- #include "reg51.h"
- #include "intrins.h" //_nop_();延時函數(shù)用
- #define dm P0 //段碼輸出口
- #define uchar unsigned char
- #define uint unsigned int
- sbit DQ=P2^7; //溫度輸入口
- sbit w0=P2^0; //數(shù)碼管4
- sbit w1=P2^1; //數(shù)碼管3
- sbit w2=P2^2; //數(shù)碼管2
- sbit w3=P2^3; //數(shù)碼管1
- sbit LED=P1^6; //指示燈
- sbit beep=P1^7; //蜂鳴器
- sbit set=P2^6; //溫度設置切換鍵
- sbit add=P2^4; //溫度加
- sbit dec=P2^5; //溫度減
- int temp1=0; //顯示當前溫度和設置溫度的標志位為0時顯示當前溫度
- uint h;
- uint temp;
- uchar r;
- uchar high=30,low=15; //溫度范圍設置為15-30度
- uchar sign;
- uchar q=0;
- uchar tt=0;
- uchar scale;
- //**************溫度小數(shù)部分用查表法***********//
- uchar code ditab[16]={0x00,0x01,0x01,0x02,0x03,0x03,0x04,0x04,0x05,0x06,0x06,0x07,0x08,0x08,0x09,0x09}; //小數(shù)斷碼表
- uchar code table_dm[12]={~0x3f,~0x06,~0x5b,~0x4f,~0x66,~0x6d,~0x7d,~0x07,~0x7f,~0x6f,~0x00,~0x40};
- //共陽極數(shù)碼管LED段碼表 "0" "1" "2" "3" "4" "5" "6" "7" "8" "9" "不亮" "-"
- uchar table_dm1[]={~0xbf,~0x86,~0xdb,~0xcf,~0xe6,~0xed,~0xfd,~0x87,~0xff,~0xef}; //個位帶小數(shù)點的斷碼表
- uchar data temp_data[2]={0x00,0x00}; //讀出溫度暫放
- uchar data display[5]={0x00,0x00,0x00,0x00,0x00}; //顯示單元數(shù)據(jù),共4個數(shù)據(jù)和一個運算暫用
- /*****************11us延時函數(shù)*************************/
- void delay(uint t)
- for (;t>0;t--);
- void scan()
- int j;
- for(j=0;j<4;j++)
- switch (j)
- case 0: dm=table_dm[display[0]];w0=0;delay(50);w0=1;//xiaoshu
- case 1: dm=table_dm1[display[1]];w1=0;delay(50);w1=1;//gewei
- case 2: dm=table_dm[display[2]];w2=0;delay(50);w2=1;//shiwei
- case 3: dm=table_dm[display[3]];w3=0;delay(50);w3=1;//baiwei
- // else{dm=table_dm[b3];w3=0;delay(50);w3=1;}
- //***************DS18B20復位函數(shù)************************/
- ow_reset(void)
- char presence=1;
- while(presence)
- while(presence)
- DQ=1;_nop_();_nop_();//從高拉倒低
- DQ=0;
- delay(50); //550 us
- DQ=1;
- delay(6); //66 us
- presence=DQ; //presence=0 復位成功,繼續(xù)下一步
- delay(45); //延時500 us
- presence=~DQ;
- DQ=1; //拉高電平
- /****************DS18B20寫命令函數(shù)************************/
- //向1-WIRE 總線上寫1個字節(jié)
- void write_byte(uchar val)
- uchar i;
- for(i=8;i>0;i--)
- DQ=1;_nop_();_nop_(); //從高拉倒低
- DQ=0;_nop_();_nop_();_nop_();_nop_(); //5 us
- DQ=val&0x01; //最低位移出
- delay(6); //66 us
- val=val/2; //右移1位
- DQ=1;
- delay(1);
- /****************DS18B20讀1字節(jié)函數(shù)************************/
- //從總線上取1個字節(jié)
- uchar read_byte(void)
- uchar i;
- uchar value=0;
- for(i=8;i>0;i--)
- value>>=1;
- DQ=0;_nop_();_nop_();_nop_();_nop_(); //4 us
- DQ=1;_nop_();_nop_();_nop_();_nop_(); //4 us
- if(DQ)value|=0x80;
- delay(6); //66 us
