代碼如下:
頻率部分
#include <reg51.h>
#include <intrins.h>
#define out P0
#define send P2
unsigned int ADresult[11];
sbit DATOUT=P1^0;
sbit DATIN=P1^1;
sbit CS=P1^2;
sbit IOCLK=P1^3;
sbit EOC=P1^4;
sbit RS=P3^0;
sbit RW=P3^1;
sbit E=P3^5;
sfr16 DPTR=0x82;//定義寄存器DPTR(頻率部分)
unsigned char cnt_t0,cnt_t1,qian,bai,shi,ge;
unsigned char freq;
unsigned char code digit[10]={"0123456789"};
unsigned char code Str_V[]={"V="};
unsigned char code Str_U[]={"Vm="};
unsigned char code Str_F[]={"F="};
void delay_ms(unsigned int z)
unsigned char i,j;
for(i=0;i<z;i++)
for(j=0;j<110;j++);
定時(shí)器的初始化
void init()
freq=0;//賦頻率初值
cnt_t1=0;
cnt_t0=0;
IE=0x8a;//開(kāi)T0,T1中斷
TMOD=0x15;//T0為定時(shí)器方式1,T1為計(jì)數(shù)器方式1
TH1=0x3c;//T1定時(shí)50ms
TL1=0xb0;
TH0=0;//T0清0
TL0=0;
TR0=1;//開(kāi)啟定時(shí)器T0
lcd1602的準(zhǔn)備工作
void check_busy()//檢測(cè)忙函數(shù)
unsigned char dt;
do{
dt=0xff;//dt作為變量單元,初值為0xff
E=0;
RS=0;//按照讀寫(xiě)操作規(guī)定RS=0,E=1時(shí)才可以讀忙標(biāo)志
RW=1;
E=1;
dt=out;
}while(dt&0x80);
E=0;
void write_command(unsigned char com)//寫(xiě)命令函數(shù)
check_busy();
E=0;
RS=0;
RW=0;
out=com;
E=1;
_nop_();
_nop_();
E=0;
delay_ms(10);
void write_data(unsigned char dat)//寫(xiě)數(shù)據(jù)函數(shù)
check_busy();
E=0;
RS=1;
RW=0;
out=dat;
E=1;
_nop_();
E=0;
delay_ms(10);
void LCD_initial(void)//液晶顯示器的初始化函數(shù)
write_command(0x38);//寫(xiě)入0x38(命令6):兩行顯示,5*7點(diǎn)陣,8位數(shù)據(jù)
_nop_(); //空操作,給硬件反應(yīng)時(shí)間
write_command(0x0C);//寫(xiě)入0x0C(命令4):開(kāi)整體顯示,光標(biāo)關(guān),無(wú)閃爍
write_command(0x06);//寫(xiě)入0x06(命令3),寫(xiě)入一個(gè)字符后,地址指針加1
write_command(0x01);//寫(xiě)入(命令1):清屏
delay_ms(10);
lcd1602上符號(hào)的顯示
void display_V(void)//顯示‘V=’
unsigned char i;
write_command(0x80);
i=0;
while(Str_V[i]!='\0')
write_data(Str_V[i]);
i++;
void display_U(void)//顯示‘Vm=’
unsigned char i;
write_command(0x88);
i=0;
while(Str_U[i]!='\0')
write_data(Str_U[i]);
i++;
void display_F(void)//顯示‘F=’
unsigned char i;
write_command(0x40+0x80);
i=0;
while(Str_F[i]!='\0')
write_data(Str_F[i]);
i++;
void display_Hz(void)//頻率的單位‘Hz’的顯示
write_command(0x47+0x80);
write_data('H');
write_command(0x48+0x80);
write_data('z');
void display_mV(void)
write_command(0x05+0x80);//V的單位‘mv’的顯示
write_data('m');
write_command(0x06+0x80);
write_data('v');
write_command(0x0e+0x80);//Vm的單位'mv'的顯示
write_data('m');
write_command(0x0f+0x80);
write_data('v');
將數(shù)據(jù)輸出到lcd1602上
void displayV(unsigned char x)//V值送lcd1602
unsigned char i,j,k;
i=x/100;
j=x/10%10;
k=x%10;
write_command(0x04+0x80);
write_command(0x03+0x80);
write_data(digit[i]);
write_data(digit[j]);
write_data(digit[k]);
void displayU(unsigned char x)//Vm值送lcd1602
unsigned char l,w,n;
l=x*141/100/100;
w=x*141/100/10%10;
n=x*141/100%10;
write_command(0x0d+0x80);
write_command(0x0b+0x80);
write_data(digit[l]);
write_data(digit[w]);
write_data(digit[n]);
void displayF(unsigned char x)//頻率值送lcd1602
qian=x/1000 ;
bai= x/100%10 ;
shi=x/10%10;
ge=x%10 ;
write_command(0x46+0x80);
write_command(0x45+0x80);
write_command(0x44+0x80);
write_command(0x43+0x80);
write_data(digit[qian]);
write_data(digit[bai]);
write_data(digit[shi]);
write_data(digit[ge]);
中斷函數(shù)(頻率部分)
void t1_func() interrupt 3
TH1=0x3c;
TL1=0xb0;
cnt_t1++;
void t0_func() interrupt 1
cnt_t0++;
電壓數(shù)據(jù)獲取函數(shù)
unsigned int getdata(unsigned char channel)//channel是通道號(hào)
unsigned char i,temp;
unsigned int read_ad_data=0;
channel=channel<<4;
IOCLK=0;
CS=0;
temp=channel;
for(i=0;i<12;i++)
if(DATOUT)read_ad_data=read_ad_data|0x01;//讀入第一次的數(shù)據(jù)
DATIN=(bit)(temp&0x80);//寫(xiě)入方式/通道命令字
IOCLK=1; //IOCLK上跳沿
_nop_(); //空操作延時(shí)
_nop_();
_nop_();
IOCLK=0; //IOCLK下跳沿
_nop_();
_nop_();
temp=temp<<1; //丟棄最高位,讀取第二高位的值
read_ad_data<<=1; //轉(zhuǎn)換結(jié)果左移一位
CS=1; //CS上跳沿
read_ad_data<<=1; //抵消第12次左移,得到12位轉(zhuǎn)換結(jié)果
return(read_ad_data);
主函數(shù)
main(void)
init();//定時(shí)器初始化
LCD_initial();//lcd1602初始化
display_Hz();//各類(lèi)字符的顯示
_nop_();
display_F();
_nop_();
display_V();
_nop_();
display_U();
_nop_();
display_mV();
_nop_();
主函中頻率部分
if(cnt_t1==19)//定時(shí)1s
cnt_t1=0;
TR1=0;
delay_ms(141);
TR0=0;
DPL=TL0;
DPH=TH0;
freq=cnt_t0*65535;
freq=freq+DPTR;
send=freq;//數(shù)據(jù)送到P2口
displayF(send);//通過(guò)P2發(fā)出去
_nop_();
主函數(shù)中電壓部分
_nop_();
_nop_();
_nop_();
ADresult[2]=getdata(2);
while(!EOC);
out=ADresult[2]*122;//數(shù)據(jù)送到P0口
displayV(out);//改成1602的顯示方式
_nop_();
_nop_();
displayU(out);//通過(guò)P0發(fā)出去
_nop_();
