查看: 10368|回復(fù): 2
Arduino電子時鐘
ID:199578 發(fā)表于 2017-5-11 15:45 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
第一步:按照接線圖接線并上傳程序及代碼
Arduino                    DS3231                  LCD1602-I2C
5V                                 VCC                         VCC
GND                             GND                        GND
A4                                 SDA                         SDA
A5                                 SCL                          SCL
第二步:上傳程序代碼,調(diào)試模塊,檢驗程序效果
將連接好的Arduino插在電腦上,打開Arduino IDE,上傳代碼到板子里。
#include
#include
#include
DS3231 Clock;
bool Century=false;
bool h12;
bool PM;
byte ADay, AHour, AMinute, ASecond, ABits;
bool ADy, A12h, Apm;
byte year, month, date, DoW, hour, minute, second;
uint8_t bell[8] = {0x4,0xe,0xe,0xe,0x1f,0x0,0x4};
LiquidCrystal_I2C lcd(0x3F,16,2);
char data[15];
char Str_year[3], Str_month[3], Str_date[3], Str_DoW[3], Str_hour[3], Str_minute[3], Str_second[3];
void setup() {
     // Start the I2C interface
     Wire.begin();
     Serial.begin(9600);
         lcd.init();
         lcd.backlight();
         Serial.println("Please enter the time: year[2]month[2]date[2]DoW[2]hour[2]minute[2]second[2]");
         Serial.println("example: 2014-12-3 Wednesday 14:15:15 enter:14120303141515");
void settime(){
    if (Serial.available() >=14)     //串口讀取數(shù)據(jù)
    for (int a = 0; a <14; a++)
                 data[a] = Serial.read();
                 Str_year[0] = data[0];    //拆包
                 Str_year[1] = data[1];
                 Str_month[0] = data[2];
                 Str_month[1] = data[3];
                 Str_date[0] = data[4];
                 Str_date[1] = data[5];
                 Str_DoW[0] = data[6];
                 Str_DoW[1] = data[7];
                 Str_hour[0] = data[8];
                 Str_hour[1] = data[9];
                 Str_minute[0] = data[10];
                 Str_minute[1] = data[11];
                 Str_second[0] = data[12];
                 Str_second[1] = data[13];
                 //Str to byte
                 year = atoi(Str_year);    //轉(zhuǎn)換數(shù)據(jù)類型
                 month = atoi(Str_month);
                 date = atoi(Str_date);
                 DoW = atoi(Str_DoW);
                 hour = atoi(Str_hour);
                 minute = atoi(Str_minute);
                 second = atoi(Str_second);
                 Clock.setSecond(second);//Set the second
                 Clock.setMinute(minute);//Set the minute
                 Clock.setHour(hour);  //Set the hour
                 Clock.setDoW(DoW);    //Set the day of the week
                 Clock.setDate(date);  //Set the date of the month
                 Clock.setMonth(month);  //Set the month of the year
                 Clock.setYear(year);  //Set the year (Last two digits of the year)
void loop() {
  int second,minute,hour,date,month,dow,year,temperature;
    settime();
   second= Clock.getSecond();
   minute=Clock.getMinute();
   hour=Clock.getHour(h12, PM);
   date=Clock.getDate();
   month=Clock.getMonth(Century);
   year=Clock.getYear();
   dow=Clock.getDoW();
   temperature=Clock.getTemperature();
   Serial.print("20");
   Serial.print(year,DEC);
   Serial.print('-');
   Serial.print(month,DEC);
   Serial.print('-');
   Serial.print(date,DEC);
   Serial.print(' ');
   Serial.print(hour,DEC);
   Serial.print(':');
   Serial.print(minute,DEC);
   Serial.print(':');
   Serial.print(second,DEC);
   Serial.print('');
   Serial.print("Temperature=");
   Serial.print(temperature);
   Serial.print('');
lcd.setCursor(0, 0);
   lcd.print("20");  // 顯示20世紀
     if (year>=10)  // 顯示年份
       lcd.print(year,DEC);
       lcd.print("0");
   lcd.print('-');
   lcd.setCursor(5, 0);
     if (month>=10)  // 顯示月份
       lcd.print(month,DEC);
       lcd.print("0");
   lcd.print('-');
   lcd.setCursor(8, 0);
     if (date>=10)  // 顯示日期
       lcd.print(date,DEC);
       lcd.print("0");
   lcd.setCursor(11, 0);
     switch (dow)  // 顯示星期
       case 1:  // 當dow等于1時,執(zhí)行以下語句
         lcd.print("Mon");
         break;
       case 2:  // 當dow等于2時,執(zhí)行以下語句
         lcd.print("Tue");
         break;
       case 3:
         lcd.print("Wed");
         break;
       case 4:
         lcd.print("Thu");
         break;
       case 5:
         lcd.print("Fri");
         break;
       case 6:
         lcd.print("Sat");
         break;
       case 7:
         lcd.print("Sun");
         break;
   lcd.setCursor(0, 1);  //光標移至第2行
     if (hour>=10)  // 顯示小時
       lcd.print(hour,DEC);
       lcd.print("0");
   lcd.print(':');
   lcd.setCursor(3, 1);
     if (minute>=10)  // 顯示分鐘
       lcd.print(minute,DEC);
       lcd.print("0");
   lcd.print(':');
   lcd.setCursor(6, 1);
     if (second>=10)  // 顯示秒鐘
       lcd.print(second,DEC);
       lcd.print("0");
   lcd.setCursor(9, 1);
   if (Clock.checkAlarmEnabled(1))  // 顯示鬧鐘標識
     lcd.write(0x00);
     lcd.print(' ');
   lcd.setCursor(12, 1);
   lcd.print(temperature);  // 顯示溫度
   lcd.write(0xdf);  // 顯示溫度單位
   lcd.print("C");
   delay(1000);
結(jié)果:上電后發(fā)現(xiàn),模塊成功運行,但是顯示的時間不對。
第三步:通過串口,對時鐘模塊進行校準,使得時間正常顯示
找到上面代碼中的如下這一段,你可以了解到,圖中紅框內(nèi)的文字,是程序本身對校準時間定義了格式,還舉例說明了。所以,可以通過固定的格式,在串口對時鐘模塊進行校準
首先,查看你目前情況下的年月日、北京時間、星期,隨后打開Arduino IDE 的串口監(jiān)視器,在串口發(fā)送框里輸入當前北京時間,并點擊發(fā)送,原先的時間就變成了你所要設(shè)定的時間。
例:2017年2月28日 星期二 11:45:55秒
串口輸入的就是:2017022802114555
注意:如果時間顯示不對,請多發(fā)送幾次。反應(yīng)周期有點慢。
收藏收藏4 分享淘帖 頂 踩
ID:827989 發(fā)表于 2020-11-24 19:17 | 只看該作者
頭文件是什么??
ID:827989 發(fā)表于 2020-11-25 08:55 | 只看該作者
代碼不對呀
