- #include<reg52.h>
- #ifndef __SOUNDPLAY_H_REVISION_FIRST__
- #define __SOUNDPLAY_H_REVISION_FIRST__
- #define SYSTEM_OSC 11059200 //定義晶振頻率11059200HZ
- #define SOUND_SPACE 4/5 //定義普通音符演奏的長度分率,//每4分音符間隔
- sbit P1_0 = P0 ^ 0; //對跑馬燈的定義使用
- sbit P1_1 = P0 ^ 1;
- sbit P1_2 = P0 ^ 2;
- sbit P1_3 = P0 ^ 3;
- sbit P1_4 = P0 ^ 4;
- sbit P1_5 = P0 ^ 5;
- sbit P1_6 = P0 ^ 6;
- sbit P1_7 = P0 ^ 7;
- sbit P3_4 = P1 ^ 0; //對功能鍵的定義使用
- sbit P3_5 = P1 ^ 1;
- unsigned int code FreTab[12] = { 262,277,294,311,330,349,369,392,415,440,466,494 };
- //原始頻率表
- unsigned char code SignTab[7] = { 0,2,4,5,7,9,11 }; //1~7在頻率表中的位置
- unsigned char code LengthTab[7]= { 1,2,4,8,16,32,64 };
- unsigned char Sound_Temp_TH0,Sound_Temp_TL0; //音符定時器初值暫存
- unsigned char Sound_Temp_TH1,Sound_Temp_TL1; //音長定時器初值暫存
- sbit BeepIO = P3^7;//定義輸出管腳
- unsigned char Count=0; //0.05秒的變量定義
- unsigned int del; //過渡變量
- unsigned int tcnt; //過渡變量
- unsigned int numble=0; //歌曲曲數(shù)的定義
- unsigned char min=0, sec=0; //1秒鐘 1分鐘的定義
- 對整個中斷系統(tǒng)的設(shè)置
- 為了得到較好的音效,定時器0和定時器1用于音樂播放子程序
- 初值都為10MS
- 定時器2 用于播放時間的間斷顯示子程序,初值為50MS
- void InitialSound(void)
- BeepIO = 0;
- Sound_Temp_TH1 = (65535-(1/1200)*SYSTEM_OSC)/256; // 計算TL1應(yīng)裝入的初值
- Sound_Temp_TL1 = (65535-(1/1200)*SYSTEM_OSC)%256; // 計算TH1應(yīng)裝入的初值
- TH1 = Sound_Temp_TH1;
- TL1 = Sound_Temp_TL1;
- TMOD |= 0x11;
- ET0 = 1;
- ET1 = 0;
- TR0 = 0;
- TR1 = 0;
- RCAP2H = 0x2c; //對定時器2的初始化的定義使用
- RCAP2L = 0x13;
- TH2 = 0x2c; // 定時器初值
- TL2 = 0x13;
- ES = 0; // 關(guān)閉通信中斷
- ET2 = 1; // 允許T2中斷
- T2CON = 0X04;
- EA = 1;
- void BeepTimer0(void) interrupt 1 //音符發(fā)生中斷
- BeepIO = !BeepIO;
- TH0 = Sound_Temp_TH0;
- TL0 = Sound_Temp_TL0;
- void timer2Int(void) interrupt 5 //時鐘發(fā)生中斷
- TF2 = 0; // 溢出標志必須由軟件清零
- EXF2 = 0; // 捕獲標志必須由軟件清零
- Count++;
- if(Count==20)
- sec++;
- Count=0;
- if(sec==60)
- min++;
- sec=0;
- /*說明**********************************************************************
- 曲譜存貯格式 unsigned char code MusicName{音高,音長,音高,音長...., 0,0};
- 末尾:0,0 表示結(jié)束(Important)
- 音高由三位數(shù)字組成:
- 個位是表示 1~7 這七個音符
- 十位是表示音符所在的音區(qū):1-低音,2-中音,3-高音;
- 百位表示這個音符是否要升半音: 0-不升,1-升半音。
- 音長最多由三位數(shù)字組成:
- 個位表示音符的時值,其對應(yīng)關(guān)系是:
- |數(shù)值(n): |0 |1 |2 |3 | 4 | 5 | 6
- |幾分音符: |1 |2 |4 |8 |16 |32 |64 音符=2^n
- 十位表示音符的演奏效果(0-2): 0-普通,1-連音,2-頓音
- 百位是符點位: 0-無符點,1-有符點
- 調(diào)用演奏子程序的格式
- Play(樂曲名,調(diào)號,升降八度,演奏速度);
- |樂曲名 : 要播放的樂曲指針,結(jié)尾以(0,0)結(jié)束;
- |調(diào)號(0-11) : 是指樂曲升多少個半音演奏;
- |升降八度(1-3) : 1:降八度, 2:不升不降, 3:升八度;
- |演奏速度(1-12000): 值越大速度越快;
- void Play(unsigned char *Sound,unsigned char Signature,unsigned Octachord,unsigned int Speed)
- unsigned int NewFreTab[12]; //新的頻率表
- unsigned char i,j;
- unsigned int Point,LDiv,LDiv0,LDiv1,LDiv2,LDiv4,CurrentFre,Temp_T,SoundLength;
- unsigned char Tone,Length,SL,SH,SM,SLen,XG,FD;
- for(i=0;i<12;i++) // 根據(jù)調(diào)號及升降八度來生成新的頻率表
- j = i + Signature;
- if(j > 11)
- j = j-12;
- NewFreTab[ i] = FreTab[j]*2; } else NewFreTab[ i] = FreTab[j];
- if(Octachord == 1) NewFreTab[ i]>>=2; else if(Octachord == 3) NewFreTab[ i]<<=2; } SoundLength = 0; while(Sound[SoundLength] != 0x00) //計算歌曲長度 { SoundLength+=2; }
