查看: 1598|回復(fù): 0
ARM上LED控制程序
ID:201115 發(fā)表于 2017-5-15 21:09 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
Header File Inclusion
#include <stdio.h>
#include <stdlib.h>
#include <stdbool.h>
#include <string.h>
#include <signal.h>
#include <unistd.h>
#include <errno.h>
Macros
SH_USR_LED_CNT  : shell commnad for counting user led devices
SH_USR_LED_DEV  : shell command for retrieving user led devices' name
#define SH_USR_LED_CNT "find /sys/class/leds/*/ | grep trigger |    \
                        xargs grep \'\\[default-on\\]\' | wc -l"
#define SH_USR_LED_DEV "find /sys/class/leds/*/ | grep trigger |    \
                        xargs grep \'\\[default-on\\]\' |           \
                        awk -F \'/\' '{printf $5\"\\n\" }\'"
#define LEN_NAME    48
#define LEN_CMD    128
#define MAX_COUNT   10
/* quit signal tag */
volatile bool quit = false;
/*=====================restore_devices==================*/
/* set all led devices as [default on] state            */
static int restore_devices(char names[][LEN_NAME], int count) {
    int i;
    char cmd[MAX_COUNT][LEN_CMD];
    for (i = 0; i < count; i++) {
        snprintf(cmd[i], LEN_CMD,
                "echo default-on > /sys/class/leds/%s/trigger", names[i]);
        if (system(cmd[i]) != 0) {
            fprintf(stderr, "fail to restore devices\n");
            return -1;
    return 0;
/*=====================turn_off==========================*/
/* turn off all led devices                              */
static int turn_off(char names[][LEN_NAME], int count) {
    int i;
                "echo 0 > /sys/class/leds/%s/brightness", names[i]);
            fprintf(stderr, "fail to turn off %s\n", names[i]);
            return -1;
    return 0;
/*=====================turn_on===========================*/
/* turn on all led devices                               */
static int turn_on(char names[][LEN_NAME], int count) {
    int i;
                "echo 1 > /sys/class/leds/%s/brightness", names[i]);
            fprintf(stderr, "fail to turn on %s\n", names[i]);
            return -1;
    return 0;
/*=====================show_devices======================*/
/* show all led devices                                  */
static void show_devices(char names[][LEN_NAME], int count) {
    int i;
    printf("twinkle %d leds\n", count);
        printf("%d. /sys/class/leds/%s\n", i + 1, names[i]);
/*=====================get_devices_names======================*/
/* retrieve user led devices' name                            */
static int get_devices_names(char names[][LEN_NAME], int count) {
    int i;
    FILE *f;
    /* the popen() function opens a process by creating
     * a pipe, forking, and invoking the shell */
    f = popen(SH_USR_LED_DEV, "r");
    if (! f)
        goto err;
        if (fscanf(f, "%s", names[i]) == EOF)
            goto err;
    pclose(f);
    return 0;
err:
    fprintf(stderr, "something error, maybe there's no led device\n");
    if (f)
        pclose(f);
    return -1;
/*=================get_devices_count==================*/
/* retrieve the amount of user led devices            */
static int get_devices_count(int *count) {
    FILE *f;
    f = popen(SH_USR_LED_CNT, "r");
    if (! f)
        goto err;
    if(fscanf(f, "%d", count) == EOF)
        goto err;
    if (*count == 0) {
        printf("warning: there's no led device\n");
        return -2;
    if (*count > MAX_COUNT) {
        *count = MAX_COUNT;
        printf("warning: max numbuer of leds is %d, dope tail\n", MAX_COUNT);
    pclose(f);
    return 0;
err:
    if (f)
        pclose(f);
    return -1;
/*=====================sig_handle======================*/
/* response to ctrl+c                                  */
static void sig_handle(int signo) {
    quit = true;
/*==============================main===============================*/
/* this program twinkle the leds which set as [defualt on] during  */
/* the time of kernel booting. you can check it by bellow command: */
/* $ cat /sys/class/leds/${device_name}/trigger                    */
int main(int argc, char **argv) {
    int i;
    int count;
    char names[MAX_COUNT][LEN_NAME];
    /* ctrl+c handler */
    signal(SIGINT, sig_handle);
    if (get_devices_count(&count) < 0)
        return -1;
    if (get_devices_names(names, count) < 0)
        return -1;
    show_devices(names, count);
    /* twinkle
     * 1. turn on all leds
     * 2. sleep 0.5 s
     * 3. tunn off all leds
     * 4. goto 1
    for (i = 0; i < 10; i++) {
        /* set as true while ctrl+c */
        if (quit)
            break;
        if (turn_on(names, count) < 0)
            break;
        usleep(500 * 1000);
        if (turn_off(names, count) < 0)
            break;
    restore_devices(names, count);
    return 0;
