查看: 2012|回復(fù): 1
【1602液晶顯示問題】
ID:204212 發(fā)表于 2017-5-29 11:15 | 只看該作者 回帖獎勵 |倒序?yàn)g覽 |閱讀模式
我想通過鍵盤來切換lcd的顯示界面(共四個(gè)界面),我覺得思路沒問題,可是就是實(shí)現(xiàn)不了,下面是代碼
    LcdInit();
        //key_return=Keyscan();
        Operation(Keyscan());
        Show(interface);
void T0Init()
/*void T0() interrupt 1
void Operation(uchar key)//界面切換
    switch(interface)
        case 1:if(key==10)
                    interface=2;
                    //運(yùn)行界面,啟動定時(shí)器,同時(shí)切換界面
                if(key==12)
                    interface=3;//設(shè)置界面
                if(key==16)
                    interface=1;
                break;
        case 2:if(key==13)
                    interface=4;//查詢界面
                else if(key==11)
                    //TR0=0;
                    interface=1;
                else if(key==12)
                    //TR0=0;
                    interface=3;
                break;
          case 3:if(key==10)
                    //TR0=1;
                    interface=2;
                else if(key==11)
                    //TR0=0;
                    interface=1;
                break;
           case 4:if(key==11)
                    interface=2;
void Show(uchar n)
    switch(n)
        case 1:Interface_start();
               break;
        case 2:Interface_run();
               break;
        case 3:Interface_set();
               break;
        case 4:Interface_find();
               break;
void refresh_date(uchar address,uchar date)
    Write_cmd(0x80+address);
    Write_data(date);
void Interface_start()//打開電源顯示界面
    //Write_cmd(0x01);
    Write_cmd(0x80);
    for(num=0;num<16;num++)
        Write_data(table[num]);
        delay(20);
    Write_cmd(0x80+0x40);//第二行顯示
        Write_data(table1[num]);
        delay(20);
    Write_cmd(0x80+0x50);
    Write_cmd(0x0c);//開顯示,不顯示光標(biāo),不閃爍
void Interface_run()//運(yùn)行界面
    LcdInit();
        Write_data(table3[num]);
        delay(20);
        Write_data(table2[num]);
        delay(20);
void Interface_set()//設(shè)置界面
     Write_cmd(0x80+5);
     Write_cmd(0x0f);
void Interface_find()//查詢界面
    refresh_date(0x40+5,table2[5]);
    refresh_date(0x40+6,table2[6]);
    refresh_date(0x40+7,table2[7]);
    refresh_date(0x40+8,table2[8]);
    refresh_date(0x40+9,table2[9]);
    refresh_date(0x40+10,table2[10]);
    refresh_date(0x40+11,table2[11]);
void LcdInit()
    wela=0;//lcd和數(shù)碼管共用P0
    dula=0;//防止數(shù)碼管干擾
    lcd_en=0;
    Write_cmd(0x38);//設(shè)置16*2顯示,5*7點(diǎn)陣,8位數(shù)據(jù)口
    Write_cmd(0x0f);//開顯示,顯示光標(biāo),光標(biāo)閃爍
    Write_cmd(0x06);
    Write_cmd(0x01);//清除數(shù)據(jù),防止出現(xiàn)錯(cuò)誤
    Write_cmd(0x80);
void Write_cmd(uchar cmd)
    rs=0;//數(shù)據(jù)/命令選擇段(h/l)
    P0=cmd;
    delay(5);
    lcd_en=1;//使能信號,高脈沖
    delay(5);
    lcd_en=0;
void Write_data(uchar data_)
    rs=1;
    P0=data_;
    delay(5);
    lcd_en=1;
    delay(5);
    lcd_en=0;
ID:7485 發(fā)表于 2017-5-29 16:00 | 只看該作者
其實(shí)這是最基本的。檢測取得按鍵值后,根據(jù)其值將程序跳轉(zhuǎn)到指定的顯示內(nèi)容即可。