- Point = 0; Tone = Sound[Point]; Length = Sound[Point+1]; // 讀出第一個音符和它時時值 LDiv0 = 12000/Speed; // 算出1分音符的長度(幾個10ms) LDiv4 = LDiv0/4; // 算出4分音符的長度 LDiv4 = LDiv4-LDiv4*SOUND_SPACE; // 普通音最長間隔標準 TR0 = 0; TR1 = 1; while(Point < SoundLength) { SL=Tone%10; //計算出音符 SM=Tone/10%10; //計算出高低音 SH=Tone/100; //計算出是否升半 CurrentFre = NewFreTab[SignTab[SL-1]+SH]; //查出對應(yīng)音符的頻率 if(SL!=0) { if (SM==1) CurrentFre >>= 2; //低音 if (SM==3) CurrentFre <<= 2; //高音 Temp_T = 65536-(50000/CurrentFre)*10/(12000000/SYSTEM_OSC);//計算計數(shù)器初值 Sound_Temp_TH0 = Temp_T/256; Sound_Temp_TL0 = Temp_T%256; TH0 = Sound_Temp_TH0; TL0 = Sound_Temp_TL0 + 12; //加12是對中斷延時的補償 } SLen=LengthTab[Length%10]; //算出是幾分音符 XG=Length/10%10; //算出音符類型(0普通1連音2頓音) FD=Length/100; LDiv=LDiv0/SLen; //算出連音音符演奏的長度(多少個10ms) if (FD==1) LDiv=LDiv+LDiv/2; if(XG!=1) if(XG==0) //算出普通音符的演奏長度 if (SLen<=4) LDiv1=LDiv-LDiv4; else LDiv1=LDiv*SOUND_SPACE; else LDiv1=LDiv/2; //算出頓音的演奏長度 else LDiv1=LDiv; if(SL==0) LDiv1=0; LDiv2=LDiv-LDiv1; //算出不發(fā)音的長度 if (SL!=0) { TR0=1; for(i=LDiv1;i>0;i--) //發(fā)規(guī)定長度的音 { while(TF1==0); TH1 = Sound_Temp_TH1; TL1 = Sound_Temp_TL1; TF1=0; }/*************************************************************************功能鍵子程序,直接嵌入音樂播放程序之中P1-0 P1-1 P1-2 P1-3 P1-4 P1-5 P1-6 P1-7六個跑馬燈實現(xiàn)發(fā)出每個音符時的間斷閃爍P3-4 P3-5兩鍵 實現(xiàn)暫停和開始的功能為以后的二次開發(fā),特留下兩個功能鍵 以備后用*************************************************************************/ { if(i==1*LDiv1/1024) {P1_0=0;P1_1=1;P1_2=1;P1_3=1;P1_4=1;P1_5=1;P1_6=1;P1_7=1;} if(i==51*LDiv1/1024) {P1_0=0;P1_1=1;P1_2=1;P1_3=1;P1_4=1;P1_5=1;P1_6=1;P1_7=1;} if(i==101*LDiv1/1024) {P1_0=0;P1_1=0;P1_2=0;P1_3=1;P1_4=1;P1_5=1;P1_6=1;P1_7=1;} if(i==151*LDiv1/1024) {P1_0=0;P1_1=0;P1_2=0;P1_3=0;P1_4=1;P1_5=1;P1_6=1;P1_7=1;} if(i==201*LDiv1/1024) {P1_0=0;P1_1=0;P1_2=0;P1_3=0;P1_4=0;P1_5=1;P1_6=1;P1_7=1;} if(i==251*LDiv1/1024) {P1_0=0;P1_1=0;P1_2=0;P1_3=0;P1_4=0;P1_5=0;P1_6=1;P1_7=1;} if(i==301*LDiv1/1024) {P1_0=0;P1_1=0;P1_2=0;P1_3=0;P1_4=0;P1_5=0;P1_6=1;P1_7=1;} if(i==351*LDiv1/1024) {P1_0=0;P1_1=0;P1_2=0;P1_3=0;P1_4=0;P1_5=0;P1_6=0;P1_7=1;} if(i==401*LDiv1/1024) {P1_0=0;P1_1=0;P1_2=0;P1_3=0;P1_4=0;P1_5=0;P1_6=0;P1_7=0;}
- if(P3_4==0) for(i=300;i>0;i--) for(j=300;j>0;j--); if(P3_4==0) EA=0; if(P3_5==0) for(i=300;i>0;i--) for(j=300;j>0;j--); if(P3_5==0) EA=1;}
- } if(LDiv2!=0) { TR0=0; BeepIO=0; for(i=LDiv2;i>0;i--) //音符間的間隔 { while(TF1==0); TH1 = Sound_Temp_TH1; TL1 = Sound_Temp_TL1; TF1=0; } } Point+=2; Tone=Sound[Point]; Length=Sound[Point+1]; } BeepIO = 0;}/**************************************************************************/#endif
- /**************************************************************************數(shù)碼管顯示子程序首先實現(xiàn)約4秒的個性簽名 FLYING 的顯示然后實現(xiàn)約3秒的歌曲曲數(shù)的顯示(從左到右的1-2位) 當前運行時間的顯示(從左到右的4-8位的)由于本人買的單片機的數(shù)碼管接線紊亂,故字形口和字位口同資料書上介紹的不同**************************************************************************/void Delay1ms(){unsigned char code dispcode[]={ 0x41,0xf5,0x29,0x31,0x95,0x13,0x03,0x75,0x01,0x11,0xbf,0x11,0x45,0xf5,0x91,0xcb,0x0f,0xff}; unsigned char dispbitcode[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f}; unsigned char dispbuf[8]={0,0,0,0,0,0,0,0}; unsigned char dispbitcnt; unsigned char mstcnt;unsigned int i,j; numble++;
- for(i=250;i>0;i--) for(j=300;j>0;j--) {mstcnt++; if(mstcnt==8) { mstcnt=0; P0=dispcode[dispbuf[dispbitcnt]]; P2=dispbitcode[dispbitcnt]; dispbitcnt++; if(dispbitcnt==8) { dispbitcnt=0; } }
