查看: 4973|回復(fù): 0
LED驅(qū)動(dòng)PAM2861引腳圖 應(yīng)用電路圖 pdf資料下載
ID:199590 發(fā)表于 2017-5-11 16:01 | 顯示全部樓層 |閱讀模式
LED驅(qū)動(dòng)PAM2861資料,免費(fèi)放送
PAM2861引腳圖如下:
PAM2861應(yīng)用電路圖:
The PAM2861 is a continuous mode inductive step-down converter,
designed for driving single or multiple series connected LEDs
efficiently from a voltage source higher than the LED voltage. The
device operates from an input  supply between 6V and 40V and
provides an externally adjustable output current of up to 1A.
Depending upon supply voltage and external components, this can
provide up to 30 watts of output power.
The PAM2861 includes the output switch and a high-side output
current sensing circuit,  which uses an external resistor to set the
nominal average output current.
Output current can be adjusted below the set value, by applying an
external control signal to the VSET pin.
The VSET pin will accept either a DC voltage or a PWM waveform.
The soft-start time can be increased using an external capacitor from
the VSET pin to ground. Applying a voltage of 0.2V or lower to the
VSET pin turns the output off and switches the device into a low
current standby state.
完整資料下載:
PAM2861.pdf (346.36 KB, 下載次數(shù): 13)
