查看: 2035|回復(fù): 0
電子時(shí)鐘51單片機(jī)
ID:194487 發(fā)表于 2017-4-28 10:26 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include<reg51.h>
#include<intrins.h>
#define GPIO_KEY P1
#define SEG P0
#define LED P2
/*138譯碼器位選數(shù)碼管*/
sbit LSA=P2^2;
sbit LSB=P2^3;
sbit LSC=P2^4;
sbit Beep=P1^5;
typedef unsigned int uint;
typedef unsigned char uchar;
uchar code segduan[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
uchar shi=23,fen=59,miao=50;
uchar KeyValue;
bit flag;
uchar jishu=0;
void delay(uint us)
        while(us--);
void KeyDown()
        char a=0;
        GPIO_KEY=0x0f;
        if(GPIO_KEY!=0x0f)//讀取按鍵是否按下
                delay(100);//延時(shí)10ms進(jìn)行消抖
                if(GPIO_KEY!=0x0f)//再次檢測(cè)鍵盤是否按下
                        //測(cè)試列
                        GPIO_KEY=0X0F;
                        switch(GPIO_KEY)
                                case(0X07):        KeyValue=0;break;
                                case(0X0b):        KeyValue=1;break;
                                case(0X0d): KeyValue=2;break;
                                case(0X0e):        KeyValue=3;break;
                        //測(cè)試行
                        GPIO_KEY=0XF0;
                        switch(GPIO_KEY)
                                case(0X70):        KeyValue=KeyValue;break;
                                case(0Xb0):        KeyValue=KeyValue+4;break;
                                case(0Xd0): KeyValue=KeyValue+8;break;
                                case(0Xe0):        KeyValue=KeyValue+12;break;
                        while((a<50)&&(GPIO_KEY!=0xf0))         //檢測(cè)按鍵松手檢測(cè)
                                delay(1000);
                                a++;
void weixuan(uchar se,uint ne)
        switch(se)
                /*1-8位數(shù)碼管位選*/
                case 0:LSC=0;LSB=0;LSA=0;break;
                case 1:LSC=0;LSB=0;LSA=1;break;
                case 2:LSC=0;LSB=1;LSA=0;break;
                case 3:LSC=0;LSB=1;LSA=1;break;
                case 4:LSC=1;LSB=0;LSA=0;break;
                case 5:LSC=1;LSB=0;LSA=1;break;
                case 6:LSC=1;LSB=1;LSA=0;break;
                case 7:LSC=1;LSB=1;LSA=1;break;
        SEG = segduan[ne];
        delay(5);
        SEG = 0x00;
void dpDisplay()
         LSC=0;LSB=1;LSA=0;//case2:
         SEG = 0x40;
         delay(5);
         SEG = 0x00;
         LSC=1;LSB=0;LSA=1;//case5:
         SEG = 0x40;
         delay(5);
         SEG = 0x00;
void miaoDisplay(uchar num)
        uchar n;
        n=num%10;
        weixuan(0,n);
        n=num/10;
        weixuan(1,n);
void fenDisplay(uchar num)
        uchar n;
        n=num%10;
        weixuan(3,n);
        n=num/10;
        weixuan(4,n);
void shiDisplay(uchar num)
        uchar n;
        n=num%10;
        weixuan(6,n);
        n=num/10;
        weixuan(7,n);
void Timer0_set()
        TMOD = 0x01;
        TH0=0x4b;
        TL0=0xfc;
        TR0=1;
        void seg1();
        void seg01();
        void seg02();
        void fx4();
        LED = 0xff;
        Timer0_set();
                KeyValue = 0;
                KeyDown();
                switch(KeyValue)
                   case 2:flag=0;break;
                   case 6:flag=1;break;
                   case 10:shi=23;fen=59;miao=50;break;
                   case 14:shi=0;fen=0;miao=10;break;
                   default:break;
                seg1();
void seg1()
                if(flag==0)
                        seg01();
                if(flag==1)
                        seg02();
                miaoDisplay(miao);
                dpDisplay();
                fenDisplay(fen);
                shiDisplay(shi);
                fx4();
void seg01()
                   if(TF0==1)
                {        TH0=0x4b;
                        TL0=0xfc;
                        TF0=0;
                        jishu++;
                if(jishu==20)
                        jishu=0;
                        miao++;
                if(miao==60)
                        miao=0;
                        if(fen!=59)
                                fen++;
                        if(fen==59)
                                 fen=0;
                                if(shi!=23)
                                        shi++;
                                if(shi==23)
                                        shi=0;
void seg02()
                if(TF0==1)
                {        TH0=0x4b;
                        TL0=0xfc;
                        TF0=0;
                        jishu++;
                if(jishu==20)
                        jishu=0;
                        miao--;
                if(miao==0)
                        miao=59;
                        if(fen !=0)
                                fen--;
                        if(fen==0)
                                 fen = 59;
                                if(shi !=0)
                                        shi--;
                                if(shi==0)
                                        shi=23;
void fx4()
        if(shi==0 && fen==0)
                if(miao<=3)
                        LED = 0x03;
                         Beep=~Beep;
                        delay(5);
                        LED = 0xff;
