查看: 3424|回復(fù): 1
求大神看下STC12C5A60S2單片機串口程序
ID:114987 發(fā)表于 2017-5-19 14:46 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
編譯之后的提示
Build target 'Target 1'
linking...
Program Size: data=117.0 xdata=121 code=1707
creating hex file from "gps2"...
"gps2" - 0 Error(s), 0 Warning(s).
我想知道為什么在串口助手里連我標(biāo)紅的那兩行串口測試的兩串字符也不顯示
  1. #include<STC12C5A60S2.h>
  2. #include <stdio.h>
  3. #include <stdlib.h>
  4. #include <string.h>
  5. #define false 0
  6. #define true 1
  7. //定義數(shù)組長度
  8. #define GPS_Buffer_Length 80
  9. #define UTCTime_Length 11
  10. #define latitude_Length 11
  11. #define N_S_Length 2
  12. #define longitude_Length 12
  13. #define E_W_Length 2
  14. #define gpsRxBufferLength  76
  15. char idata gpsRxBuffer[gpsRxBufferLength];
  16. unsigned char RX_Count;
  17. //函數(shù)或者變量聲明
  18. void Delay_ms(unsigned int n);
  19. void printGpsBuffer();
  20. void parseGpsBuffer();
  21. void errorLog(int num);
  22. void Uart_Init();
  23. void UartPrintf(unsigned char *p);
  24. void UartPrintASCII(unsigned char c);
  25. void Uart_Init();
  26. void UartPrintf(unsigned char *p);
  27. void UartPrintASCII(unsigned char c);
  28. extern void clrStruct();
  29. struct SaveData
  30. {
  31.         char GPS_Buffer[GPS_Buffer_Length];
  32.         char isGetData;                //是否獲取到GPS數(shù)據(jù)
  33.         char isParseData;        //是否解析完成
  34.         char UTCTime[UTCTime_Length];                //UTC時間
  35.         char latitude[latitude_Length];                //緯度
  36.         char N_S[N_S_Length];                //N/S
  37.         char longitude[longitude_Length];                //經(jīng)度
  38.         char E_W[E_W_Length];                //E/W
  39.         char isUsefull;                //定位信息是否有效
  40. } xdata Save_Data;
  41. #define gpsRxBufferLength  76
  42. char idata gpsRxBuffer[gpsRxBufferLength];
  43. unsigned char RX_Count=0;
  44. void main()
  45. {
  46.         unsigned char i = 0;
  47.         Uart_Init();
  48.         Delay_ms(10);
  49.         [color=#ff0000]UartPrintf("Welcome to use!");                                             //測試串口是正確[/color]
  50. [color=#ff0000]        UartPrintf("ILoveMCU.taobao.com");[/color]
  51.         clrStruct();        //清空緩存數(shù)組
  52.         while(1)
  53.         {
  54.                 parseGpsBuffer();
  55.                 printGpsBuffer();
  56.         }
  57. }
  58. void Uart_Init()
  59. {
  60.         SCON = 0X50;  //UART方式1;8位UART
  61.         REN  = 1;     //允許串行口接收數(shù)據(jù)
  62.         PCON = 0x00;  //SMOD=0;波特率不加倍
  63.         TMOD = 0x20;  //T1方式2,用于產(chǎn)生波特率
  64.         TH1  = 0xFD;  //裝初值
  65.         TL1  = 0xFD;
  66.         TR1  = 1;     //啟動定時器1
  67.         EA   = 1;     //打開全局中斷控制
  68.         ES   = 1;     //打開串行口中斷
  69. }
  70. void UartPrintf(unsigned char *p)                                //發(fā)送字符串
  71. {
  72.          while(*p)
  73.          {
  74.                  SBUF=*(p++);
  75.                 while(TI==0)
  76.                 {
  77.                 };
  78.                 TI=0;
  79.         }
  80. }
  81. void UartPrintASCII(unsigned char c)                                //發(fā)送一個字符
  82. {
  83.     TI=0;
  84.     SBUF=c;
  85.     while(TI==0);
  86.     TI=0;
  87. }
  88. void RECEIVE_DATA(void) interrupt 4 using 3
  89. {
  90.         unsigned char temp = 0;
  91.         char i = 0;
  92.         ES=0;
  93.         temp = SBUF;
  94.         RI = 0;
  95.
  96.         if(temp == ')
  97.         {
  98.                 RX_Count = 0;
  99.         }
  100.
  101.         if(RX_Count <= 5)
  102.         {
  103.            gpsRxBuffer[RX_Count++] = temp;
  104.         }
  105.         else if(gpsRxBuffer[0] == ' &gpsRxBuffer[4] == 'M' && gpsRxBuffer[5] == 'C')                        //確定是否收到"GPRMC/GNRMC"這一幀數(shù)據(jù)
  106.         {
  107.                 gpsRxBuffer[RX_Count++] = temp;
  108.                 if(temp == '\n')
  109.                 {
  110.                         memset(Save_Data.GPS_Buffer, 0, GPS_Buffer_Length);      //清空
  111.                         memcpy(Save_Data.GPS_Buffer, gpsRxBuffer, RX_Count);         //保存數(shù)據(jù)
  112.                         Save_Data.isGetData = true;
  113.                         RX_Count = 0;
  114.                         memset(gpsRxBuffer, 0, gpsRxBufferLength);      //清空
  115.                 }
  116.