- dispbuf[1]=10; dispbuf[2]=11; dispbuf[0]=12; dispbuf[3]=13; dispbuf[5]=14; dispbuf[6]=15; dispbuf[4]=16; dispbuf[7]=10; }
- for(i=150;i>0;i--) for(j=200;j>0;j--) { mstcnt++; if(mstcnt==8) { mstcnt=0; P0=dispcode[dispbuf[dispbitcnt]]; P2=dispbitcode[dispbitcnt]; dispbitcnt++; if(dispbitcnt==8) { dispbitcnt=0; } }
- dispbuf[7]=numble/10; dispbuf[4]=numble&9; dispbuf[6]=17; dispbuf[5]=min/10; dispbuf[3]=min&9; dispbuf[0]=10; dispbuf[2]=sec/10; dispbuf[1]=sec&9; }
- //*****************************Music*******************************************//揮著翅膀的女孩---容祖兒unsigned char code Music_Girl[]={ 0x17,0x02, 0x17,0x03, 0x18,0x03, 0x19,0x02, 0x15,0x03, 0x16,0x03, 0x17,0x03, 0x17,0x03, 0x17,0x03, 0x18,0x03, 0x19,0x02, 0x16,0x03, 0x17,0x03, 0x18,0x02, 0x18,0x03, 0x17,0x03, 0x15,0x02, 0x18,0x03, 0x17,0x03, 0x18,0x02, 0x10,0x03, 0x15,0x03, 0x16,0x02, 0x15,0x03, 0x16,0x03, 0x17,0x02, 0x17,0x03, 0x18,0x03, 0x19,0x02, 0x1A,0x03, 0x1B,0x03, 0x1F,0x03, 0x1F,0x03, 0x17,0x03, 0x18,0x03, 0x19,0x02, 0x16,0x03, 0x17,0x03, 0x18,0x03, 0x17,0x03, 0x18,0x03, 0x1F,0x03, 0x1F,0x02, 0x16,0x03, 0x17,0x03, 0x18,0x03, 0x17,0x03, 0x18,0x03, 0x20,0x03, 0x20,0x02, 0x1F,0x03, 0x1B,0x03, 0x1F,0x66, 0x20,0x03, 0x21,0x03, 0x20,0x03, 0x1F,0x03, 0x1B,0x03, 0x1F,0x66, 0x1F,0x03, 0x1B,0x03, 0x19,0x03, 0x19,0x03, 0x15,0x03, 0x1A,0x66, 0x1A,0x03, 0x19,0x03, 0x15,0x03, 0x15,0x03, 0x17,0x03, 0x16,0x66, 0x17,0x04, 0x18,0x04, 0x18,0x03, 0x19,0x03, 0x1F,0x03, 0x1B,0x03, 0x1F,0x66, 0x20,0x03, 0x21,0x03, 0x20,0x03, 0x1F,0x03, 0x1B,0x03, 0x1F,0x66, 0x1F,0x03, 0x1B,0x03, 0x19,0x03, 0x19,0x03, 0x15,0x03, 0x1A,0x66, 0x1A,0x03, 0x19,0x03, 0x19,0x03, 0x1F,0x03, 0x1B,0x03, 0x1F,0x00, 0x1A,0x03, 0x1A,0x03, 0x1A,0x03, 0x1B,0x03, 0x1B,0x03, 0x1A,0x03, 0x19,0x03, 0x19,0x02, 0x17,0x03, 0x15,0x17, 0x15,0x03, 0x16,0x03, 0x17,0x03, 0x18,0x03, 0x17,0x04, 0x18,0x0E, 0x18,0x03, 0x17,0x04, 0x18,0x0E, 0x18,0x66, 0x17,0x03, 0x18,0x03, 0x17,0x03, 0x18,0x03, 0x20,0x03, 0x20,0x02, 0x1F,0x03, 0x1B,0x03, 0x1F,0x66, 0x20,0x03, 0x21,0x03, 0x20,0x03, 0x1F,0x03, 0x1B,0x03, 0x1F,0x66, 0x1F,0x04, 0x1B,0x0E, 0x1B,0x03, 0x19,0x03, 0x19,0x03, 0x15,0x03, 0x1A,0x66, 0x1A,0x03, 0x19,0x03, 0x15,0x03, 0x15,0x03, 0x17,0x03, 0x16,0x66, 0x17,0x04, 0x18,0x04, 0x18,0x03, 0x19,0x03, 0x1F,0x03, 0x1B,0x03, 0x1F,0x66, 0x20,0x03, 0x21,0x03, 0x20,0x03, 0x1F,0x03, 0x1B,0x03, 0x1F,0x66, 0x1F,0x03, 0x1B,0x03, 0x19,0x03, 0x19,0x03, 0x15,0x03, 0x1A,0x66, 0x1A,0x03, 0x19,0x03, 0x19,0x03, 0x1F,0x03, 0x1B,0x03, 0x1F,0x00, 0x18,0x02, 0x18,0x03, 0x1A,0x03, 0x19,0x0D, 0x15,0x03, 0x15,0x02, 0x18,0x66, 0x16,0x02, 0x17,0x02, 0x15,0x00, 0x00,0x00};
- //同一首歌-毛阿敏unsigned char code Music_Same[]={ 0x0F,0x01, 0x15,0x02, 0x16,0x02, 0x17,0x66, 0x18,0x03, 0x17,0x02, 0x15,0x02, 0x16,0x01, 0x15,0x02, 0x10,0x02, 0x15,0x00, 0x0F,0x01, 0x15,0x02, 0x16,0x02, 0x17,0x02, 0x17,0x03, 0x18,0x03, 0x19,0x02, 0x15,0x02, 0x18,0x66, 0x17,0x03, 0x19,0x02, 0x16,0x03, 0x17,0x03, 0x16,0x00, 0x17,0x01, 0x19,0x02, 0x1B,0x02, 0x1B,0x70, 0x1A,0x03, 0x1A,0x01, 0x19,0x02, 0x19,0x03, 0x1A,0x03, 0x1B,0x02, 0x1A,0x0D, 0x19,0x03, 0x17,0x00, 0x18,0x66, 0x18,0x03, 0x19,0x02, 0x1A,0x02, 0x19,0x0C, 0x18,0x0D, 0x17,0x03, 0x16,0x01, 0x11,0x02, 0x11,0x03, 0x10,0x03, 0x0F,0x0C, 0x10,0x02, 0x15,0x00, 0x1F,0x01, 0x1A,0x01, 0x18,0x66, 0x19,0x03, 