0xD5,0xD0,0xDD,0xDD,0xFF,
0xFF,0xF8,0xFF,0x00,0xF7,0xFB,0xEF,0xEF,0xEF,0x00,0xEF,0xEF,0xE0,0xFF,0xFF,0xFF,
0xFF,0xFF,0xF8,0xC6,0xDE,0xDE,0xDE,0xD0,0xBE,0xBE,0x3E,0xBE,0xFE,0xFE,0xFF,0xFF,
0xFF,0xFF,0xF1,0xE0,0xE0,0xF1,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF};
uchar code hanzi12[]={0xBF,0x7F,0xFF,0x00,0xFE,0x3D,0xFB,0xE7,0x1F,0xFF,0xFF,0x03,0xFD,0xFD,0xE1,0xFF,
0x7F,0xFF,0xFF,0x00,0xFF,0xF7,0xCF,0x3F,0xFD,0xFE,0x01,0xFF,0x7F,0x9F,0xE7,0xFF,
0xFF,0xFF,0x00,0xFE,0x6D,0x73,0x0B,0xED,0x6D,0x6D,0x01,0x6D,0x6D,0x6D,0xED,0xFF,
0xFD,0xF3,0x0F,0xFD,0x3B,0x57,0x6D,0x7E,0x01,0x5F,0x6F,0x77,0x6B,0xDD,0xFD,0xFF,
0x7F,0xFF,0xFF,0x00,0xFF,0x7E,0x7D,0x73,0x4F,0x3F,0x4F,0x73,0x7D,0x7E,0x7E,0xFF,
0xFF,0xFB,0xF7,0xEF,0x9F,0xFD,0xFE,0x01,0xFF,0xFF,0xBF,0xDF,0xEF,0xF3,0xFF,0xFF,
0xFF,0xFF,0xFF,0x4F,0x4F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF};
uchar code hanzi13[]={0xFF,0xFF,0xFC,0xF0,0xE3,0xEF,0xFF,0xFF,0xFF,0xEF,0xCF,0x9F,0x9F,0xCF,0xEF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xEF,0xCF,0x9F,0x9F,0xCF,0xEF,0xFF,
0xFF,0xFF,0xEF,0xE3,0xF0,0xFC,0xFF,0xFF};
uchar code hanzi14[]={0xFF,0xFF,0x1F,0x07,0xE3,0xFB,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFD,0xFD,0xFD,0xFD,0xFD,0xFD,0xFD,0xFD,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFB,0xE3,0x07,0x1F,0xFF,0xFF};
uchar code hanzi15[2][64]={{0xFF,0xFF,0xDF,0xE7,0xE0,0xF3,0xF5,0xF6,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0xE7,
0xDF,0xBF,0xFF,0xFF,0xDF,0xBF,0xBF,0xBF,0xDF,0xF8,0xF7,0xEF,0xFF,0xFC,0xFF,0xEF,
0xF7,0xF8,0xDF,0xBF,0xBF,0xBF,0xDF,0xFF,0xFF,0xBF,0xDF,0xE7,0xF0,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xF6,0xF5,0xF3,0xE0,0xE7,0xDF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
{0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0xE7,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},};
uchar code hanzi16[2][64]={{0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0xBF,0xDF,0xEF,0xF7,0xFB,0x1F,0xCF,
0xF7,0xFB,0xFD,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x3F,0xDF,0xEF,0xDF,0x3F,0xDF,0xEF,
0xDF,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFD,0xFB,0xF7,0xCF,0x1F,0xFB,0xF7,0xEF,
0xDF,0xBF,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
{0xFB,0xF1,0xEA,0xFB,0xFB,0xFB,0xFB,0xFB,0xFB,0xFB,0xFB,0xFB,0xFB,0xFB,0x1F,0xCF,
0xDF,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFD,0xFB,0xF7,0xCF,0x1F,0xFB,0xFB,0xFB,
0xFB,0xFB,0xFB,0xFB,0xFB,0xFB,0xFB,0xFB,0xEA,0xF1,0xFB,0xFF,0xFF,0xFF,0xFF,0xFF},};
uchar code hanzi17[]={0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFE,0xFC,0xFC,0xFA,0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,
0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,
0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xFC,0xFC,0xFC,0xFC,0xFE};
uchar code hanzi18[]={0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0x7F,0x7F,0xBF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0x7F,0x7F,0x7F,0xFF};
