查看: 3032|回復(fù): 1
L298N驅(qū)動(dòng)實(shí)例
ID:192571 發(fā)表于 2017-4-23 09:14 | 顯示全部樓層 |閱讀模式
(1)
#include<reg51.h>
sbit INPUT1 = P1^0; //控制口
sbit INPUT2 = P1^1;
sbit INPUT3 = P1^2;
sbit INPUT4 = P1^3;
sbit ENA   = P1^4; //產(chǎn)生PWM
sbit ENB   = P1^5;
uint MA=0,MB=0;
uint SpeedA=20;//50%占空比
uint SpeedB=20;
void delay(uint z) {
         uintx,y;
         for(x=z;x>0;x--)
                   for(y=125;y>0;y--);
void main(void)
         delay(1000)      ;
         delay(1000)      ;
         INPUT1=1;
         INPUT2=0;
         INPUT3=1;
         INPUT4=0;
         TH0= 0xF4;
         TL0= 0x48;
         TH1= 0xF4;
         TL1= 0x48;
         TMOD= 0x11;
         TR0= 1;
         TR1= 1;
         ET0= 1;
         ET1= 1;
         EA  = 1;
         while(1){}
void time0_int() interrupt 1 using 1
         TR0=0;
         TH0=0xF4;
         TL0=0x48;
         MA++;
         if(MA<SpeedA){
           ENA = 1;
         elseENA = 0;
         if(MA== 40){
           MA = 0;
         TR0= 1;
void time1_int() interrupt 3 using 1
         TR1=0;
         TH1=0xF4;
         TL1=0x48;
         MB=MB+ 1;
         if(MB< SpeedB){
           ENB=1;
         elseENB = 0;
         if(MB== 40){
           MB = 0;
         TR1= 1;
(2)
#include <reg52.h>
sbit KEY1 = P3^1;
sbit PWM = P1^5;
unsigned char CYCLE; //定義周期 該數(shù)字X基準(zhǔn)定時(shí)時(shí)間 如果是10 則周期是10 x0.1ms
unsigned char PWM_ON ;//定義高電平時(shí)間
void delay(unsigned int cnt)
while(--cnt);
main()
unsigned char PWM_Num;//定義檔位
TMOD |=0x01;//定時(shí)器設(shè)置 1ms in12M crystal
TH0=(65536-1000)/256;
TL0=(65536-1000)%256;//定時(shí)1mS
IE= 0x82; //打開中斷
TR0=1;
CYCLE = 10;// 時(shí)間可以調(diào)整 這個(gè)是10步調(diào)整 周期10ms 8PWM就是256
if(!KEY1)
  delay(10000);
  if(!KEY1)
     PWM_Num++;
           if(PWM_Num==4)PWM_Num=0;
      switch(PWM_Num){
      case 0:P1=0xFE;PWM_ON=0;break;//高電平時(shí)長(zhǎng)
      case 1:P1=0xFD;PWM_ON=4;break;
      case 2:P1=0xFB;PWM_ON=6;break;
      case 3:P1=0xF7;PWM_ON=8;break;
      default:break;
/*     定時(shí)中斷                */
void tim(void) interrupt 1 using 1
static unsigned char count; //
if (count==PWM_ON)
    PWM = 1; //燈滅
count++;
if(count == CYCLE)
   count=0;
         if(PWM_ON!=0)//如果左右時(shí)間是0 保持原來(lái)狀態(tài)
            PWM = 0;//燈亮
(3)
/***************電子電機(jī)驅(qū)動(dòng)模塊直流電機(jī)控制程序**************************/
#include <reg52.h>
sbit IN1=P1^0;
sbit IN2=P1^1;
sbit IN3=P1^2;
sbit IN4=P1^3;
sbit EN1=P1^4;
sbit EN2=P1^5;
unsigned int pwm_H;
unsigned int pwm_L;
/***********初始函數(shù)函數(shù)**********************************/
/*日期:201222 */
/*版本號(hào) V1.2*/
/*說(shuō)明:初始化系統(tǒng),調(diào)用速度設(shè)置函數(shù)前請(qǐng)先初始化*/
void InitSpeed()
TMOD=0X01;
TL0=0;
TH0=0;
TR0=1;
ET0=1;
EA=1;
/***********速度設(shè)置函數(shù)**********************************/
/*日期:201222 */
/*版本號(hào) V1.2*/
/*說(shuō)明:0-1000級(jí)速度,值越高速度越快*/
void SetSpeed(unsigned int num)
if(num<1000)
pwm_L=65535-num;
pwm_H=65536-(1001-num);
else return ;
/*日期:201222 */
/*版本號(hào) V1.2*/
/*說(shuō)明:左轉(zhuǎn)設(shè)置函數(shù)*/
void TurnLeft()
IN1=0;
IN2=1;
IN3=0;
IN4=1;
/*日期:201222 */
/*版本號(hào) V1.2*/
/*說(shuō)明:右轉(zhuǎn)設(shè)置函數(shù)*/
void TurnRight()
IN1=1;
IN2=0;
IN3=1;
IN4=0;
/************電機(jī)使能*********************************/
/*日期:201222 */
/*版本號(hào) V1.2*/
void MotorGo()
EN1=0;
EN2=0;
InitSpeed();
TurnRight();
MotorGo();
SetSpeed(999);
  while(1);
/*******定時(shí)器0中斷服務(wù)程序*************/
void Timer0() interrupt 1 using 1
                 static char stepFlag;
                   TR0=0;
                   if(stepFlag==1)
                   TL0=pwm_H;
       TH0=pwm_H>>8;
                   EN1=0;      //電機(jī)1不使能
                   EN2=0;      //電機(jī)2不使能
                   stepFlag=0;
             TL0=pwm_L;
       TH0=pwm_L>>8;
                  EN1=1;     //電機(jī)1使能
                   EN2=1;      //電機(jī)2使能
                   stepFlag=1;
                   TR0=1;
ID:751649 發(fā)表于 2021-4-11 11:24 | 顯示全部樓層
用你的程序,電機(jī)只有嗡嗡聲音,不轉(zhuǎn)動(dòng)啊
