查看: 2549|回復(fù): 1
藍(lán)牙小車程序c51
ID:198662 發(fā)表于 2017-5-9 15:33 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include<reg51.h>
#include <intrins.h>
sbit IN1=P2^0;
sbit IN2=P2^1;
sbit IN3=P2^2;
sbit IN4=P2^3;
sbit IN11=P2^4;
sbit IN21=P2^5;
sbit IN31=P2^6;
sbit IN41=P2^7;
sbit beet=P1^3;
sbit TRIG=P1^2;
sbit ECHO=P1^1;
sbit led=P1^4;
sbit p10=P1^0;
sbit lin=P1^2;
sbit hong=P3^3;
sbit LED=P0^0;
uint pwm,push,push1,shu,flag,flagg,butt[5]=0,j,i,num,time,lednum;
/*void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
  for(y=110;y>0;y--);
void init()
IN1=0;
    IN2=0;
IN3=0;
    IN4=0;
IN11=0;
    IN21=0;
IN31=0;
    IN41=0;
LED=1;
TMOD=0X21;
TH0=(65536-1000)/256;
TL0=(65536-1000)%256;
TH1=0xfd;
TL1=0xfd;
TR0=1;
ET0=1;
TR1=1;
REN=1;
SM0=0;
SM1=1;
ES=1;
EA=1;
beet=1;
num=0;
lednum=0;
push=187;
lin=1;
hong=1;
void time1() interrupt 1
     TH0=(65536-100)/256;
  TL0=(65536-100)%256;
  pwm++;
  if(pwm<=push)
   p10=1;
  p10=0;
  if(pwm>=200)
  pwm=0;
if(led==0)
   time++;
   if(time==1000)
    time=0;
    if(num==0)
     beet=1;
    if(num==2)
     beet=0;
    if(num==3)
     beet=1;
    if(num==5)
     beet=0;
    num++;
    if(num==10)
     num=0;
void ser() interrupt 4
ES=0;
if(RI==1)
  RI=0;
  shu=SBUF;
  if((shu==0x4f)&&(j==0))
   butt[j]=shu;
   flag=1;
  else if(flag==1)
     j++;
     butt[j]=shu;
     if(j>=2)
      j=0;
      flag=0;
      flagg=1;
  ES=1;
void liang()
     LED=0;
void mie()
    LED=1;
void qian()
IN1=1;
IN2=0;
IN3=1;
IN4=0;
IN11=1;
IN21=0;
IN31=1;
IN41=0;
void hou()
IN1=0;
IN2=1;
IN3=0;
IN4=1;
IN11=0;
IN21=1;
IN31=0;
IN41=1;
void you()
IN1=0;
IN2=1;
IN3=0;
IN4=1;
IN11=1;
IN21=0;
IN31=1;
IN41=0;
void zuo()
IN1=1;
IN2=0;
IN3=1;
IN4=0;
IN11=0;
IN21=1;
IN31=0;
IN41=1;
void ting()
IN1=0;
IN2=0;
IN3=0;
IN4=0;
IN11=0;
IN21=0;
IN31=0;
IN41=0;
void ling()
lin=0;
void lig()
lin=0;
void hf()
while(hong!=1)
lin=0;
ting();
init();
hf();
  if(led==1)
   TR0=0;
   ET0=0;
   beet=1;
   lednum=0;
   if(flagg==1)
    flagg=0;
    if((butt[0]==0x4f)&&(butt[1]==0x4e))
     switch(butt[2])
      case 0x41:qian();break;
      case 0x42:hou();break;
      case 0x43:zuo();break;
      case 0x44:you();break;
      case 0x46:ting();break;
      case 0x31:ling();break;
      case 0x32:lig();break;
      case 0x34:mie();break;
         case 0x33:liang();break;
/* if(led==0)
   if(lednum==0)
    ting();
    lednum=0;
   lednum++;
   //TR0=1;
   //ET0=1;
   if(flagg==1)
    flagg=0;
     switch(butt[2])
      case 0x45:ting();break;
ID:194699 發(fā)表于 2017-5-9 23:02 來自觸屏版 | 只看該作者
樓主怎么不來電說明呀?
