查看: 2636|回復(fù): 0
基于protues的ampire12864漢字顯示
ID:192154 發(fā)表于 2017-5-7 15:57 | 顯示全部樓層 |閱讀模式
file:///C:/Users/user1/AppData/Local/Temp/msohtml1/01/clip_image002.jpg
中文資料文庫(kù)地址:
http://wenku.baidu.com/link?url=2RskpTcACLnDJp-GdMjaTVbrq7HNjjeLZ_5Kvkz3Xld-PkmTcTwzUFbEfC_daKr0KcE57b_JYbeD2eX3VRI2qSAV7exIPvhsnWfnPw8ATSu
#include<reg52.h>
#include<intrins.h>
sbit CS1=P2^4;
sbit CS2=P2^3;
sbit RS=P2^2;
sbit RW=P2^1;
sbit E=P2^0;
void check_busy();                   //忙檢測(cè)
void write_cmd(ucharinst);          //寫(xiě)命令
void write_data(uchardat);             //寫(xiě)數(shù)據(jù)
void set_xy(ucharx,uchar y);            //設(shè)置顯示坐標(biāo)
void LCD_Init();                        //lcd初始化
//  字摸軟件提取出的數(shù)據(jù),提取字模時(shí)要注意參數(shù)設(shè)置,縱向取模,字節(jié)倒序。
uchar code HZ0[6][32]={//;--  文字:    --
//;-- 宋體12;  此字體下對(duì)應(yīng)的點(diǎn)陣為:寬x=16x16   --
{0x80,0x90,0x8C,0x84,0x84,0x84,0xF5,0x86,0x84,0x84,0x84,0x84,0x94,0x8C,0x80,0x00,0x00,0x80,0x80,0x84,0x46,0x49,0x28,0x10,0x10,0x2C,0x23,0x40,0x80,0x00,0x00,0x00},
//;-- 文字:    --
{0x10,0x88,0xC4,0x23,0xAE,0x68,0x2F,0x28,0xAE,0x20,0xD8,0x17,0x10,0xF0,0x10,0x00,0x01,0x00,0xFF,0x48,0x29,0x8D,0xFB,0x09,0xAC,0x48,0x37,0x08,0x36,0x41,0x80,0x00},
//;-- 文字:    --
{0x00,0x04,0x04,0x04,0x04,0x04,0x04,0xFC,0x04,0x04,0x04,0x04,0x04,0x04,0x00,0x00,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x3F,0x20,0x20,0x20,0x20,0x30,0x20,0x20,0x00},
//;-- 文字:  業(yè)  --
{0x00,0x10,0x60,0x80,0x00,0xFF,0x00,0x00,0x00,0xFF,0x00,0x00,0xC0,0x30,0x00,0x00,0x40,0x40,0x40,0x43,0x40,0x7F,0x40,0x40,0x40,0x7F,0x42,0x41,0x40,0x40,0x40,0x00},
//;-- 文字:    --
{0x20,0x20,0x20,0x20,0x20,0x20,0x20,0xFF,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x00,0x80,0x80,0x40,0x20,0x10,0x0C,0x03,0x00,0x03,0x0C,0x10,0x20,0x40,0x80,0x80,0x00},
//;-- 文字:  學(xué)  --
{0x40,0x30,0x11,0x96,0x90,0x90,0x91,0x96,0x90,0x90,0x98,0x14,0x13,0x50,0x30,0x00,0x04,0x04,0x04,0x04,0x04,0x44,0x84,0x7E,0x06,0x05,0x04,0x04,0x04,0x04,0x04,0x00}
uchar code FZ0[10][32]={
/*-- 文字:  I  --*/
/*-- 宋體12;  此字體下對(duì)應(yīng)的點(diǎn)陣為:寬x=8x16   --*/
{0x00,0x08,0x08,0xF8,0x08,0x08,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00},
/*-- 文字:     --*/
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},
/*-- 文字:  L  --*/
{0x08,0xF8,0x08,0x00,0x00,0x00,0x00,0x00,0x20,0x3F,0x20,0x20,0x20,0x20,0x30,0x00},
/*-- 文字:  O  --*/
{0xE0,0x10,0x08,0x08,0x08,0x10,0xE0,0x00,0x0F,0x10,0x20,0x20,0x20,0x10,0x0F,0x00},
/*-- 文字:  V  --*/
{0x08,0x78,0x88,0x00,0x00,0xC8,0x38,0x08,0x00,0x00,0x07,0x38,0x0E,0x01,0x00,0x00},
/*-- 文字:  E  --*/
{0x08,0xF8,0x88,0x88,0xE8,0x08,0x10,0x00,0x20,0x3F,0x20,0x20,0x23,0x20,0x18,0x00},
/*-- 文字:     --*/
/*-- 文字:  Y  --*/
