查看: 2397|回復(fù): 2
想在這個(gè)時(shí)鐘程序加個(gè)鬧鐘功能,求大神指導(dǎo)
ID:194878 發(fā)表于 2017-6-2 13:00 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
本帖最后由 yhb306724368 于 2017-6-2 13:02 編輯
#include <reg52.h>
typedef unsigned char u8;
typedef unsigned int u16;
sbit rs=P3^5;
sbit rw = P3^6;
sbit en=P3^4;
sbit k1=P3^0;
sbit k2=P3^1;
sbit k3=P3^2;
sbit ding=P2^3;    //蜂鳴器
u8  code disp1[]="  Design clock";
u8  code disp2[]="    23:59:40 ";
u8 num,ad;        //全局變量
char miao,fen,shi;
void delay(u16 z)   //延時(shí)函數(shù)
u16 x,y;
for(x=z;x>0;x--)
  for(y=110;y>0;y--);
void write_com(u8 com)  //寫指令
   rs=0;
   rw=0;
   P0=com;
   delay(5);
   en=1;
   delay(5);
   en=0;
void write_date(u8 date)  //讀指令
   rs=1;
   rw=0;
   P0=date;
   delay(5);
   en=1;
   delay(5);
   en=0;
void init_lcd()   //lcd液晶初始化
{  shi=23;
   fen=59;
   miao=40;
   ding=1;
   k1=1;
   k2=1;
   k3=1;
   rs=0;
   rw=0;
   en=0;
   write_com(0x06);
   write_com(0x0c);
   write_com(0x38);
   write_com(0x01);
   write_com(0x80);
   TMOD=0x01;
   TH0=(65535-50000)/256;
   TL0=(65535-50000)%256;
   EA=1;
   ET0=1;
void lcd_dis(u8 add,u8 shu)  //顯示函數(shù)
   u8 shi,ge;
   shi=shu/10;
   ge=shu%10;
   write_com(0x80+0x40+add);
   write_date(0x30+shi);
   write_date(0x30+ge);
void hed()      //蜂鳴器響一次
   ding=0;
   delay(10);
   ding=1;
void key()    //調(diào)時(shí)函數(shù)
if(k1==0)
   delay(5);//消抖
   if(k1==0)
      hed();
       ad++;
       while(!k1)
       if(ad==1)
         TR0=0;    //關(guān)閉定時(shí)器0
         write_com(0x80+0x40+10);//秒位
         write_com(0x0f);  //開光標(biāo)
       if(ad==2)
         write_com(0x80+0x40+7);
         write_com(0x0f);
      if(ad==3)
         write_com(0x80+0x40+4);
         write_com(0x0f);
      if(ad==4)
           write_com(0x0c);
           TR0=1;  //開啟定時(shí)器0
           ad=0;
void jia() //加函數(shù)
   if(ad!=0)
   if(k2==0)
      delay(5);
      if(k2==0)
         while(!k2);hed();
         if(ad==1)
         miao++;
         if(miao==60)
            miao=0;
         lcd_dis(10,miao);
         if(ad==2)
         fen++;
         if(fen==60)
            fen=0;
         lcd_dis(7,fen);
         if(ad==3)
         shi++;
         if(shi==24)
            shi=0;
         lcd_dis(4,shi);
void jian()//減函數(shù)
   if(ad!=0)
   if(k3==0)
      delay(5);
      if(k3==0)
         while(!k3);hed();
         if(ad==1)
         miao--;
         if(miao==0)
            miao=59;
         lcd_dis(10,miao);
         if(ad==2)
         fen--;
         if(fen==0)
            fen=59;
         lcd_dis(7,fen);
         if(ad==3)
         shi--;
         if(shi==0)
            shi=24;
         lcd_dis(4,shi);
void main()//主函數(shù)
   init_lcd();
   for(num=0;num<14;num++)//lcd液晶顯示初值
      write_date(disp1[num]);
      delay(10);
     write_com(0x80+0x40);
   for(num=0;num<13;num++)
     write_date(disp2[num]);
     delay(10);
   TR0=1;
             key();
             jia();
             jian();
void timer0()  interrupt 0//定時(shí)器中斷0函數(shù)
  u8 a;
  a++;
  if(a==20)
       a=0;
       miao++;
       if(miao==60)
           miao=0;
           fen++;
           if(fen==60)
               fen=0;
               shi++;
               if(shi==24)
                shi=0;
               lcd_dis(4,shi);
           lcd_dis(7,fen);
       lcd_dis(10,miao);
ID:82765 發(fā)表于 2017-6-2 22:57 | 只看該作者
提示: 作者被禁止或刪除 內(nèi)容自動(dòng)屏蔽
ID:194878 發(fā)表于 2017-6-3 18:04 | 只看該作者
cjjcjj1 發(fā)表于 2017-6-2 22:57
鬧鐘是固定時(shí)間響?還是需要隨意設(shè)置時(shí)間?
隨意設(shè)置時(shí)間
