查看: 2377|回復(fù): 0
stm8對電機調(diào)速程序
ID:206568 發(fā)表于 2017-6-1 16:44 | 顯示全部樓層 |閱讀模式
#include"canshu.h"
uint t;
uchar time2_2h=4,time2_2l=4;
void TIM2_Init()
TIM2_CCMR2 = TIM2_CCMR2 | 0x70;// Output modePWM2.
                                //通道2被設(shè)置成比較輸出方式
                                // OC2M = 111,PWM模式2,
                                // 向上計數(shù)時,若計數(shù)器小于比較值,為無效電平
                                // 即當計數(shù)器在0到比較值時,輸出為1,否則為0
TIM2_CCMR1 = TIM2_CCMR1 | 0x70;
TIM2_CCMR3 = TIM2_CCMR3 | 0x70;
TIM2_CCER1 = TIM2_CCER1 | 0x33;// CC polarity low,enable PWMoutput      */
                                // CC2P = 1,低電平為有效電平
                                // CC2E = 1,開啟輸出引腳
TIM2_CCER2 = TIM2_CCER2 | 0x03;
//初始化自動裝載寄存器,決定PWM方波的頻率,Fpwm=16000000/1000=16kHZ
  TIM2_ARRH = 16000/255;
  TIM2_ARRL = 16000%255;
   TIM2_CCR1H =time2_2h;
  TIM2_CCR1L = time2_2l=4;
//初始化比較寄存器,決定PWM方波的占空比
  TIM2_CCR2H =1000/255;
  TIM2_CCR2L =1000%255;
  TIM2_CCR3H = 1000/255;
  TIM2_CCR3L = 1000%255;
//初始化時鐘分頻器為1,即計數(shù)器的時鐘頻率為Fmaster=4MHZ
  TIM2_PSCR =0x00;//因為用了繼電器,所以喲分頻,可到0x08,256分頻
//啟動計數(shù)
TIM2_CR1 = TIM2_CR1 | 0x01;
//外部中斷觸發(fā)
void exit_init()
   PC_DDR&=~0x04;
   PC_CR1|=0x04;
   PC_CR2|=0x04;
   EXTI_CR1|= 0x10;
#pragma vector=0x07 // 這里很關(guān)鍵!看下面說明。
__interrupt void EXTI_PC1(void)
  asm("sim");
  switch(EXTI_CR1)
  case 0x10:EXTI_CR1=0x20;exit_flag=1;break;
  case 0x20:EXTI_CR1=0x10;exit_flag=2;break;
  default :exit_flag=0;break;
if(exit_flag==2)
    t++;
   exit_flag=0;
   if(t%10==0)
      ulong chaju;
      now_nus=TIM4_CNTR;
      now_ms=cishu;
     chaju_ms=now_ms-last_ms;
   if(cishu_flag==1)
     cishu_flag=0;
     chaju_ms=30000+now_ms-last_ms;
      chaju_nus=now_nus-last_nus;
      chaju=chaju_ms*250+chaju_nus;
      now_rads=(1250000/chaju);
      last_nus=now_nus;
      last_ms=now_ms;
      last_rads[rads_flag++]=now_rads;
      if(rads_flag==10)
        rads_flag=0;
    pid_error=now_rads-last_radss;
    pid_error1=last_radss-last_radsss;
     last_radsss=last_radss;
     last_radss =now_rads;
   asm("rim");
#pragma vector=TIM2_OVR_UIF_vector
     __interrupt void TIM3_OVF_IRQHandler(void)
         TIM2_SR1 = 0x00;
         ds1820_flag=1;
//定時器2產(chǎn)生60s的中斷
void TIM2_time()
     TIM2_EGR=0x01; //手動產(chǎn)生更新事件,重新初始化計數(shù)器,并允許產(chǎn)生一個更新事件
    //設(shè)置定時器初值
    TIM2_CNTRH=0; //不能使用TIM3_CNTR直接設(shè)值,
    TIM2_CNTRL=0;
    //設(shè)定自動重裝寄存器值
    //這里得注意不能使用TIM2_ARR的方式進行設(shè)值,TIM2是十六位的。
    //TIM2_ARR=0xFA,實際上是賦給高字節(jié)了,TIM2_ARRH=0xFA,而不是想象中的賦給低字節(jié)。
    TIM2_ARRH=0x72; //488hz 488 /29280  = 60s (1S)
    TIM2_ARRL=0x60; //0x007d   意味著每產(chǎn)生一次中斷時間為60S
    TIM2_PSCR=0x0f; //預(yù)分頻32275
    TIM2_IER=0x01; //中斷允許位使能
    TIM2_CR1=0x01; //使能計時器
