查看: 3648|回復(fù): 0
RTC實(shí)時(shí)時(shí)鐘DS1302液晶顯示單片機(jī)源程序
RTC實(shí)時(shí)時(shí)鐘DS1302液晶顯示 ds18b20
  1. /*-----------------------------------------------
  2.   名稱:LCD1602顯示實(shí)時(shí)時(shí)鐘
  3.   修改:無(wú)
  4.   內(nèi)容:音樂(lè)鬧鐘  普通鬧鐘已被注釋    音樂(lè)鬧鐘無(wú)法停止 自動(dòng)播放后停止 (普通鬧鐘功能正常)
  5.         error:無(wú)
  6.         warning:四個(gè) 函數(shù)未被調(diào)用
  7.   -----------------------------------------------*/
  8. #include<reg52.h>
  9. #include <String.h>
  10. #include"ds1302.h"
  11. #include"LCD1602.h"
  12. #include"key.h"
  13. #include "18B20.h"
  14. #include "240c02.h"
  15. sbit buzeer = P2^3;           //普通鬧鐘
  16. sbit led1 =P2^4;              //指示燈
  17. sbit led2 =P2^5;
  18. sbit led3 =P2^6;
  19.
  20. sbit fm=P2^3;                  //音樂(lè)鬧鐘 接口相同
  21. unsigned char timeh,timel,music;//            鬧鐘變量
  22. unsigned char code zbjbxf[]={//
  23. 0x64,0xA3,0xC1,0xA2,0x62,0x84,0x61,0x81,0x61,0xA4,0xA1,
  24. 0x91,0xA1,0x81,0x64,0xA3,0xC1,0xD2,0xD2,0xD2,0xA2,0xC4,
  25. 0xA1,0xC1,0xA1,0xC1,0xD2,0xD2,0xD2,0xA2,0xC4,0xC2,0x62,
  26. 0xC2,0x62,0xA2,0xA2,0x84,0x94,0x94,0x92,0x81,0x91,
  27. 0xA2,0xC2,0xD4,0xE4,0xA4,0xE4,0xA2,0xE2,0xA2,0xE2,0xA2,
  28. 0xA2,0x84,0x94,0x94,0x92,0x81,0x91,0xA2,0xC2,0xD8};
  29. uchar code chuzhi[]={
  30.          0xff,0xff,//
  31.          0xFC,0x8E,//L1-7
  32.          0xFC,0xED,
  33.          0xFD,0x43,
  34.          0xFD,0x6A,
  35.          0xFD,0xB3,
  36.          0xFD,0xF3,
  37.          0xFE,0x2D,
  38.          0xFE,0x47,//H1-7
  39.          0xFE,0x76,
  40.          0xFE,0xA1,
  41.          0xFE,0xC7,
  42.          0xFE,0xD9,
  43.          0xFE,0xF9,
  44.          0xFF,0x16
  45.          };
  46. void timer0() interrupt 1         //音樂(lè)鬧鐘中斷
  47. {
  48.         TH0=timeh;
  49.         TL0=timel;
  50.         fm=~fm;
  51. }
  52. void delay(uint z)        //??165MS,??????
  53. {        uint y;
  54.         for(z;z>0;z--)
  55.                  for(y=19000;y>0;y--);//????
  56. }
  57. void delay1(uint z)        //??1MS
  58. {        uint y;
  59.         for(z;z>0;z--)
  60.                  for(y=112;y>0;y--);//????
  61. }
  62. //sbit bell = P2^3;
  63. char key;
  64. char keyflg;
  65. //時(shí)鐘變量
  66. unsigned char times[7]={1};
  67. unsigned char time[3];
  68. unsigned char PPP;
  69. unsigned char clock_buf[7];
  70. //鬧鐘變量
  71. unsigned char counter;
  72. unsigned char baifenmiao;
  73. unsigned char shifenmiao;
  74. unsigned char miao;
  75. unsigned char shimiao;
  76. unsigned char baimiao;
  77. void key_timeset(void);
  78. void dateTrans(void);
  79. void alarm_aclok(void);
  80. void arm(void);
  81. void timer_run(void);
  82. void timer_runback(void);
  83. void clock_display(void);
  84. void clock_delay(void);
  85. void start(void);
  86. void delay_ms(unsigned int z);
  87. void ds18b20(void);
  88. void ds18b20_xiugai(void);
  89. void xieshuju(void);
  90. void dushuju(void);
  91.