- DQ=1;
- return(value);
- /*****************讀出溫度函數(shù)************************/
- read_temp()
- ow_reset(); //總線復位
- delay(200);
- write_byte(0xcc); //發(fā)命令
- write_byte(0x44); //發(fā)轉換命令
- ow_reset();
- delay(1);
- write_byte(0xbe);
- temp_data[0]=read_byte(); //讀溫度值的第字節(jié)
- temp_data[1]=read_byte(); //讀溫度值的高字節(jié)
- temp=temp_data[1];
- temp<<=8;
- temp=temp|temp_data[0]; // 兩字節(jié)合成一個整型變量。
- return temp; //返回溫度值
- /****************溫度數(shù)據(jù)處理函數(shù)************************/
- //二進制高字節(jié)的低半字節(jié)和低字節(jié)的高半字節(jié)組成一字節(jié),這個
- //字節(jié)的二進制轉換為十進制后,就是溫度值的百、十、個位值,而剩
- //下的低字節(jié)的低半字節(jié)轉化成十進制后,就是溫度值的小數(shù)部分
- work_temp(uint tem)
- uchar n=0;
- if(tem>6348) // 溫度值正負判斷
- {tem=65536-tem;n=1;} // 負溫度求補碼,標志位置1
- display[4]=tem&0x0f; // 取小數(shù)部分的值
- display[0]=ditab[display[4]]; // 存入小數(shù)部分顯示值
- display[4]=tem>>4; // 取中間八位,即整數(shù)部分的值
- display[3]=display[4]/100; // 取百位數(shù)據(jù)暫存
- display[1]=display[4]%100; // 取后兩位數(shù)據(jù)暫存
- display[2]=display[1]/10; // 取十位數(shù)據(jù)暫存
- display[1]=display[1]%10; //個位數(shù)據(jù)
- r=display[1]+display[2]*10+display[3]*100;
- /////符號位顯示判斷/////
- if(!display[3])
- display[3]=0x0a; //最高位為0時不顯示
- if(!display[2])
- display[2]=0x0a; //次高位為0時不顯示
- if(n){display[3]=0x0b;} //負溫度時最高位顯示"-"
- void BEEP()
- if((r>=high&&r<129)||r<low)
- beep=!beep;
- LED=0;
- else
- beep=1;
- LED=1;
- //*********設置溫度顯示轉換************//
- void xianshi(int horl)
- int n=0;
- if(horl>128)
- horl=256-horl;n=1;
- display[3]=horl/100;
- display[3]=display[3]&0x0f;
- display[2]=horl%100/10;
- display[1]=horl%10;
- display[0]=0;
- if(!display[3])
- if(!display[2])
- if(n)
- display[3]=0x0b; //負溫度時最高位顯示"-"
- //*********按鍵查詢程序**************//
- void keyscan()
- int temp1; //最高溫度和最低溫度標志位
- if(set==0)
- while(1)
- delay(500);//消抖
- if(set==0)
- temp1++;
- while(!set)
- scan();
- if(temp1==1)
- xianshi(high);
- scan();
- if(add==0)
- while(!add)
- scan();
- high+=1;
- if(dec==0)
- while(!dec)
- scan();
- high-=1;
- if(temp1==2)
- xianshi(low);
- if(add==0)
- while(!add)
- scan();
- low+=1;
- if(dec==0)
- while(!dec)
- scan();
- low-=1;
- scan();
- if(temp1>=3)
- temp1=0;
- break;
- /****************主函數(shù)************************/
- void main()
- dm=0x00; //初始化端口
- w0=1;
- w1=1;
- w2=1;
- w3=1;
- for(h=0;h<4;h++) //開機顯示"0000"
- display[h]=0;
- ow_reset(); //開機先轉換一次
- write_byte(0xcc); //Skip ROM
- for(h=0;h<100;h++) //開機顯示"0000"
- scan();
- while(1)
- if (temp1==0)
- work_temp(read_temp()); //處理溫度數(shù)據(jù)
- BEEP();
- scan(); //顯示溫度值
- keyscan();
- else
- keyscan();
