給你個(gè)數(shù)碼管的測速程序:
#include<reg52.h>
#include<stdio.h>
#include <intrins.h>
#define THC0 0xf8 //0xf9
#define TLC0 0x30 //2ms //0x0f
unsigned char code Duan[]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90};//共陽極數(shù)碼管,0-9段碼表
unsigned char Data_Buffer[8]={0,0,0,0,0,0,0,0}; //轉(zhuǎn)速及定值顯示緩存
uchar i=0,n,Bit;
sbit led1=P2^0; //轉(zhuǎn)速千位顯數(shù)碼管位驅(qū)動(dòng)端口
sbit led2=P2^2; //轉(zhuǎn)速百位顯數(shù)碼管位驅(qū)動(dòng)端口
sbit led3=P2^4; //轉(zhuǎn)速個(gè)位顯數(shù)碼管位驅(qū)動(dòng)端口
sbit led4=P2^6; //轉(zhuǎn)速十位顯數(shù)碼管位驅(qū)動(dòng)端口
static uchar bdata ke; //可位尋址的狀態(tài)寄存器
sbit aj=ke^0; //按鍵處理標(biāo)志位
sbit k1=P3^3; //功能按鍵
sbit k2=P3^4; //定值加按鍵
sbit k3=P3^5; //定值加按鍵
sbit PWM_FC=P2^7; //PWM調(diào)速輸出端
uchar T0_H = 0,T0_L = 0,T1_H=0,T1_L=0; //用來裝計(jì)算出的初值
uchar flag=1;// pwm輸出標(biāo)志,0為輸出低電平,1為輸出高電平
int out=0;
uint Inpluse=0,num=0; //脈沖計(jì)數(shù)
uint PWMTime=100; //脈沖寬度
unsigned char arry[];
void SendString(uint ch);
void PIDControl();
void SystemInit();
void PWMOUT();
void SetSpeed();
void SegRefre();
void delay(i); //延時(shí)函數(shù)
/**************主函數(shù)************/
SystemInit(); //單片機(jī)初始化
SetSpeed(); //按鍵處理程序
SegRefre(); //顯示處理
void SystemInit()
TMOD=0X11; //t0,t1為16位
TH0=THC0;
TL0=TLC0;
T0_H = (65535-300)/256; //PWM=1時(shí)給定高位初值
T0_L = (65535-300)%256; //PWM=1時(shí)給定低位初值
T1_H = (65535-(1000-300))/256; //PWM=0時(shí)給定高位初值
T1_L = (65535-(1000-300))%256; //PWM=0時(shí)給定低位初值
ET1=1;
ET0=1;
TR0=1;
TR1=1;
EX0=1; //中斷0用來測量轉(zhuǎn)速
IT0=1;
EA=1;
out=300; //開總中斷
// n=30;
void SetSpeed()
if (k2==0) //增加轉(zhuǎn)速定值按鍵按下時(shí),每次增加定值100轉(zhuǎn)/分
while(!k2); //再次進(jìn)行按鍵按下判斷
delay(40); //延時(shí)
out+=50; //增加定值100轉(zhuǎn)/分
if(out>1000) //定值最大值為9900轉(zhuǎn)/分
out=1000; //定值=9900轉(zhuǎn)/分
T0_H = (65535-out)/256; //PWM=1高位初值計(jì)算
T0_L = (65535-out)%256; //PWM=1低位初值計(jì)算
T1_H = (65535-(1000-out))/256; //PWM=0高位初值計(jì)算
T1_L = (65535-(1000-out))%256; //PWM=0低位初值計(jì)算
if (k3==0) //減小轉(zhuǎn)速定值按鍵按下時(shí),每次增減定值100轉(zhuǎn)/分
while(!k3); //再次進(jìn)行按鍵按下判斷
out-=50; //減小定值100轉(zhuǎn)/分
if(out<100) //定值最小值為200轉(zhuǎn)/分
out=100; //定值=200轉(zhuǎn)/分
SegRefre(); //顯示刷新
void SegRefre() //顯示刷新
Data_Buffer[0]=num/1000; //轉(zhuǎn)速千位顯示轉(zhuǎn)換處理
Data_Buffer[1]=num%1000/100; //轉(zhuǎn)速百位顯示轉(zhuǎn)換處理
Data_Buffer[2]=num%100/10; //轉(zhuǎn)速十位顯示轉(zhuǎn)換處理
Data_Buffer[3]=num%10; //轉(zhuǎn)速個(gè)位顯示轉(zhuǎn)換處理
void int0() interrupt 0 //進(jìn)行轉(zhuǎn)速脈沖計(jì)數(shù)外部中斷處理
Inpluse++; //轉(zhuǎn)速脈沖加1
void t0() interrupt 1 //2毫秒中斷一次
static unsigned int time=0;
TH0=THC0;
TL0=TLC0;
time++; //轉(zhuǎn)速測量周期
if(time>250) //0.5秒獲取一次轉(zhuǎn)速數(shù)據(jù),進(jìn)行一次PID處理。
time=0;
num=Inpluse*2; //碼盤數(shù)n num=Inpluse*60/n
Inpluse=0;
led1=1; //停止顯示
led2=1; //停止顯示
led3=1; //停止顯示
led4=1; //停止顯示
Bit++;
if(Bit>4) Bit=0;
P0=Duan[Data_Buffer[Bit]]; //獲取顯示數(shù)據(jù)段碼
switch(Bit)
case 0:led1=0;break; //數(shù)碼管千位顯示
case 1:led2=0;break; //數(shù)碼管百位顯示
case 2:led3=0;break; //數(shù)碼管十位顯示
case 3:led4=0;break; //數(shù)碼管個(gè)位顯示
void timer_1() interrupt 3 //PWM調(diào)速中斷處理程序
if(flag)
TH1 = T0_H; //通的初值高位
TL1 = T0_L; //通的初值低位
PWM_FC= 1; //PWM輸出=1
flag= 0;
TH1 = T1_H; //斷的初值高位
TL1 = T1_L; //斷的初值低位
PWM_FC= 0; //PWM輸出=0
flag= 1;
void delay(i) //延時(shí)函數(shù)
while(--i);