  92. void buzeer_music()                    //音樂(lè)鬧鐘
  93. {
  94.         uint temp;        //??????????????????
  95.         uchar i=0;
  96.         uchar jp;        //jp????temp???8???8?
  97.         TMOD=0x01;//?????T0?????1
  98.         IE=0x82;  //??T0??
  99.         while(music)
  100.         {
  101.                                         /*        ds1302_read_time();//讀取時(shí)鐘信息
  102.
  103.                                                 dateTrans();         //數(shù)據(jù)復(fù)制
  104.                                                 disp();*/
  105.                 key = Key4Scan();
  106.                 if(key==4){cflg=1; keyflg=0;music=0;}
  107.                 if(key==6){ keyflg=0;}
  108.                 clock_delay();
  109.
  110.
  111.                 temp=zbjbxf[i];
  112.                 if(temp==0xff)
  113.                         break;
  114.                 jp=temp/16; //????4?,????
  115.                 if(jp!=0)
  116.                 {
  117.                 timeh=chuzhi[jp*2];//????????8?
  118.                 timel=chuzhi[jp*2+1]; //????????8?
  119.                 TR0=1;          //????
  120.                 }
  121.                 else
  122.                 {
  123.                 TR0=0;          //????
  124.                 fm=1;          //????
  125.                 }
  126.                 delay(temp%16); //????4?,??(?????)
  127.                 TR0=0;         //??????5MS
  128.                 fm=1;
  129.                 delay1(5);
  130.                 //TR0=1;
  131.                 i++;
  132.         }
  133.         /*TR0=0;        //????
  134.         fm=1;        //????*/                //JJX
  135. }
  136. void Time1_Int(){          //用于定時(shí) 倒計(jì)時(shí)
  137.                 TMOD=0x10;
  138.                 TH1=0xfc;          //10毫秒
  139.                 TL1=0x66;
  140.                 EA=1;
  141.                 ET1=1;
  142.                 TR1=1;
  143. }
  144. void main()
  145. {
  146.                          //buzeer=0;        //鬧鐘停
  147.                                 buzeer=1;                                // 接非門后鬧鐘停
  148.                         // dushuju(); //e2prom 讀數(shù)據(jù) 有問(wèn)題
  149.                          ds1302_init(); /*DS302初始化函數(shù)*/
  150.
  151.        ds1302_write_time();
  152.                          ds1302_read_time();
  153.                         // tmpchange();
  154.                          //Time0_Int();
  155.        InitLcd();     //初始化LCD
  156.        DelayMs(15);   //延時(shí)用于穩(wěn)定功能
  157.                          Time1_Int();
  158.                          start();                //開(kāi)機(jī)顯示
  159.
  160.   while(1)
  161.         {
  162.                                 key = Key4Scan();
  163.                     if(!cflag){
  164.
  165.                                                 if(key==4) { buzeer= 1;/*buzeer= 0;*/}               //按鍵停止鬧鐘
  166.                                         //        while(1);              //調(diào)試
  167.                                                 alarm_aclok();                                         //鬧鐘
  168.
  169.                                                 ds1302_read_time();//讀取時(shí)鐘信息
  170.
  171.                                                 dateTrans();         //數(shù)據(jù)復(fù)制
  172.                                                 disp();         //液晶顯示時(shí)間信息
  173.                                                 timer_run();         //秒表
  174.                                                 timer_runback();                //倒計(jì)時(shí)
  175.                                                 clock_display();                //時(shí)鐘顯示
  176.                                                 if(key==7) keyflg=7;
  177.                                                 ds18b20();                                        //按鍵顯示
  178.                                         //        ds18b20_xiugai();               // 顯示位置修改
  179.                                                 if(key==4) keyflg=0;
  180.                                                 if(key==5) keyflg=5;
  181.                                                 if(key==6) keyflg=6;
  182.
  183.
