#include <reg52.h>
*自定義數據類型
typedef unsigned char uchar;
typedef unsigned int uint;
#define LCD1602_DB P0 //LCD1602數據總線
sbit LCD1602_RS = P3^5; //RS端
sbit LCD1602_RW = P3^6; //RW端
sbit LCD1602_EN = P3^4; //EN端
sbit DU = P2^6;//
sbit WE = P2^7;//數碼管位選段選用于關閉數碼管顯示
*函數名稱:Read_Busy
*函數功能:判斷1602液晶忙,并等待
void Read_Busy()
uchar busy;
LCD1602_DB = 0xff;//復位數據總線
LCD1602_RS = 0; //拉低RS
LCD1602_RW = 1; //拉高RW讀
do
LCD1602_EN = 1;//使能EN
busy = LCD1602_DB;//讀回數據
LCD1602_EN = 0; //拉低使能以便于下一次產生上升沿
}while(busy & 0x80); //判斷狀態(tài)字BIT7位是否為1,為1則表示忙,程序等待
*函數名稱:LCD1602_Write_Cmd
*函數功能:寫LCD1602命令
*調用:Read_Busy();
*輸入:cmd:要寫的命令
void LCD1602_Write_Cmd(uchar cmd)
Read_Busy(); //判斷忙,忙則等待
LCD1602_RS = 0;
LCD1602_RW = 0; //拉低RS、RW操作時序情況1602課件下中文使用說明基本操作時序章節(jié)
LCD1602_DB = cmd;//寫入命令
LCD1602_EN = 1; //拉高使能端 數據被傳輸到LCD1602內
*函數名稱:LCD1602_Write_Dat
*函數功能:寫LCD1602數據
*調用:Read_Busy();
*輸入:dat:需要寫入的數據
void LCD1602_Write_Dat(uchar dat)
Read_Busy();
LCD1602_RS = 1;
LCD1602_RW = 0;
LCD1602_DB = dat;
LCD1602_EN = 1;
LCD1602_EN = 0;
*函數名稱:LCD1602_Dis_OneChar
*函數功能:在指定位置顯示 *一個* 字符
*調用:LCD1602_Write_Cmd(); LCD1602_Write_Dat();
*輸入:x:要顯示的橫坐標取值0-40,y:要顯示的行坐標取值0-1(0為第一行,1為第二行)
dat:需要顯示的數據以ASCLL形式顯示
void LCD1602_Dis_OneChar(uchar x, uchar y,uchar dat)
if(y) x |= 0x40;//第二行時
x |= 0x80;
LCD1602_Write_Cmd(x);
LCD1602_Write_Dat(dat);
*函數名稱:LCD1602_Dis_Str
*函數功能:在指定位置顯示字符串
*str:需要顯示的字符串
void LCD1602_Dis_Str(uchar x, uchar y, uchar *str)
if(y) x |= 0x40;
x |= 0x80;
while(*str != '\0')
LCD1602_Write_Dat(*str++);
*函數名稱:Init_LCD1602
*函數功能:1602初始化
*調用: LCD1602_Write_Cmd();
void Init_LCD1602()
LCD1602_Write_Cmd(0x38); // 設置16*2顯示,5*7點陣,8位數據接口
LCD1602_Write_Cmd(0x0c); //開顯示
LCD1602_Write_Cmd(0x06); //讀寫一字節(jié)后地址指針加1
LCD1602_Write_Cmd(0x01); //清除顯示
uchar TestStr[] = {"Welcome!"};//字符串數組
DU = 0;
WE = 0;//關閉數碼管顯示
Init_LCD1602();//1602初始化
LCD1602_Dis_Str(0, 0, &TestStr[0]); //顯示字符串
LCD1602_Dis_OneChar(10, 1, 0xff); //(1,10)后顯示一個黑方格
while(1);
