查看: 6982|回復(fù): 1
LDPC編碼學(xué)習(xí) Matlab程序
ID:204662 發(fā)表于 2017-5-25 11:39 | 顯示全部樓層 |閱讀模式
LDPC非常好用的工具。
Matlab程序源程序如下:
  1. %--------------------------------------------------------------------------
  2. %-----Chamitha-de-Alwis----------------------------------------------------
  3. %-----University-of-Surrey-------------------------------------------------
  4. %-----chamithadealwis@hotmail.com------------------------------------------
  5. %--------------------------------------------------------------------------
  6. clear
  7. clc
  8. clear
  9. %--------------------------------------------------------------------------
  10. %-----Set-Simulation-Parameters--------------------------------------------
  11. %--------------------------------------------------------------------------
  12. snrs = [10 13 15];      %SNR values
  13. codeRate = 9/10; %Possible values for codeRate are 1/4, 1/3, 2/5, 1/2, 3/5, 2/3, 3/4, 4/5, 5/6, 8/9, and 9/10. The block length of the code is 64800
  14. mod_order = 4;  %PSK Modulation Order
  15. frames = 2500;  %Number of frames (fame size is 64800 bits) to be simulated
  16. %--------------------------------------------------------------------------
  17. rounds = size(snrs,2);
  18. messageLength = round(64800*codeRate);
  19. for run = 1:1:rounds
  20. framepattern = [];
  21.
  22. snrvalue = snrs(run);
  23. H = dvbs2ldpc(codeRate);
  24. %spy(H);   % Visualize the location of nonzero elements in H.
  25. errors = 0;
  26. hEnc = comm.LDPCEncoder(H);
  27. hMod = comm.PSKModulator(mod_order, 'BitInput',true);
  28. hChan = comm.MIMOChannel('MaximumDopplerShift', 0, 'NumTransmitAntennas',1,'NumReceiveAntennas',1, 'TransmitCorrelationMatrix', 1, 'ReceiveCorrelationMatrix', 1, 'PathGainsOutputPort', true);
  29. hAWGN = comm.AWGNChannel('NoiseMethod','Signal to noise ratio (SNR)','SNR',snrvalue);
  30. % hDemod = comm.PSKDemodulator(4, 'BitOutput',true,'DecisionMethod','Approximate log-likelihood ratio',...
  31. %                              'Variance', 1/10^(hChan.SNR/10));
  32. hDemod = comm.PSKDemodulator(4, 'BitOutput',true,'DecisionMethod','Approximate log-likelihood ratio');
  33. hDec = comm.LDPCDecoder(H,'DecisionMethod', 'Soft decision');
  34. %hError = comm.ErrorRate;
  35. for counter = 1:frames
  36.     receiveddataBits = [];
  37.     data           = logical(randi([0 1], messageLength, 1));
  38. %    data = randi([0 hMod.ModulationOrder-1], messageLength, 1);
  39.     encodedData    = step(hEnc, data);
  40.
  41.
  42.     modSignal      = step(hMod, encodedData);
  43.
  44.
  45.     % Transmit through Rayleigh and AWGN channels
  46.     [chanOut, pathGains] = step(hChan, modSignal);
  47.     receivedSignal = step(hAWGN, chanOut);
  48.     demodSignal    = step(hDemod, receivedSignal);
  49.     receivedBits   = step(hDec, demodSignal);
  50.     %errorStats     = step(hError, data, receivedBits);
  51.
  52.     for i=1:1:messageLength
  53.         if receivedBits(i,1) >= 0
  54.             receiveddataBit = 0;
  55.         else
  56.             receiveddataBit = 1;
  57.         end
  58.         receiveddataBits = [receiveddataBits; receiveddataBit];
  59.     end
  60.
  61.     newErrors = nnz(receiveddataBits-data);
  62.     errors = errors + newErrors;
  63.     if newErrors == 0
  64.         addFramepattern = 1;
  65.     else
  66.         addFramepattern = 0;
  67.     end
  68.     framepattern = [framepattern addFramepattern];
  69.
  70.     clc
  71.     run
  72.     counter
  73.     errors
  74.     code_errors = (size(framepattern,2) - nnz(framepattern));
  75.     code_errors
  76. end
  77. SumErrors(run) = errors;
  78. ……………………
  79. …………限于本文篇幅 余下代碼請從51黑下載附件…………
LDPC_AWGN.zip (2.17 KB, 下載次數(shù): 32)
admin + 50 共享資料的黑幣獎勵!
ID:345094 發(fā)表于 2018-6-5 01:06 | 顯示全部樓層
誤碼率信噪比曲線出來結(jié)果不正確為什么?