  184.                                                 clock_delay();                  //瞌睡
  185.                                                 xieshuju();                   // ——>到e2prom
  186.                                         //        WriteCommand(0x80+0x40+15); //按鍵調(diào)試信息
  187.                                         //        WriteData(shuzi[key]);
  188.                                 }
  189.                                 key_timeset();           //案件時(shí)間設(shè)定
  190.                         }
  191.
  192. }
  193. void key_timeset(void){
  194.         char i;
  195.                 switch(key)   //Key4Scan()
  196.                         {
  197.                                                 case 0x01:
  198.        switch(PP++)      //??????
  199.        {
  200.        case 0:  WriteCommand(0x80+0x40+7);break;                                                //秒
  201.        case 1:  WriteCommand(0x80+3);break;            //年
  202.        case 2:  WriteCommand(0x80+6);break;                                                //月
  203.        case 3:  WriteCommand(0x80+9);break;                                //日
  204.        case 4:  WriteCommand(0x80+15);break;                                //周
  205.        case 5:  WriteCommand(0x80+0x40+1);break;                                //時(shí)
  206.        case 6:  WriteCommand(0x80+0x40+4);break;                                //分
  207.        default:break;
  208.        }
  209.        WriteCommand(0x0f);//光標(biāo)閃爍
  210.        if(PP == 8) PP = 0;                 //7還是 8好像和編譯器有關(guān)系
  211.
  212.        cflag = 1;          //????
  213.
  214.        break;
  215.                                                 case 0x02:
  216.        if(cflag)
  217.        {
  218.        switch(PP-1)
  219.        {
  220.        case 1:          // 年
  221.        times[6]++;
  222.        if((times[6]&0x0f) == 0x0a)                   //  0000 1111 1010  轉(zhuǎn)變?yōu)?6進(jìn)制
  223.        {
  224.        times[6] += 0x06;
  225.        }
  226.        if(times[6] > 0x99)
  227.        {
  228.        times[6] = 0x00;
  229.        }
  230.        WriteCommand(0x80+2);
  231.        WriteData(shuzi[times[6]>>4]);
  232.        WriteData(shuzi[times[6]&0x0f]);
  233.        WriteCommand(0x80+3);
  234.        break;
  235.        case 2:                                 //月
  236.        times[4]++;
  237.        if((times[4]&0x0f) == 0x0a)
  238.        {
  239.        times[4] += 0x06;
  240.        }
  241.        if(times[4] > 0x12)
  242.        {
  243.        times[4] = 0x01;
  244.        }
  245.        WriteCommand(0x80+5);
  246.        WriteData(shuzi[times[4]>>4]);
  247.        WriteData(shuzi[times[4]&0x0f]);
  248.        WriteCommand(0x80+6);
  249.        break;
  250.        case 3:                        //
  251.        times[3]++;
  252.        if((times[3]&0x0f) == 0x0a)
  253.        {
  254.        times[3] += 0x06;
  255.        }
  256.        if(times[3] > 0x31)
  257.        {
  258.        times[3] = 0x01;
  259.        }
  260.        times[5]++;
  261.        if((times[5]&0x0f) == 0x08)
  262.        {
  263.        times[5] = 0x01;
  264.        }
  265.        WriteCommand(0x80+8);
  266.        WriteData(shuzi[times[3]>>4]);
  267.        WriteData(shuzi[times[3]&0x0f]);
  268.        WriteCommand(0x80+9);
  269.
  270.        break;
  271.        case 4:         //?
  272.        times[5]++;
  273.        if((times[5]&0x0f) == 0x08)
  274.        {
  275.        times[5] = 0x01;
  276.        }
  277.        WriteCommand(0x80+15);
  278.        WriteData(shuzi[times[5]]);
  279.        WriteCommand(0x80+15);
  280.
  281.        break;
  282.        case 5:         //?
  283.        times[2]++;
  284.        if((times[2]&0x0f) == 0x0a)
  285.        {
  286.        times[2] += 0x06;
  287.        }
  288.        if(times[2] > 0x23)
  289.        {
  290.        times[2] = 0x00;
  291.        }
  292.        WriteCommand(0x80+0x40+0);
  293.        WriteData(shuzi[times[2]>>4]);
  294.        WriteData(shuzi[times[2]&0x0f]);
  295.        WriteCommand(0x80+0x40+1);
  296.