0x1A,0x01, 0x1B,0x02, 0x1B,0x03, 0x1B,0x03, 0x1B,0x0C, 0x1A,0x0D, 0x19,0x03, 0x17,0x00, 0x1F,0x01, 0x1A,0x01, 0x18,0x66, 0x19,0x03, 0x1A,0x01, 0x10,0x02, 0x10,0x03, 0x10,0x03, 0x1A,0x0C, 0x18,0x0D, 0x17,0x03, 0x16,0x00, 0x0F,0x01, 0x15,0x02, 0x16,0x02, 0x17,0x70, 0x18,0x03, 0x17,0x02, 0x15,0x03, 0x15,0x03, 0x16,0x66, 0x16,0x03, 0x16,0x02, 0x16,0x03, 0x15,0x03, 0x10,0x02, 0x10,0x01, 0x11,0x01, 0x11,0x66, 0x10,0x03, 0x0F,0x0C, 0x1A,0x02, 0x19,0x02, 0x16,0x03, 0x16,0x03, 0x18,0x66, 0x18,0x03, 0x18,0x02, 0x17,0x03, 0x16,0x03, 0x19,0x00, 0x00,0x00 };
- //兩只蝴蝶---- unsigned char code Music_Two[] ={ 0x17,0x03, 0x16,0x03, 0x17,0x01, 0x16,0x03, 0x17,0x03, 0x16,0x03, 0x15,0x01, 0x10,0x03, 0x15,0x03, 0x16,0x02, 0x16,0x0D, 0x17,0x03, 0x16,0x03, 0x15,0x03, 0x10,0x03, 0x10,0x0E, 0x15,0x04, 0x0F,0x01, 0x17,0x03, 0x16,0x03, 0x17,0x01, 0x16,0x03, 0x17,0x03, 0x16,0x03, 0x15,0x01, 0x10,0x03, 0x15,0x03, 0x16,0x02, 0x16,0x0D, 0x17,0x03, 0x16,0x03, 0x15,0x03, 0x10,0x03, 0x15,0x03, 0x16,0x01, 0x17,0x03, 0x16,0x03, 0x17,0x01, 0x16,0x03, 0x17,0x03, 0x16,0x03, 0x15,0x01, 0x10,0x03, 0x15,0x03, 0x16,0x02, 0x16,0x0D, 0x17,0x03, 0x16,0x03, 0x15,0x03, 0x10,0x03, 0x10,0x0E, 0x15,0x04, 0x0F,0x01, 0x17,0x03, 0x19,0x03, 0x19,0x01, 0x19,0x03, 0x1A,0x03, 0x19,0x03, 0x17,0x01, 0x16,0x03, 0x16,0x03, 0x16,0x02, 0x16,0x0D, 0x17,0x03, 0x16,0x03, 0x15,0x03, 0x10,0x03, 0x10,0x0D, 0x15,0x00, 0x19,0x03, 0x19,0x03, 0x1A,0x03, 0x1F,0x03, 0x1B,0x03, 0x1B,0x03, 0x1A,0x03, 0x17,0x0D, 0x16,0x03, 0x16,0x03, 0x16,0x0D, 0x17,0x01, 0x17,0x03, 0x17,0x03, 0x19,0x03, 0x1A,0x02, 0x1A,0x02, 0x10,0x03, 0x17,0x0D, 0x16,0x03, 0x16,0x01, 0x17,0x03, 0x19,0x03, 0x19,0x03, 0x17,0x03, 0x19,0x02, 0x1F,0x02, 0x1B,0x03, 0x1A,0x03, 0x1A,0x0E, 0x1B,0x04, 0x17,0x02, 0x1A,0x03, 0x1A,0x03, 0x1A,0x0E, 0x1B,0x04, 0x1A,0x03, 0x19,0x03, 0x17,0x03, 0x16,0x03, 0x17,0x0D, 0x16,0x03, 0x17,0x03, 0x19,0x01, 0x19,0x03, 0x19,0x03, 0x1A,0x03, 0x1F,0x03, 0x1B,0x03, 0x1B,0x03, 0x1A,0x03, 0x17,0x0D, 0x16,0x03, 0x16,0x03, 0x16,0x03, 0x17,0x01, 0x17,0x03, 0x17,0x03, 0x19,0x03, 0x1A,0x02, 0x1A,0x02, 0x10,0x03, 0x17,0x0D, 0x16,0x03, 0x16,0x01, 0x17,0x03, 0x19,0x03, 0x19,0x03, 0x17,0x03, 0x19,0x03, 0x1F,0x02, 0x1B,0x03, 0x1A,0x03, 0x1A,0x0E, 0x1B,0x04, 0x17,0x02, 0x1A,0x03, 0x1A,0x03, 0x1A,0x0E, 0x1B,0x04, 0x17,0x16, 0x1A,0x03, 0x1A,0x03, 0x1A,0x0E, 0x1B,0x04, 0x1A,0x03, 0x19,0x03, 0x17,0x03, 0x16,0x03, 0x0F,0x02,0x10,0x03, 0x15,0x00, 0x00,0x00 };
- //月亮代表我的心----鄧麗君unsigned char code Music_moon[] ={ 0x0F,0x03, 0x15,0x66, 0x17,0x03, 0x19,0x66, 0x15,0x03, 0x11,0x66, 0x17,0x03, 0x19,0x16, 0x19,0x03, 0x1A,0x66, 0x1B,0x03, 0x1F,0x66, 0x1A,0x03, 0x1A,0x04, 0x19,0x00, 0x17,0x03, 0x16,0x03, 0x15,0x66, 0x15,0x03, 0x15,0x02, 0x17,0x03, 0x16,0x03, 0x15,0x66, 0x15,0x03, 0x15,0x02, 0x16,0x03, 0x17,0x03, 0x17,0x04, 0x16,0x66, 0x15,0x03, 0x10,0x02, 0x17,0x02, 0x17,0x04, 0x16,0x14, 0x0F,0x17, 0x0F,0x03, 0x15,0x66, 0x17,0x03, 0x19,0x66, 0x15,0x03, 0x11,0x66, 0x17,0x03, 0x19,0x16, 0x19,0x03, 0x1A,0x66, 0x1B,0x03, 0x1F,0x66, 0x1A,0x03, 0x1A,0x04, 0x19,0x00, 0x17,0x03, 0x16,0x03, 0x15,0x66, 0x15,0x03, 0x15,0x02, 0x17,0x03, 0x16,0x03, 0x15,0x66, 0x15,0x03, 0x15,0x02, 0x16,0x03, 0x17,0x03, 0x17,0x04, 0x16,0x66, 0x10,0x03, 0x11,0x02, 0x15,0x0D, 0x16,0x03, 0x15,0x00, 0x19,0x02, 0x17,0x66, 0x16,0x03, 