uchar code hanzi19[]={0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0xFC,0xFC,0xFA,0xFE,0xFE,0xFE,0xFE};
uchar code hanzi20[]={0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0x7F,0xBF,0xFF,0xFF,0xFF,0xFF};
uchar code hanzi21[]={0xFB,0xF7,0xCF,0x30,0xB7,0xB7,0xB5,0xB6,0xB7,0xB7,0xB7,0xB0,0xBF,0xBF,0xFF,0xFF,
0xFF,0xFD,0xBD,0xDD,0xE5,0xFD,0xFD,0x01,0xFD,0xFD,0xF5,0xED,0x9C,0xFF,0xFF,0xFF,
0xF7,0xF9,0xBF,0xCE,0xFF,0xDD,0xD9,0xD5,0x4D,0x9D,0xDD,0xD5,0xD9,0xDC,0xDF,0xFF,
0xFF,0xFF,0xFF,0x82,0xAB,0xAB,0xAB,0xA8,0xAB,0xAB,0xAB,0x83,0xFF,0xFF,0xFF,0xFF,
0xFB,0xFB,0xFB,0x00,0xFB,0xBB,0xD7,0xF6,0xF7,0xFF,0xE0,0xFF,0xFF,0x00,0xFF,0xFF,
0xFD,0xFD,0xBD,0xCC,0xFF,0xEF,0xED,0xEE,0xEF,0xEF,0xEF,0x00,0xEF,0xEF,0xEF,0xFF,
0xFD,0xFD,0xFC,0x05,0x55,0x55,0x54,0x55,0x55,0x55,0x55,0x05,0xFD,0xFD,0xFD,0xFF,
0xFD,0xFD,0xBD,0xCC,0xFF,0xFF,0xFF,0xC0,0xDB,0xDB,0xDB,0xB8,0x3B,0xBB,0xFB,0xFF,
0xFD,0xFD,0xBD,0xBD,0xBD,0xBD,0xBD,0x80,0xBD,0xBD,0xBD,0xBD,0xBD,0xFD,0xFD,0xFF,
0xFD,0xFD,0xBD,0xCC,0xFF,0xFF,0xEF,0xEF,0xEE,0x01,0xEF,0xEF,0xEF,0xE0,0xFF,0xFF,
0xFD,0xFD,0xFB,0xFB,0xF5,0xED,0xDD,0x3D,0xDD,0xED,0xF5,0xFB,0xFB,0xFD,0xFD,0xFF,
0xFF,0xFB,0xBB,0xCB,0xFB,0xFB,0xF8,0x03,0xFB,0xFB,0xFB,0xFB,0xF8,0xFF,0xFF,0xFF,
0xFD,0xFD,0xBD,0xCC,0xFF,0xFF,0xFB,0xE7,0x0F,0xEF,0xE0,0xEF,0xEF,0xEF,0xFF,0xFF,
0xBF,0xBF,0xBF,0xBF,0xBF,0xBF,0x80,0xBF,0xBF,0xBD,0xBE,0xBF,0xBF,0xBF,0xBF,0xFF,
0xFF,0xFF,0xFE,0xFF,0xFF,0xF8,0xBF,0xDF,0xE7,0xFF,0xFF,0xFF,0xFD,0xFE,0xFF,0xFF,
uchar code hanzi22[]={0x7F,0x7F,0x07,0x77,0x77,0x77,0x57,0x67,0x75,0x76,0x75,0x03,0x77,0x77,0x7F,0xFF,
0xFF,0xFD,0xDD,0xDD,0xDD,0xDD,0xDD,0xDD,0xDD,0xDD,0xDD,0xDD,0x00,0xFF,0xFF,0xFF,
0xDF,0xDF,0x81,0x7F,0xFE,0xFD,0x83,0xFF,0xFF,0x80,0xFF,0xFF,0x81,0xFE,0xF8,0xFF,
0xFF,0xDD,0xBD,0x6D,0x6D,0x6D,0x6D,0x01,0x6D,0x6D,0x6D,0x6D,0x7D,0xFD,0xFF,0xFF,
0xFD,0xFD,0xFB,0x37,0xCF,0xD7,0xBB,0x7D,0xE0,0xFF,0x0F,0xFD,0xFE,0x01,0xFF,0xFF,
0xFF,0xFD,0xFB,0x07,0xFB,0xFD,0xFD,0x7D,0xFD,0xED,0xF5,0x0D,0xFD,0xFD,0xFD,0xFF,
0xFB,0xF9,0x03,0x5B,0x57,0x57,0x00,0xF6,0x1D,0x6B,0x77,0x4B,0x3D,0xFE,0xFE,0xFF,
0xFF,0xFD,0xFB,0x07,0xFB,0xF5,0xCD,0x3D,0xFD,0xFD,0xFD,0x05,0xFD,0xFD,0xFD,0xFF,
0xFE,0xFE,0xFD,0xFB,0xF7,0xCF,0x3F,0xFF,0x3F,0xCF,0xF7,0xFB,0xFD,0xFE,0xFE,0xFF,
0xFF,0xFD,0xFB,0x07,0xFB,0xF5,0xED,0x9D,0x7D,0xFD,0xED,0xF5,0xED,0x1D,0xFD,0xFF,
0xFF,0xFF,0xFF,0xCF,0xCF,0xCF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xBF,0xBD,0xB8,0xB5,0xAD,0x9D,0xBD,0xBD,0xBD,0xB5,0xB9,0xBC,0xBF,0xFF,0xFF,
0xFE,0xFD,0xFB,0xF7,0xEF,0x9F,0x7F,0xFF,0x7F,0x9D,0xFE,0xFD,0x03,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0x01,0xFB,0xF7,0x7F,0x7F,0x7F,0x7F,0x00,0x7F,0x7F,0x7F,0x7F,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0xFF,0xFF,0xFF,0xFF,0x7F,0x9F,0xFF,0xFF,0xFF,
0xBF,0x7F,0x00,0xFF,0x3F,0xFF,0x00,0x6D,0x6D,0x6D,0x01,0x6D,0x6D,0x6D,0x00,0xFF,
0xF7,0xCF,0x3F,0xFF,0xFF,0x03,0xFD,0xFD,0xFD,0xFD,0xFD,0xE1,0xFF,0x7F,0x8F,0xFF,