  297.        break;
  298.        case 6:         //?
  299.        times[1]++;
  300.        if((times[1]&0x0f) == 0x0a)
  301.        {
  302.        times[1] += 0x06;
  303.        }
  304.        if(times[1] > 0x59)
  305.        {
  306.        times[1] = 0x00;
  307.        }
  308.        WriteCommand(0x80+0x40+3);
  309.        WriteData(shuzi[times[1]>>4]);
  310.        WriteData(shuzi[times[1]&0x0f]);
  311.        WriteCommand(0x80+0x40+4);
  312.
  313.        break;
  314.        case 0:         //?
  315.        times[0]++;
  316.        if((times[0]&0x0f) == 0x0a)
  317.        {
  318.        times[0] += 0x06;
  319.        }
  320.        if(times[0] > 0x59)
  321.        {
  322.        times[0] = 0x00;
  323.        }
  324.        WriteCommand(0x80+0x40+6);
  325.        WriteData(shuzi[times[0]>>4]);
  326.        WriteData(shuzi[times[0]&0x0f]);
  327.        WriteCommand(0x80+0x40+7);
  328.
  329.        break;
  330.        default:
  331.        break;
  332.
  333.        }
  334.        }
  335.        break;
  336.                                                 case 0x03:
  337.        if(cflag)
  338.        {
  339.        cflag = 0;
  340.        PP = 0;
  341.        WriteCommand(0X0C);   //取消 并關(guān)光標(biāo)
  342.        }
  343.        break;
  344.                                                 case 0x04:                                 //保存數(shù)據(jù)到 DS1302
  345.        if(cflag)
  346.        {
  347.        cflag = 0;
  348.        PP = 0;
  349.        WriteCommand(0X0C);   //關(guān)光標(biāo)
  350.        ds1302_write_byte(ds1302_control_add,0x00);                        //關(guān)閉寫保護(hù)
  351.        ds1302_write_byte(ds1302_sec_add,0x80);                                //暫停
  352.        ds1302_write_byte(ds1302_charger_add,0xa9);                        //涓流充電
  353.
  354.        ds1302_write_byte(ds1302_year_add,times[6]);                //年
  355.        ds1302_write_byte(ds1302_month_add,times[4]);        //月
  356.        ds1302_write_byte(ds1302_day_add,times[5]);                //周
  357.        ds1302_write_byte(ds1302_date_add,times[3]);                //日
  358.
  359.        ds1302_write_byte(ds1302_hr_add,times[2]);                //時(shí)
  360.        ds1302_write_byte(ds1302_min_add,times[1]);                //分
  361.        ds1302_write_byte(ds1302_sec_add,times[0]);                //秒
  362.        ds1302_write_byte(ds1302_control_add,0x80);                        //打開(kāi)寫保護(hù)
  363.
  364.        // Set_DS1302(times);   //DS1302 寫入時(shí)間
  365.        }
  366.        break;
  367.                                                  case 0x05:            //保存數(shù)據(jù)到鬧鐘
  368.        if(cflag)
  369.        {
  370.        cflag = 0;
  371.        PP = 0;
  372.        WriteCommand(0X0C);   //關(guān)光標(biāo)
  373.        for(i=0;i<7;i++){
  374.        clock_buf[i]=times[i];
  375.        }
  376.        //        strcpy(clock_buf,times);
  377.        }
  378.        break;
  379.                                                 default:
  380.        break;
  381.                         }
  382. }
  383. void dateTrans(void){
  384.
  385.         times[6]=time_buf[1];
  386.         times[5]=time_buf[7];
  387.
  388.         times[4]=time_buf[2];
  389.         times[3]=time_buf[3];
  390.         times[2]=time_buf[4];
  391.         times[1]=time_buf[5];
  392.         times[0]=time_buf[6];
  393. }
  394. void alarm_aclok(void)
  395.         {
  396.
  397.                 if((times[2]==clock_buf[2])&&(times[1]==clock_buf[1])&&(times[0]==0))        {/*buzeer= 0;*/        music=1;buzeer_music();/*可替換為普通鬧鐘*/}     //1111 0111 P2 & 0xf7
  398.                 //else        {        buzeer= 1;}
  399. }
  400.
