* For GPS Walkie Talkie 821
* (c) Copyright 2010, suoyin
* All Rights Reserved
* File : SAUitoplayer.c
* History:
* 08/06/2010 Created by liufang
#define TARGET_IS_TEMPEST_RB1
#define ewarm
#include "SAInclude.h"
//-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-cut-off rule-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-
//內(nèi)部宏定義
//函數(shù)內(nèi)部部調(diào)用聲明
//void
//函數(shù)內(nèi)部部變量聲明
// 定義CAT9555(I2C接口)
#define CAT9555_SLA (0x40>>1) //定義CAT9555的器件地址
#define CAT9555_INPUT0 0//CAT9555輸入端口寄存器0
#define CAT9555_INPUT1 1//CAT9555輸入端口寄存器1
#define CAT9555_OUTPUT0 2//CAT9555輸出端口寄存器0
#define CAT9555_OUTPUT1 3//CAT9555輸出端口寄存器1
#define CAT9555_PI0 4//CAT9555反轉(zhuǎn)寄存器0
#define CAT9555_PI1 5//CAT9555反轉(zhuǎn)寄存器1
#define CAT9555_CFG0 6//CAT9555配置寄存器0
#define CAT9555_CFG1 7//CAT9555配置寄存器1
tI2CM_DEVICE CAT9555 = {CAT9555_SLA, 0x00, 0x01, (void *)0, 0x00};
unsigned char gucPort1Status;
//描 述:寫寄存器 函數(shù)
//功 能:寫寄存器
//形 參:unsigned char ucAddr:CAT9555_OUTPUT0
// CAT9555_OUTPUT1
// CAT9555_CFG0
// CAT9555_CFG1
// unsigned char ucData:8bit data
//返 回:ulStatus 返回可能的錯誤狀態(tài)
unsigned char CAT9555MWriteReg(unsigned char ucAddr, unsigned char ucData0,unsigned char ucData1)
unsigned char ucDataTemp[2];
unsigned long ulStatus = 0;
ucDataTemp[0] = ucData0;//port0 data
ucDataTemp[1] = ucData1;//port1 data
I2CM_DeviceDataSet(&CAT9555,ucAddr,ucDataTemp, 2);
ulStatus = I2CM_DataSend(&CAT9555);
return ulStatus;
//描 述:CAT9555初始化函數(shù)
//功 能:配置CAT9555,包括16個I/O口的初始化 input:1 output:0
//形 參:無
//返 回:無
void CAT9555Init(void)
gucPort1Status = 0;
CAT9555MWriteReg(CAT9555_CFG0, 0x00,0x00);//P0.0~P0.7,P1.0~P1.7為輸出腳
CAT9555MWriteReg(CAT9555_OUTPUT0, gucPort1Status,gucPort1Status);//P0.0~P0.7,P1.0~P1.7輸出0
//描 述:電源控制函數(shù)
//功 能:電源控制輸出端口
//形 參:tBoolean tFlag:1:寫高電平 0:寫低電平
//返 回:無
unsigned char CAT9555PwrCtrl(tBoolean tFlag)
if (tFlag)
gucPort1Status = (gucPort1Status | 0x80);//P1.7
gucPort1Status = (gucPort1Status & 0x7f);//P1.7
ulStatus = CAT9555MWriteReg(CAT9555_OUTPUT0, gucPort1Status,gucPort1Status);//P1.0~P1.7為輸出腳
return ulStatus;
//描 述:按鍵音控制函數(shù)
//功 能:按鍵音控制輸出端口
//返 回:無
unsigned char CAT9555BeepCtrl(tBoolean tFlag)
if (tFlag)
gucPort1Status = (gucPort1Status | 0x40);//P1.6
gucPort1Status = (gucPort1Status & 0xbf);//P1.6
return ulStatus;
//描 述:LCD控制函數(shù)
//功 能:LCD控制輸出端口
//返 回:無
unsigned char CAT9555LCDCtrl(tBoolean tFlag)
if (tFlag)
gucPort1Status = (gucPort1Status | 0x20);//P1.5
gucPort1Status = (gucPort1Status & 0xdf);//P1.5
return ulStatus;
//描 述:GPS控制函數(shù)
//功 能:GPS控制輸出端口
//返 回:無
unsigned char CAT9555GPSCtrl(tBoolean tFlag)
if (tFlag)
gucPort1Status = (gucPort1Status | 0x10);//P1.4
gucPort1Status = (gucPort1Status & 0xef);//P1.4
return ulStatus;
//描 述:voice pa控制函數(shù)
//功 能:voice pa控制輸出端口
//返 回:無
unsigned char CAT9555VoicePaCtrl(tBoolean tFlag)
if (tFlag)
gucPort1Status = (gucPort1Status | 0x08);//P1.3
gucPort1Status = (gucPort1Status & 0xf7);//P1.3
return ulStatus;
//描 述:PWM控制函數(shù)
//功 能:PWM控制輸出端口
//返 回:無
unsigned char CAT9555PWMCtrl(tBoolean tFlag)
if (tFlag)
gucPort1Status = (gucPort1Status | 0x04);//P1.2
gucPort1Status = (gucPort1Status & 0xfb);//P1.2
return ulStatus;
//描 述:對講機發(fā)送控制函數(shù)
//功 能:對講機發(fā)送控制腳TX
//返 回:無
unsigned char CA9555WalTalTxCtrl(tBoolean tFlag)
if (tFlag)
gucPort1Status = (gucPort1Status | 0x02);//P1.1
gucPort1Status = (gucPort1Status & 0xfd);//P1.1
return ulStatus;
//描 述:對講機接收控制函數(shù)
//功 能:對講機接收控制腳RX
//返 回:無
unsigned char CA9555WalTalRxCtrl(tBoolean tFlag)
if (tFlag)
gucPort1Status = (gucPort1Status | 0x01);//P1.0
gucPort1Status = (gucPort1Status & 0xfe);//P1.0
return ulStatus;