0x15,0x02, 0x19,0x02, 0x11,0x00, 0x10,0x03, 0x11,0x03, 0x10,0x66, 0x11,0x03, 0x10,0x02, 0x0F,0x02, 0x17,0x00, 0x19,0x02, 0x17,0x66, 0x16,0x03, 0x15,0x02, 0x19,0x02, 0x11,0x00, 0x10,0x03, 0x11,0x03, 0x15,0x66, 0x15,0x03, 0x15,0x66, 0x16,0x0E, 0x17,0x04, 0x17,0x04, 0x16,0x14, 0x0F,0x03, 0x15,0x66, 0x17,0x03, 0x19,0x66, 0x15,0x03, 0x11,0x66, 0x17,0x03, 0x19,0x66, 0x19,0x03, 0x1A,0x66, 0x1B,0x03, 0x1F,0x66, 0x1A,0x03, 0x1A,0x04, 0x19,0x00, 0x17,0x03, 0x16,0x03, 0x15,0x66, 0x15,0x03, 0x15,0x02, 0x17,0x03, 0x16,0x03, 0x15,0x66, 0x15,0x03, 0x15,0x02, 0x16,0x03, 0x17,0x03, 0x17,0x04, 0x16,0x66, 0x10,0x03, 0x11,0x02, 0x15,0x0D, 0x16,0x03, 0x16,0x03, 0x15,0x00, 0x17,0x03, 0x16,0x03, 0x15,0x66, 0x15,0x03, 0x15,0x02, 0x17,0x03, 0x16,0x03, 0x15,0x66, 0x15,0x03, 0x15,0x02, 0x16,0x03, 0x17,0x03, 0x17,0x04, 0x16,0x66, 0x10,0x03, 0x11,0x02, 0x15,0x0D, 0x16,0x03, 0x16,0x03, 0x15,0x00,0x00,0x00 };
- //偏偏喜歡你----陳百祥unsigned char code Music_like[] ={ 0x15,0x03, 0x10,0x03, 0x19,0x66, 0x1A,0x03, 0x19,0x02, 0x16,0x03, 0x15,0x03, 0x17,0x03, 0x16,0x03, 0x15,0x01, 0x15,0x03, 0x16,0x03, 0x10,0x66, 0x0F,0x03, 0x19,0x03, 0x17,0x03, 0x16,0x03, 0x17,0x03, 0x15,0x00, 0x0F,0x71, 0x0D,0x04, 0x15,0x66, 0x17,0x03, 0x16,0x03, 0x15,0x03, 0x10,0x0E, 0x0F,0x04, 0x0D,0x03, 0x0F,0x66, 0x10,0x03, 0x0F,0x02, 0x10,0x03, 0x0F,0x03, 0x19,0x66, 0x1F,0x03, 0x1A,0x03, 0x19,0x03, 0x17,0x0E, 0x16,0x04, 0x15,0x0D, 0x16,0x00, 0x16,0x03, 0x15,0x03, 0x19,0x66, 0x1A,0x03, 0x19,0x02, 0x1A,0x03, 0x19,0x03, 0x17,0x67, 0x16,0x04, 0x15,0x01, 0x15,0x03, 0x16,0x03, 0x10,0x66, 0x0F,0x03, 0x19,0x03, 0x17,0x03, 0x16,0x0E, 0x17,0x04, 0x10,0x03, 0x0F,0x00, 0x0F,0x67, 0x0D,0x04, 0x15,0x03, 0x10,0x03, 0x19,0x66, 0x1A,0x03, 0x19,0x02, 0x16,0x03, 0x15,0x03, 0x17,0x03, 0x16,0x03, 0x15,0x01, 0x15,0x03, 0x16,0x03, 0x10,0x66, 0x0F,0x03, 0x19,0x03, 0x17,0x03, 0x16,0x03, 0x17,0x03, 0x15,0x00, 0x0F,0x71, 0x0D,0x04, 0x15,0x66, 0x17,0x03, 0x16,0x03, 0x15,0x03, 0x10,0x0E, 0x0F,0x04, 0x0D,0x03, 0x0F,0x66, 0x10,0x03, 0x0F,0x02, 0x10,0x03, 0x0F,0x03, 0x19,0x66, 0x1F,0x03, 0x1A,0x03, 0x19,0x03, 0x17,0x0E, 0x16,0x04, 0x15,0x0D, 0x16,0x00, 0x16,0x03, 0x15,0x03, 0x19,0x66, 0x1A,0x03, 0x19,0x02, 0x1A,0x03, 0x19,0x03, 0x17,0x67, 0x16,0x04, 0x15,0x01, 0x15,0x03, 0x16,0x03, 0x10,0x66, 0x0F,0x03, 0x19,0x03, 0x17,0x03, 0x16,0x0E, 0x17,0x0E, 0x10,0x03, 0x0F,0x03, 0x19,0x03, 0x17,0x03, 0x16,0x03, 0x16,0x03, 0x1A,0x04, 0x15,0x00, 0x15,0x03, 0x15,0x03, 0x11,0x66, 0x11,0x03, 0x11,0x02, 0x16,0x03, 0x15,0x03, 0x11,0x03, 0x10,0x03, 0x10,0x15, 0x17,0x03, 0x16,0x66, 0x10,0x03, 0x16,0x02, 0x19,0x03, 0x1A,0x03, 0x17,0x00, 0x17,0x03, 0x17,0x03, 0x16,0x66, 0x16,0x03, 0x19,0x02, 0x16,0x03, 0x15,0x03, 0x15,0x66, 0x16,0x03, 0x17,0x01, 0x1A,0x03, 0x19,0x03, 0x18,0x03, 0x17,0x03, 0x16,0x66, 0x15,0x03, 0x1A,0x04, 0x15,0x00, 0x0F,0x03, 0x0D,0x03, 0x15,0x66, 0x17,0x03, 0x16,0x03, 0x15,0x03, 0x24,0x0E, 0x23,0x04, 0x21,0x03, 0x0F,0x66, 0x10,0x0D, 0x0F,0x02, 0x10,0x03, 0x0F,0x03, 0x19,0x66, 0x1F,0x03, 0x1A,0x03, 0x19,0x03, 0x17,0x0E, 0x16,0x04, 0x15,0x03, 0x16,0x15, 0x16,0x03, 0x17,0x0D, 0x18,0x03, 0x19,0x66, 0x1A,0x03, 0x19,0x02, 0x1A,0x03, 0x19,0x03, 0x17,0x67, 0x16,0x04, 0x15,0x01, 0x15,0x03, 0x11,0x03, 0x10,0x66, 0x0F,0x03, 0x19,0x03, 0x17,0x03, 0x16,0x03, 0x16,0x03, 0x1A,0x04, 0x15,0x14, 0x00,0x00};