  401. void T1_time() interrupt 3 {
  402.                 TH1=0xfc;
  403.                 TL1=0x66;
  404.                 counter++;
  405.         if(counter == 10)                { counter = 0; baifenmiao++;}
  406.         if(baifenmiao == 10)                {baifenmiao = 0; shifenmiao++;}
  407.         if(shifenmiao == 10)                {shifenmiao = 0;led1=~led1; miao++;}
  408.         if(miao == 10)                { miao = 0; shimiao++;}
  409.         if(shimiao == 10)                { shimiao = 0; baimiao++;}
  410.         if(baimiao == 10) baimiao =0;
  411.
  412. }
  413. void timer_run(void)
  414. {
  415.                 if(key==2) keyflg=2;                       //計(jì)時(shí)功能
  416.                 while(key==2)
  417.                                 {
  418.                                                 WriteCommand(0x01); //顯示清屏
  419.                                                 while(keyflg==2){
  420.        key = Key4Scan();
  421.        if(key==4) keyflg=0;
  422.        WriteCommand(0x80+5);            //計(jì)時(shí)功能
  423.        WriteData(shuzi[baimiao]);
  424.        WriteData(shuzi[shimiao]);
  425.        WriteData(shuzi[miao]);
  426.        WriteData('.');
  427.        WriteData(shuzi[shifenmiao]);
  428.        WriteData(shuzi[baifenmiao]);
  429.                                                         if(key==2) TR1=~TR1;
  430.                                                         if(key==3) {shifenmiao=0;baifenmiao=0;baimiao=0;shimiao=0;miao=0;TR0=0;}
  431.                                         }
  432.                                         WriteCommand(0x01); //顯示清屏
  433.                                 }
  434. }
  435. void timer_runback(void){
  436.                 if(key==3) keyflg=3;                       //倒計(jì)時(shí)功能
  437.                 while(key==3)
  438.                         {
  439.                                 WriteCommand(0x01); //顯示清屏
  440.                                 WriteCommand(0x80+5); //顯示清屏   k1 功能選擇 k2 定是數(shù)據(jù)選擇 k3數(shù)據(jù)保存
  441.                                                 WriteData('0');
  442.                                                 WriteData('0');
  443.                                                 WriteData('0');
  444.                                         /*        WriteData(':');
  445.                                                 WriteData('0');
  446.                                                 WriteData('0');*/
  447.                                 while(keyflg==3)
  448.                                         {
  449.                                                 key = Key4Scan();
  450.                                                 if(key==4) keyflg=0;
  451.
  452.                                                 switch(key)   //Key4Scan()
  453.                         {
  454.                                                 case 0x01:
  455.        switch(PPP++)      //??????
  456.        {
  457.        case 0:  WriteCommand(0x80+5);break;                                                //分鐘
  458.        case 1:  WriteCommand(0x80+6);break;            //
  459.        case 2:  WriteCommand(0x80+7);break;                                                //
  460.        /*case 3:  WriteCommand(0x80+9);break;                                //        秒
  461.        case 4:  WriteCommand(0x80+10);break;                                //*/
  462.        default:break;
  463.        }
  464.        WriteCommand(0x0f);//光標(biāo)閃爍
  465.        if(PPP == 4){ PPP = 0; time[0]=time[1]=time[2] =0; }              //7還是 8好像和編譯器有關(guān)系
  466.
  467.        cflg = 1;          //標(biāo)志位
  468.
  469.        break;
  470.                                                 case 0x02:
  471.        if(cflg)
  472.        {
  473.        switch(PPP-1)
  474.        {
  475.        case 0:          // 百秒
  476.        time[0]++;
  477.
  478.        if(time[0] > 9)
  479.        {
  480.        time[0] = 0;
  481.        }
  482.        WriteCommand(0x80+5);
  483.        WriteData(shuzi[time[0]]);
  484.        WriteCommand(0x80+5);
  485.        break;
  486.        case 1:                                 //十秒
  487.        time[1]++;
  488.