  117.                 if(RX_Count >= 75)
  118.                 {
  119.                         RX_Count = 75;
  120.                         gpsRxBuffer[RX_Count] = '\0';//添加結(jié)束符
  121.                 }
  122.         }
  123.         ES=1;
  124. }
  125. void clrStruct()
  126. {
  127.         Save_Data.isGetData = false;
  128.         Save_Data.isParseData = false;
  129.         Save_Data.isUsefull = false;
  130.         memset(Save_Data.GPS_Buffer, 0, GPS_Buffer_Length);      //清空
  131.         memset(Save_Data.UTCTime, 0, UTCTime_Length);
  132.         memset(Save_Data.latitude, 0, latitude_Length);
  133.         memset(Save_Data.N_S, 0, N_S_Length);
  134.         memset(Save_Data.longitude, 0, longitude_Length);
  135.         memset(Save_Data.E_W, 0, E_W_Length);
  136.
  137. }
  138. void errorLog(int num)
  139. {
  140.
  141.         while (1)
  142.         {
  143.                   UartPrintf("ERROR");
  144.                 UartPrintASCII(num+0x30);
  145.                 UartPrintf("\r\n");
  146.         }
  147. }
  148. void parseGpsBuffer()
  149. {
  150.         char *subString;
  151.         char *subStringNext;
  152.         char i = 0;
  153.         if (Save_Data.isGetData)
  154.         {
  155.                 Save_Data.isGetData = false;
  156.                 UartPrintf("**************\r\n");
  157.                 UartPrintf(Save_Data.GPS_Buffer);
  158.
  159.                 for (i = 0 ; i <= 6 ; i++)
  160.                 {
  161.                         if (i == 0)
  162.                         {
  163.                                 if ((subString = strstr(Save_Data.GPS_Buffer, ",")) == NULL)
  164.                                         errorLog(1);        //解析錯誤
  165.                         }
  166.                         else
  167.                         {
  168.                                 subString++;
  169.                                 if ((subStringNext = strstr(subString, ",")) != NULL)
  170.                                 {
  171.                                         char usefullBuffer[2];
  172.                                         switch(i)
  173.                                         {
  174.                                                 case 1:memcpy(Save_Data.UTCTime, subString, subStringNext - subString);break;        //獲取UTC時間
  175.                                                 case 2:memcpy(usefullBuffer, subString, subStringNext - subString);break;        //獲取UTC時間
  176.                                                 case 3:memcpy(Save_Data.latitude, subString, subStringNext - subString);break;        //獲取緯度信息
  177.                                                 case 4:memcpy(Save_Data.N_S, subString, subStringNext - subString);break;        //獲取N/S
  178.                                                 case 5:memcpy(Save_Data.longitude, subString, subStringNext - subString);break;        //獲取經(jīng)度信息
  179.                                                 case 6:memcpy(Save_Data.E_W, subString, subStringNext - subString);break;        //獲取E/W
  180.                                                 default:break;
  181.                                         }
  182.                                         subString = subStringNext;
  183.                                         Save_Data.isParseData = true;
  184.                                         if(usefullBuffer[0] == 'A')
  185.                                                 Save_Data.isUsefull = true;
  186.                                         else if(usefullBuffer[0] == 'V')
  187.                                                 Save_Data.isUsefull = false;
  188.                                 }
  189.                                 else
  190.                                 {
  191.                                         errorLog(2);        //解析錯誤
  192.                                 }
  193.                         }
  194.                 }
  195.         }
  196. }
  197. void printGpsBuffer()
  198. {
  199.         if (Save_Data.isParseData)
  200.         {
  201.                 Save_Data.isParseData = false;
  202.
  203.                 UartPrintf("Save_Data.UTCTime = ");
  204.                 UartPrintf(Save_Data.UTCTime);
  205.                 UartPrintf("\r\n");
  206.                 if(Save_Data.isUsefull)
  207.                 {
  208.                         Save_Data.isUsefull = false;
  209.                         UartPrintf("Save_Data.latitude = ");
  210.                         UartPrintf(Save_Data.latitude);
  211.                         UartPrintf("\r\n");
  212.                         UartPrintf("Save_Data.N_S = ");
  213.                         UartPrintf(Save_Data.N_S);
  214.                         UartPrintf("\r\n");
  215.                         UartPrintf("Save_Data.longitude = ");
  216.                         UartPrintf(Save_Data.longitude);
  217.                         UartPrintf("\r\n");
  218.                         UartPrintf("Save_Data.E_W = ");
  219.                         UartPrintf(Save_Data.E_W);
  220.                         UartPrintf("\r\n");
  221.                 }
  222.                 else
  223.                 {
  224.                         UartPrintf("GPS DATA is not usefull!\r\n");
  225.                 }
  226.
  227.         }
  228. }
  229. //****************************************************
  230. //MS延時函數(shù)
  231. //****************************************************
  232. void Delay_ms(unsigned int n)
  233. {
  234.         unsigned int  i,j;
  235.         for(i=0;i<n;i++)
  236.                 for(j=0;j<123;j++);
  237. }
ID:76181 發(fā)表于 2018-6-15 22:40 | 只看該作者
SUBF被占用了,沒清空