{0x08,0x38,0xC8,0x00,0xC8,0x38,0x08,0x00,0x00,0x00,0x20,0x3F,0x20,0x00,0x00,0x00},
/*-- 文字:  O  --*/
/*-- 文字:  U  --*/
{0x08,0xF8,0x08,0x00,0x00,0x08,0xF8,0x08,0x00,0x1F,0x20,0x20,0x20,0x20,0x1F,0x00}
/************************延時(shí)函數(shù)**************************/
voiddelayus(uchar delay)
uchar i;
for(i=0;i<=delay;i++)
_nop_();
/********************忙檢查*********************************/
voidcheck_busy()
uchar a=0;
for(a=0;a<200;a++);                  //此處為延時(shí),一段時(shí)間后確保處于空閑狀態(tài)
/*                                      //此處為狀態(tài)查詢(xún),查詢(xún)忙狀態(tài),沒(méi)有使用成功,以后再調(diào)試
RW=1;
RS=0;
E=1;
     E=1;
if(!(P0&0x80))
break;
         a++;
if(a>10)
                   break;
E=1;
/********************寫(xiě)命令函數(shù)*********************************/
voidwrite_cmd(ucharinst)
check_busy();
RS=0;
RW=0;
E=1;
P3=inst;
E=0;
_nop_();
/********************寫(xiě)數(shù)據(jù)函數(shù)*********************************/
voidwrite_data(uchardat)
check_busy();
RS=1;
RW=0;
E=1;
P3=dat;
E=0;
_nop_();
/********************初始化函數(shù)*********************************/
voidLCD_Init()
write_cmd(0x30);//30H--基本指令操作?
delayus(4);
write_cmd(0x0c);//開(kāi)顯示,關(guān)光標(biāo),不閃爍。
delayus(10);
write_cmd(0x01);//清除顯示
delayus(10);
write_cmd(0x06);//光標(biāo)的移動(dòng)方向左,DDRAM的地址計(jì)數(shù)器(AC)加1
delayus(10);
/*******************設(shè)置顯示坐標(biāo)*********************************/
void set_xy(ucharx,uchar y)           //x為行,y為列
if(y>=64)                            //列地址大于等于64時(shí)右屏顯示?
  CS2=0;                          //低電平選擇
         CS1=1;                            //寫(xiě)右屏是左屏關(guān)閉,不然兩邊會(huì)同時(shí)顯示
         y=y-64;
else                                 //列地址小于64時(shí)左屏顯示
  CS1=0;                            //同上
         CS2=1;
write_cmd(0x40|y);                      //寫(xiě)列地址
_nop_();
write_cmd(0xb8|x);                         //寫(xiě)行地址?
/*******************顯示中文字體*********************************/
voiddisp_hz(ucharR,ucharL,uchar *p)
uchar i;
for(i=0;i<16;i++)
set_xy(2*R,16*L+i);           //設(shè)定顯示位置,每個(gè)漢字16*16個(gè)點(diǎn),顯示時(shí)每行8*16個(gè)點(diǎn),所以需要兩行8*32個(gè)點(diǎn),此處為第一行
write_data(p);           //寫(xiě)入DDRAM
set_xy(2*R+1,16*L+i);        //第二行
write_data(p[i+16]);
voiddisp_zf(ucharR,ucharL,uchar *p)
uchar i;
for(i=0;i<8;i++)
set_xy(2*R,8*L+i);                 //設(shè)定顯示位置,每個(gè)字母16*8個(gè)點(diǎn),顯示時(shí)每行8*8個(gè)點(diǎn),所以需要兩行8*16個(gè)點(diǎn),此處為第一行
write_data(p);
set_xy(2*R+1,8*L+i);                //第二行
write_data(p[i+8]);
uchar k=0,n=0;
LCD_Init();                  //初始化
for(k=0;k<6;k++)
disp_hz(1,1+k,HZ0[k]);          //顯示安徽工業(yè)大學(xué)
for(n=0;n<10;n++)
disp_zf(2,3+n,FZ0[n]);            //顯示 I LOVE YOU
while(1){;};
