該文檔從網(wǎng)上找來(lái)的,但是缺了幾個(gè)頭文件。
現(xiàn)補(bǔ)充如下
#ifndef _Lcd_1602_H_
#define _Lcd_1602_H_
extern void Init_Lcd();
extern void LCD_write_str(unsigned char X,unsigned char Y,unsigned char *s);
//extern void LCD_set_xy(uchar x,uchar y )
//extern void LCD_en_write(void)
//extern void LCD_write_char(uchar cd,uchar ab)
//extern void LCD_byte(unsigned char abc)
extern LCD_value(unsigned char x,unsigned char y,float f);
#endif
#ifndef _Time_Delay_H_
#define _Time_Delay_H_
extern void Delay_ms(unsigned int n);
extern void Delay_us(unsigned char n);
#endif
#ifndef _DHT11_H_
#define _DHT11_H_
extern char COM(void);
extern void getDHT11(void);
#endif