- //飄雪----陳慧嫻unsigned char code Music_snow[] ={ 0x17,0x02, 0x16,0x03, 0x17,0x03, 0x15,0x01, 0x16,0x02, 0x19,0x03, 0x16,0x03, 0x17,0x02, 0x16,0x02, 0x15,0x01, 0x16,0x02, 0x10,0x02, 0x11,0x01, 0x15,0x02, 0x16,0x02, 0x17,0x03, 0x19,0x03, 0x1A,0x04, 0x1A,0x04, 0x1F,0x67, 0x19,0x02, 0x16,0x03, 0x17,0x03, 0x16,0x03, 0x17,0x0E, 0x16,0x04, 0x15,0x03, 0x16,0x03, 0x17,0x01, 0x17,0x03, 0x19,0x03, 0x1A,0x04, 0x1A,0x04, 0x1F,0x67, 0x19,0x02, 0x16,0x03, 0x17,0x03, 0x16,0x0D, 0x17,0x0E, 0x16,0x04, 0x15,0x03, 0x16,0x0E, 0x15,0x04, 0x15,0x01, 0x16,0x03, 0x17,0x03, 0x16,0x03, 0x15,0x03, 0x16,0x02, 0x15,0x03, 0x16,0x03, 0x17,0x04, 0x19,0x67, 0x17,0x03, 0x16,0x03, 0x17,0x02, 0x17,0x03, 0x19,0x03, 0x1A,0x02, 0x1A,0x03, 0x19,0x0E, 0x17,0x04, 0x17,0x02, 0x17,0x03, 0x19,0x03, 0x16,0x04, 0x17,0x67, 0x16,0x03, 0x15,0x03, 0x16,0x01, 0x17,0x03, 0x19,0x03, 0x1A,0x04, 0x1A,0x04, 0x1F,0x67, 0x19,0x02, 0x16,0x03, 0x17,0x03, 0x16,0x03, 0x17,0x0E, 0x16,0x04, 0x15,0x03, 0x16,0x03, 0x17,0x01, 0x17,0x03, 0x19,0x03, 0x1A,0x04, 0x1A,0x04, 0x1F,0x67, 0x19,0x02, 0x16,0x03, 0x17,0x03, 0x16,0x0D, 0x17,0x0E, 0x16,0x04, 0x15,0x03, 0x16,0x0E, 0x15,0x04, 0x15,0x01, 0x16,0x03, 0x17,0x03, 0x16,0x03, 0x15,0x03, 0x16,0x02, 0x15,0x03, 0x16,0x03, 0x17,0x04, 0x19,0x67, 0x17,0x03, 0x16,0x03, 0x17,0x02, 0x17,0x03, 0x19,0x03, 0x1A,0x02, 0x1A,0x03, 0x19,0x03, 0x17,0x04, 0x17,0x67, 0x17,0x03, 0x19,0x03, 0x16,0x04, 0x17,0x67, 0x16,0x03, 0x15,0x03, 0x16,0x01, 0x17,0x03, 0x19,0x03, 0x1A,0x03, 0x1F,0x03, 0x20,0x0C, 0x20,0x0E, 0x21,0x02, 0x20,0x03, 0x1F,0x04, 0x1A,0x04, 0x1F,0x0E, 0x1F,0x01, 0x20,0x03, 0x1F,0x03, 0x17,0x02, 0x17,0x03, 0x19,0x03, 0x16,0x03, 0x17,0x03, 0x17,0x03, 0x16,0x0E, 0x15,0x04, 0x15,0x00, 0x17,0x03, 0x19,0x03, 0x1A,0x03, 0x1F,0x03, 0x20,0x0C, 0x20,0x0E, 0x21,0x02, 0x20,0x03, 0x1F,0x04, 0x1A,0x04, 0x1F,0x0E, 0x1F,0x01, 0x20,0x03, 0x1F,0x03, 0x17,0x02, 0x17,0x03, 0x19,0x03, 0x16,0x03, 0x17,0x03, 0x19,0x03, 0x16,0x0E, 0x17,0x04,0x15,0x00, 0x00,0x00};
- //昨日重現(xiàn)unsigned char code Music_yesterday[]={ 0x15,0x03, 0x15,0x03, 0x16,0x03, 0x17,0x02, 0x19,0x02, 0x19,0x03, 0x17,0x03, 0x19,0x03, 0x17,0x03, 0x1A,0x02, 0x19,0x66, 0x17,0x02, 0x17,0x03, 0x19,0x03, 0x1A,0x02, 0x16,0x02, 0x17,0x03, 0x19,0x66, 0x1A,0x15, 0x17,0x03, 0x19,0x03, 0x1A,0x02, 0x21,0x02, 0x20,0x03, 0x1F,0x02, 0x1B,0x0D, 0x1B,0x66, 0x19,0x03, 0x17,0x03, 0x19,0x02, 0x17,0x0C, 0x16,0x14, 0x15,0x03, 0x15,0x03, 0x16,0x03, 0x17,0x03, 0x19,0x02, 0x19,0x0D, 0x19,0x03, 0x17,0x03, 0x19,0x03, 0x17,0x03, 0x1A,0x03, 0x19,0x02, 0x17,0x0D, 0x17,0x02, 0x17,0x03, 0x19,0x03, 0x1A,0x02, 0x1B,0x02, 0x17,0x03, 0x19,0x02, 0x1A,0x0D, 0x1A,0x01, 0x1B,0x02, 0x20,0x02, 0x1F,0x03, 0x1B,0x03, 0x1A,0x66, 0x1B,0x03, 0x1F,0x03, 0x1B,0x03, 0x1F,0x03, 0x1B,0x02, 0x1A,0x66, 0x1A,0x03, 0x1B,0x03, 0x1F,0x02, 0x1F,0x02, 0x1A,0x03, 0x1F,0x02, 0x20,0x0D, 0x20,0x16, 0x1F,0x02, 0x20,0x02, 0x21,0x03, 0x21,0x03, 0x21,0x03, 0x21,0x02, 0x20,0x03, 0x1F,0x03, 0x1B,0x0D, 0x1F,0x03, 0x1B,0x0D, 0x1A,0x66, 0x17,0x03, 0x19,0x0D, 0x19,0x14, 0x1F,0x03, 0x20,0x03, 0x21,0x03, 0x21,0x03, 0x21,0x03, 0x21,0x03, 0x21,0x02, 0x20,0x03, 0x1F,0x03, 0x1B,0x0D, 0x1F,0x03, 0x1B,0x03, 0x1A,0x66, 0x17,0x03, 0x19,0x0D, 0x19,0x14, 0x1A,0x03, 0x1B,0x03, 0x1F,0x03, 0x1B,0x03, 0x1F,0x03, 0x20,0x66, 0x1F,0x03, 0x1B,0x03, 0x1F,0x03, 0x1B,0x03, 0x1F,0x03, 