  489.        if(time[1] > 9)
  490.        {
  491.        time[1] = 0;
  492.        }
  493.        WriteCommand(0x80+6);
  494.        WriteData(shuzi[time[1]]);
  495.        WriteCommand(0x80+6);
  496.        break;
  497.        case 2:                        //秒
  498.        time[2]++;
  499.        if(time[2] > 9)
  500.        {
  501.        time[2] = 0;
  502.        }
  503.        WriteCommand(0x80+7);
  504.        WriteData(shuzi[time[2]]);;
  505.        WriteCommand(0x80+7);
  506.
  507.        break;
  508.
  509.
  510.        default:
  511.        break;
  512.
  513.        }
  514.        }
  515.        break;
  516.                                                 case 0x03:
  517.        if(cflg)
  518.        {
  519.        cflg = 0;
  520.        PPP = 0;
  521.        WriteCommand(0X0C);   //取消 并關(guān)光標(biāo)
  522.        miao=9-time[2];
  523.        shimiao=9-time[1];
  524.        baimiao=9-time[0];
  525.
  526.        }
  527.        break;
  528.
  529.                                                 /* case 0x05:            //保存數(shù)據(jù)到鬧鐘
  530.        if(cflag)
  531.        {
  532.        cflag = 0;
  533.        PP = 0;
  534.        WriteCommand(0X0C);   //關(guān)光標(biāo)
  535.        }
  536.        break; */
  537.                                                 default:
  538.        break;
  539.                         }
  540.                                 while(!cflg)
  541.                                 {
  542.
  543.                                                 WriteCommand(0X80+5);   //取消 并關(guān)光標(biāo)
  544.                                                 WriteData(shuzi[9-baimiao]);
  545.                                                 WriteData(shuzi[9-shimiao]);
  546.                                                 WriteData(shuzi[9-miao]);
  547.                                                 key = Key4Scan();
  548.                                                 if(key==4){cflg=1; keyflg=0; }
  549.                                                 while((9-baimiao)==0&&(9-shimiao==0)&&(9-miao)==0)
  550.                                                 {
  551.        while(keyflg){
  552.        led3=~led3;
  553.        DelayMs(3500);
  554.        key = Key4Scan();
  555.        WriteCommand(0X80+7);
  556.        WriteData('0');
  557.        if(key==4){cflg=1; keyflg=0; }
  558.        }
  559.                                                 }
  560.                                 }
  561.                                         }
  562.                         WriteCommand(0X01);
  563.                         }
  564. }
  565. void clock_display(void)
  566. {
  567.                 if(key==5)
  568.                 {
  569.                         WriteCommand(0x01);
  570.                         WriteCommand(0x80+5);
  571.                         WriteData(shuzi[clock_buf[2]/16]);
  572.                         WriteData(shuzi[clock_buf[2]%16]);
  573.                         WriteData(':');
  574.                         WriteData(shuzi[clock_buf[1]/16]);
  575.                         WriteData(shuzi[clock_buf[1]%16]);
  576.                         delay_ms(2000);
  577.
  578.
  579.
  580.                 }
  581. }
  582. void clock_delay(void)
  583. {
  584.
  585.                 if(key==6)
  586.                 {
  587.                         miao=0;
  588.                         shimiao=0;
  589.                         TR0=0;
  590.                         buzeer=1;
  591.                 }
  592.         if(keyflg==6)
  593.                         {
  594.                                         if(miao==9)
  595.                                 {
  596.
  597.        //buzeer=0;
  598.                                                         TR0=1;
  599.                                                         buzeer_music();
  600.                                 }
  601.                         }
  602. }
  603. void start(void)
  604. {
  605.
  606.
  607.                 WriteCommand(0x80+3);
  608.
  609.           WriteData('3');
  610.                 WriteData('-');
  611.           WriteData('0');
  612.                 WriteData('5');
  613.                 WriteData('-');
  614.                 WriteData('0');
  615.                 WriteData('6');
  616.
  617.           led2=1;
  618.                 delay_ms(1000);
  619. ……………………
  620. …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
RTC實(shí)時(shí)時(shí)鐘DS1302液晶顯示.rar (96.15 KB, 下載次數(shù): 24)
