從前,利用51單片機(jī)自帶的時(shí)鐘做的電子鐘時(shí)差太大,不停地在程序里去寫時(shí)間矯正程序,之后發(fā)現(xiàn)了DS1302這個(gè)芯片,那時(shí)候是新手,不太了解,所以一直擱置,現(xiàn)在有了時(shí)間,把這個(gè)芯片詳細(xì)研究了一下,之后發(fā)現(xiàn)開(kāi)發(fā)板上程序只能讀,不能寫,專門挑了半天來(lái)研究這個(gè)芯片的驅(qū)動(dòng),果然功夫不負(fù)有心人,終于把這個(gè)做了出來(lái),成品如下
2017-5-30 16:21 上傳
原理圖:
2017-5-30 16:21 上傳
2017-5-30 16:22 上傳
現(xiàn)在把代碼發(fā)一下
- /***temp.h***/
- #ifndef _temp_h_
- #define _temp_h_
- #include"reg52.h"
- #include"intrins.h"
- #define uint unsigned int
- #define uchar unsigned char
- extern uchar shuzu[7];
- sbit sclk=P3^2;
- sbit dsio=P3^3;
- sbit dir=P3^4;
- sbit dq=P3^5;
- sbit sb1=P1^0;
- sbit sb2=P1^1;
- sbit sb3=P1^2;
- //void delay(uint z);
- void dee(uint z);
- void csh1302();
- void dq1302();
- void xzl1302(uchar add,uchar dar);
- uchar kzzsc(uchar ram,uchar temp,uchar wd);
- #endif
復(fù)制代碼- /***main.c***/
- #include"temp.h"
- uchar dtt,drr;
- uchar smgshuzu[4];
- uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
- uint et0time=(65535-50000);
- void zhdq1302(uchar i)
- uchar ge,shi,miao;
- if(i==0){dq1302();}
- smgshuzu[0]=table[shuzu[2]/16];
- smgshuzu[1]=dtt+table[shuzu[2]%16];
- smgshuzu[2]=table[shuzu[1]/16];
- smgshuzu[3]=table[shuzu[1]%16];
- shi=shuzu[0]/16;
- ge=shuzu[0]%16;
- miao=ge+shi*10;
- if(miao!=drr)
- drr=miao;
- if(dtt==0x00){dtt=0x80;}
- else {dtt=0x00;}
- void smgxs()
- uchar i;
- P0=0xfe;
- for(i=0;i<4;i++)
- P2=smgshuzu[i];
- dee(100);
- P2=0x00;
- P0=_crol_(P0,1);
- void szcsh()
- TCON=1;
- TH0=et0time/256;
- TL0=et0time%256;
- TR0=1;
- EA=1;
- ET0=1;
- void main()
- uchar i,k;
- uint l;
- csh1302();
- szcsh();
- while(1)
- zhdq1302(0);
- if(sb1==0)
- dee(100);
- if(sb1==0)
- while(sb1==0){l++,dee(110);if(l==1000){k=1;l=0;}}
- dee(100);
- xzl1302(0x8e,0x00);
- xzl1302(kzzsc(0,1,1),0x80);
- while(sb1!=0 && k!=1)
- zhdq1302(1);
- smgxs();
- if(sb2==0){while(sb2==0);dee(100);shuzu[1]++;}
- if(sb3==0){while(sb3==0);dee(100);shuzu[2]++;}
- if(shuzu[1]%16==10){shuzu[1]-=10;shuzu[1]+=16;}
- if(shuzu[1]/16==6){shuzu[1]=0;shuzu[2]++;}
- if(shuzu[2]%16==10){shuzu[2]-=10;shuzu[2]+=16;}
- if(shuzu[2]%16==4&&shuzu[2]/16==2){shuzu[0]=shuzu[1]=shuzu[2]=0;}
- while(sb1==0);
- if(k==0)
- for(i=0;i<7;i++)
- xzl1302(kzzsc(0,i,0),shuzu[i]);
- xzl1302(0x8e,0x80);
- k=0;
- void zhong1() interrupt 1
- uint i;
- TH0=et0time/256;
- TL0=et0time%256;
- smgxs();
- i++;
- if(i==200)
- i=0;
這邊是核心的驅(qū)動(dòng)
- /***ds1302.c***/
- #include"temp.h"
- uchar shuzu[7]={0,0,0x12,0x07,0x05,0x06,0x16};
- void dee(uint z)
- while(z--);
- /*void delay(uint z)
- uint x,y;
- for(x=z;x>0;x--)
- for(y=110;y>0;y--);
- uchar i;
- sclk=0;
- _nop_();
- dir=1;
- _nop_();
- for(i=0;i<8;i++)
- dsio=add&0x01;
- add>>=1;
- _nop_();
- sclk=1;
- _nop_();
- sclk=0;
- _nop_();
- _nop_();
- for(i=0;i<8;i++)
- dsio=dar&0x01;
- dar>>=1;
- _nop_();
- sclk=1;
- _nop_();
- sclk=0;
- _nop_();
- _nop_();
- dir=0;
- uchar dsj1302(uchar dar)
- uchar bi,temp,i;
- sclk=0;
- _nop_();
- dir=1;
- _nop_();
- for(i=0;i<8;i++)
- dsio=dar&0x01;
- dar>>=1;
- _nop_();
- sclk=1;
- _nop_();
- sclk=0;
- _nop_();
- _nop_();
- for(i=0;i<8;i++)
- bi=dsio;
- temp=(temp>>=1)|(bi<<=7);
- _nop_();
- sclk=1;
- _nop_();
- sclk=0;
- _nop_();
- dir=0;
- _nop_();
- sclk=1;
- _nop_();
- dsio=0;
- _nop_();
- dsio=1;
- _nop_();
- return temp;
- uchar drr;
- drr=1;
- drr<<=1;
- drr=drr|ram;
- drr<<=5;
- drr+=temp;
- drr<<=1;
- drr+=wd;
- return drr;
- void dq1302()
- uchar i;
- for(i=0;i<7;i++)
- shuzu[i]=dsj1302(kzzsc(0,i,1));
- _nop_();
- void csh1302()
- uchar i;
- for(i=0;i<7;i++)
- _nop_();
里面有一些沒(méi)用的代碼,本來(lái)是要加上溫度顯示功能,結(jié)果沒(méi)加,現(xiàn)在把文件發(fā)了:
相關(guān)工程文件.rar
(2.07 MB, 下載次數(shù): 50)
2017-5-30 10:04 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