0x20,0x66, 0x1F,0x03, 0x20,0x03, 0x21,0x02, 0x21,0x02, 0x20,0x03, 0x1F,0x02, 0x1A,0x0D, 0x1A,0x02, 0x17,0x02, 0x17,0x0D, 0x1A,0x03, 0x17,0x03, 0x19,0x0D, 0x19,0x14, 0x17,0x03, 0x17,0x03, 0x16,0x04, 0x15,0x0E, 0x15,0x03, 0x16,0x03, 0x17,0x0B, 0x17,0x0D, 0x18,0x0C, 0x16,0x0D, 0x16,0x14, 0x17,0x03, 0x17,0x03, 0x17,0x03, 0x18,0x02, 0x16,0x03, 0x16,0x16, 0x15,0x03, 0x17,0x03, 0x17,0x02, 0x19,0x02, 0x19,0x03, 0x17,0x03, 0x19,0x03, 0x17,0x03, 0x1A,0x02, 0x19,0x66, 0x17,0x02, 0x17,0x03, 0x19,0x03, 0x1A,0x02, 0x16,0x02, 0x17,0x03, 0x19,0x66, 0x1A,0x15, 0x17,0x03, 0x19,0x03, 0x1A,0x02, 0x21,0x02, 0x20,0x03, 0x1F,0x02, 0x1B,0x0D, 0x1B,0x66, 0x19,0x03, 0x17,0x03, 0x19,0x02, 0x17,0x0C, 0x16,0x14, 0x15,0x03, 0x15,0x03, 0x16,0x03, 0x17,0x03, 0x19,0x02, 0x19,0x0D, 0x19,0x03, 0x17,0x03, 0x19,0x03, 0x17,0x03, 0x1A,0x03, 0x19,0x02, 0x17,0x0D, 0x17,0x02, 0x17,0x03, 0x19,0x03, 0x1A,0x02, 0x1B,0x02, 0x17,0x03, 0x19,0x02, 0x1A,0x0D, 0x1A,0x01, 0x1B,0x02, 0x20,0x02, 0x1F,0x03, 0x1B,0x03, 0x1A,0x66, 0x1B,0x03, 0x1F,0x03, 0x1B,0x03, 0x1F,0x03, 0x1B,0x02, 0x1A,0x66, 0x1A,0x03, 0x1B,0x03, 0x1F,0x02, 0x1F,0x02, 0x1A,0x03, 0x1F,0x02, 0x20,0x0D, 0x20,0x16, 0x1F,0x02, 0x20,0x02, 0x21,0x03, 0x21,0x03, 0x21,0x03, 0x21,0x02, 0x20,0x03, 0x1F,0x03, 0x1B,0x0D, 0x1F,0x03, 0x1B,0x0D, 0x1A,0x66, 0x17,0x03, 0x19,0x0D, 0x19,0x14, 0x1F,0x03, 0x20,0x03, 0x21,0x03, 0x21,0x03, 0x21,0x03, 0x21,0x03, 0x21,0x02, 0x20,0x03, 0x1F,0x03, 0x1B,0x0D, 0x1F,0x03, 0x1B,0x03, 0x1A,0x66, 0x17,0x03, 0x19,0x0D, 0x19,0x14, 0x1A,0x03, 0x1B,0x03, 0x1F,0x03, 0x1B,0x03, 0x1F,0x03, 0x20,0x66, 0x1F,0x03, 0x1B,0x03, 0x1F,0x03, 0x1B,0x03, 0x1F,0x03, 0x20,0x66, 0x1F,0x03, 0x20,0x03, 0x21,0x02, 0x21,0x02, 0x20,0x03, 0x1F,0x02, 0x1A,0x0D, 0x1A,0x02, 0x17,0x02, 0x17,0x0D, 0x1A,0x03, 0x17,0x03, 0x19,0x0D, 0x19,0x14, 0x17,0x03, 0x17,0x03, 0x16,0x04, 0x15,0x0E, 0x15,0x03, 0x16,0x03, 0x17,0x0B, 0x17,0x0D, 0x18,0x0C, 0x16,0x0D, 0x16,0x01, 0x1F,0x02, 0x20,0x02, 0x21,0x03, 0x21,0x03, 0x21,0x03, 0x21,0x02, 0x20,0x03, 0x1F,0x03, 0x1B,0x0D, 0x1F,0x03, 0x1B,0x0D, 0x1A,0x02, 0x17,0x03, 0x19,0x0D, 0x19,0x14, 0x1F,0x03, 0x20,0x03, 0x21,0x03, 0x21,0x03, 0x21,0x03, 0x21,0x03, 0x21,0x02, 0x20,0x03, 0x1F,0x03, 0x1B,0x03, 0x1F,0x03, 0x1B,0x03, 0x1A,0x0D, 0x1A,0x02, 0x17,0x03, 0x19,0x0D, 0x19,0x14, 0x1F,0x02, 0x20,0x02, 0x21,0x03, 0x21,0x03, 0x21,0x03, 0x21,0x66, 0x20,0x03, 0x1F,0x03, 0x1B,0x0D, 0x1F,0x03, 0x1B,0x0D, 0x1A,0x66, 0x17,0x03, 0x19,0x0D, 0x19,0x00, 0x00,0x00 };
- //笑傲江湖----許冠杰unsigned char code Music_laugh[]={ 0x19,0x04, 0x1A,0x04, 0x1F,0x04, 0x20,0x04, 0x23,0x03, 0x20,0x03, 0x19,0x04, 0x1A,0x04, 0x1F,0x04, 0x20,0x04, 0x19,0x02, 0x1A,0x03, 0x1A,0x04, 0x19,0x04, 0x17,0x71, 0x16,0x04, 0x15,0x01, 0x17,0x67, 0x16,0x04, 0x15,0x03, 0x24,0x0E, 0x23,0x04, 0x0F,0x01, 0x0F,0x71, 0x10,0x04, 0x0F,0x71, 0x10,0x04, 0x15,0x71, 0x16,0x04, 0x17,0x0D, 0x19,0x03, 0x1A,0x71, 0x19,0x04, 0x17,0x0E, 0x16,0x04, 0x15,0x03, 0x16,0x01, 0x1A,0x03, 0x1A,0x04, 0x19,0x04, 0x17,0x71, 0x16,0x04, 0x15,0x01, 0x17,0x67, 0x16,0x04, 0x15,0x03, 0x24,0x0E, 0x23,0x04, 0x0F,0x01, 0x0F,0x71, 0x10,0x04, 0x0F,0x71, 0x10,0x04, 0x15,0x71, 0x16,0x04, 0x17,0x0D, 0x19,0x03, 0x1A,0x71, 0x19,0x04, 0x17,0x0E, 0x16,0x04, 0x15,0x03, 0x16,0x01, 0x1A,0x03, 0x1A,0x04, 0x19,0x04, 0x17,0x71, 0x16,0x04, 0x15,0x01, 0x17,0x67, 0x16,0x04, 0x15,0x03, 0x24,0x0E, 0x23,0x04, 0x0F,0x01, 0x0F,0x71, 0x10,0x04, 0x0F,0x71, 0x10,0x04, 0x15,0x71, 0x16,0x04, 0x17,0x0D, 0x19,0x03, 0x1A,0x71, 0x19,0x04, 0x17,0x0E, 0x16,0x04, 0x15,0x03, 0x16,0x01, 0x1A,0x03, 0x1A,0x04, 0x19,0x04, 0x17,0x71, 0x16,0x04, 0x15,0x01, 0x17,0x67, 0x16,0x04, 0x15,0x03, 0x24,0x0E, 0x23,0x04, 0x0F,0x01, 0x0F,0x71, 0x10,0x04, 0x0F,0x71, 0x10,0x04, 0x15,0x71, 0x16,0x04, 0x17,0x0D, 0x19,0x03, 0x1A,0x71, 0x19,0x04, 0x17,0x0E, 0x16,0x04, 0x15,0x03, 0x15,0x01, 0x10,0x04, 0x15,0x04, 0x16,0x04, 0x17,0x04, 0x10,0x04, 0x15,0x04, 0x16,0x04, 0x17,0x04, 0x10,0x04, 0x15,0x04, 0x16,0x04, 0x17,0x04, 0x10,0x04, 0x15,0x04, 0x16,0x04, 0x17,0x04, 0x1A,0x03, 0x1A,0x04, 0x19,0x04, 0x17,0x71, 0x16,0x04, 0x15,0x01, 0x17,0x67, 0x16,0x04, 0x15,0x03, 0x24,0x0E, 0x23,0x04, 0x0F,0x01, 0x0F,0x71, 0x10,0x04, 0x0F,0x71, 0x10,0x04, 0x15,0x71, 0x16,0x04, 0x17,0x0D, 0x19,0x03, 0x1A,0x71, 0x19,0x04, 0x17,0x0E, 0x16,0x04, 0x15,0x03, 0x16,0x01, 0x1A,0x03, 0x1A,0x04, 0x19,0x04, 0x17,0x71, 0x16,0x04, 0x15,0x01, 0x17,0x67, 0x16,0x04, 0x15,0x03, 0x24,0x0E, 0x23,0x04, 0x0F,0x01, 0x0F,0x71, 0x10,0x04, 0x0F,0x71, 0x10,0x04, 0x15,0x71, 0x16,0x04, 0x17,0x0D, 0x19,0x03, 0x1A,0x71, 0x19,0x04, 0x17,0x0E, 0x16,0x04, 0x15,0x03, 0x16,0x01, 0x1A,0x03, 0x1A,0x04, 0x19,0x04, 0x17,0x71, 0x16,0x04, 0x15,0x01, 0x17,0x67, 0x16,0x04, 0x15,0x03, 0x24,0x0E, 0x23,0x04, 0x0F,0x01, 0x0F,0x71, 0x10,0x04, 0x0F,0x71, 0x10,0x04, 0x15,0x71, 0x16,0x04, 0x17,0x0D, 0x19,0x03, 0x1A,0x71, 0x19,0x04, 0x17,0x0E, 0x16,0x04, 0x15,0x03, 0x16,0x01, 0x1A,0x03, 0x1A,0x04, 0x19,0x04, 0x17,0x71, 0x16,0x04, 0x15,0x01, 0x17,0x67, 0x16,0x04, 0x15,0x03, 0x24,0x0E, 0x23,0x04, 0x0F,0x01, 0x0F,0x71, 0x10,0x04, 0x0F,0x71, 0x10,0x04, 0x15,0x71, 0x16,0x04, 0x17,0x0D, 0x19,0x03, 0x1A,0x71, 0x19,0x04, 0x17,0x0E, 0x16,0x04, 0x15,0x03, 0x15,0x01,0x00,0x00 };
- //祝你生日快樂unsigned char code Music_happy[]={ 0x19,0x03, 0x19,0x03, 0x1A,0x02, 0x19,0x02, 0x1F,0x02, 0x1B,0x01, 0x19,0x03, 0x19,0x03, 0x1A,0x02, 0x19,0x02, 0x20,0x02, 0x1F,0x01, 0x19,0x03, 0x19,0x03, 0x23,0x02, 0x21,0x02, 0x1F,0x02, 0x1B,0x0C, 0x1A,0x15, 0x22,0x03, 0x22,0x03, 0x21,0x02, 0x1F,0x02, 0x20,0x02, 0x1F,0x15, 0x19,0x03, 0x19,0x03, 0x1A,0x02, 0x19,0x02, 0x1F,0x02, 0x1B,0x01, 0x19,0x03, 0x19,0x03, 0x1A,0x02, 0x19,0x02, 0x20,0x02, 0x1F,0x01, 0x19,0x03, 0x19,0x03, 0x23,0x02, 0x21,0x02, 0x1F,0x02, 0x1B,0x0C, 0x1A,0x15, 0x22,0x03, 0x22,0x03, 0x21,0x02, 0x1F,0x02, 0x20,0x02, 0x1F,0x15, 0x19,0x03, 0x19,0x03, 0x1A,0x02, 0x19,0x02, 0x1F,0x02, 0x1B,0x01, 0x19,0x03, 0x19,0x03, 0x1A,0x02, 0x19,0x02, 0x20,0x02, 0x1F,0x01, 0x19,0x03, 0x19,0x03, 0x23,0x02, 0x21,0x02, 0x1F,0x02, 0x1B,0x0C, 0x1A,0x15, 0x22,0x03, 0x22,0x03, 0x21,0x02, 0x1F,0x02, 0x20,0x02, 0x1F,0x15, 0x00,0x00 };//***********************************************************************************main(){ InitialSound();
- while(1) { BeepIO=1;//初始化蜂鳴器口 P0=0x00;//事先熄滅流水燈 Delay1ms(); Play(Music_happy,0,3,300);
- P0=0x00;//事先熄滅流水燈 Delay1ms(); Play(Music_Girl,0,3,330);
- Delay1ms(); Play(Music_laugh,0,3,240); Delay1ms(); Play(Music_Same,0,3,360); Delay1ms(); Play(Music_Two,0,3,320); Delay1ms(); Play(Music_moon,0,3,300); Delay1ms(); Play(Music_like,0,3,340); Delay1ms(); Play(Music_snow,0,3,340);
- Delay1ms(); Play(Music_yesterday,0,3,340); }}
