STC單片機做了一個關(guān)于PID控制氣壓的算法,led數(shù)據(jù)碼顯示
2017-6-14 16:34 上傳
2017-6-14 16:34 上傳
單片機源程序如下:
- #include "config.h"
- #include <math.h>
- #define ADC_POWER 0x80
- #define ADC_FLAG 0x10
- #define ADC_START 0x08
- #define ADC_SPEEDLL 0x00
- #define ADC_SPEEDL 0x20
- #define ADC_SPEEDH 0x40
- #define ADC_SPEEDHH 0x60
- unsigned char idata RsBuf[MAC_RX_BUF];
- unsigned char data guc_RsPoint=0;
- //unsigned char xdata Time0L1;
- //unsigned char xdata Time0H1;
- unsigned char xdata led_step=0;
- unsigned char xdata led_show1;
- unsigned char xdata led_show2;
- unsigned char xdata led_show3;
- unsigned char xdata led_show4;
- unsigned int xdata Time_Show=0;
- unsigned int xdata TimeMotor=0;
- unsigned int xdata PwmBitVat=0;
- //unsigned short xdata ADC_VAL[3];
- //unsigned char xdata ADC_ch=0;
- bit led_dian1;
- bit led_dian2;
- bit led_dian3;
- bit led_dian4;
- bit RsOver=0;
- typedef struct _pid_t
- float SetSpeed;//定義設(shè)定值
- float ActualSpeed;//定義實際值
- float err;//定義偏差值
- float err_last;//定義上一個偏差值
- float Kp,Ki,Kd;//定義比例、積分、微分系數(shù)
- float voltage;//定義電壓值(控制執(zhí)行器的變量)
- float integral;//定義積分值
- float umax;
- float umin;
- } pid_t;
- unsigned char code ledTab[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x27,0x7f,0x6f};
- void PID_init(pid_t *npid)
- npid->SetSpeed=0.0;
- npid->ActualSpeed=0.0;
- npid->err=0.0;
- npid->err_last=0.0;
- npid->voltage=0.0;
- npid->integral=0.0;
- npid->Kp=0.2;
- npid->Ki=0.015;
- npid->Kd=0.2;
- npid->umax=127;
- npid->umin=-127;
- float PID_realize(pid_t *npid ,float speed,float ActualSpeed)
- float index;
- npid->SetSpeed=speed;
- npid->ActualSpeed=ActualSpeed;
- npid->err=npid->SetSpeed-npid->ActualSpeed;
- if(npid->voltage>npid->umax)
- if(abs(npid->err)>200)//變積分過程
- index=0.0;
- else if(abs(npid->err)<180)
- index=1.0;
- if(npid->err<0)
- npid->integral+=npid->err;
- else
- index=(200-abs(npid->err))/20;
- if(npid->err<0)
- else if(npid->voltage<npid->umin)
- index=0.0;
- index=1.0;
- if(npid->err>0)
- else
- if(npid->err>0)
- else
- index=0.0;
- index=1.0;
- else
- npid->voltage=npid->Kp*npid->err+index*npid->Ki*npid->integral+npid->Kd*(npid->err-npid->err_last);
- npid->err_last=npid->err;
- return npid->voltage;
- void Delay_n_ms(unsigned int dly)
- unsigned int j;
- do
- j = MAIN_Fosc / 13000; //延時1ms, 主程序在此節(jié)拍下運行
- while(--j) ;
- }while(--dly);
- void InitUart(void)
- SCON = 0x50;//工作在串口模式
- T2L = (65536 - (MAIN_Fosc/4/BAUD)); //設(shè)置波特率為重新裝值
- T2H = (65536 - (MAIN_Fosc/4/BAUD))>>8;
- AUXR |= 0x14; //啟用定時器T2為1T模式, 并啟用定時器2
- AUXR |= 0x01; //選擇定時器2為串口1的波特率發(fā)生器
- ES = 1; //使能串口1為中斷
- void InitTime0(void)
- // #if 0
- // AUXR |= (1<<7); // Timer0 set as 1T mode
- // TMOD = 0x01; //16位,
- // //Timer0_16bit();
- // Time0L1=(65536-(MAIN_Fosc/1000000)*(TIME0_us1))%256;
- // Time0H1=(65536-(MAIN_Fosc/1000000)*(TIME0_us1))/256;
- // TL0=Time0L1;
- // TH0=Time0H1;
- // #endif
- T0_Load_us_12T(TIME0_us1);
- ET0 = 1; //Timer0 Interrupt Enable
- PT0 = 1; //高優(yōu)先級
- TR0 = 1; //Timer0 Run
- // ADC初始化函數(shù)
- void ADC_Init(void)
- // ADC_ch=0;
- // P1ASF=0x30;//設(shè)置P1為ADC
- // //P1ASF|=(1<<4)|(1<<5);
- // ADC_RES=0; // 清除結(jié)果寄存器
- // ADC_CONTR=ADC_POWER|ADC_SPEEDLL|ADC_START|4;
- // Delay_n_ms(20);
- // EADC=1;// EADC=1 允許ADC中斷
- //查詢方式
- P1ASF=0x30;//設(shè)置P1為ADC
- ADC_RES=0;
- ADC_RESL=0;
- ADC_CONTR=ADC_POWER|ADC_SPEEDLL;
- Delay_n_ms(20);
- void SendTxdBuf(unsigned char ASC) //發(fā)送-個ASCII
- ES = 0; //關(guān)閉串口中斷
- SBUF = ASC;
- while(TI ==0); //
- TI = 0; //
- ES = 1; //允許串口中斷
- void Rs_Do(void) interrupt 4 using 1 // 通訊中斷接收程序
- unsigned char data luc_temp;
- if(RI==1)
- RI=0;
- luc_temp = SBUF;
- if(guc_RsPoint>=MAC_RX_BUF)
- guc_RsPoint=0;
- if(luc_temp==0x0d)
- RsBuf[guc_RsPoint] = 0x0d;
- guc_RsPoint = 0;
- RsOver = 1;
- else
- RsBuf[guc_RsPoint++]=luc_temp;
- void ledTime()
- switch(led_step)
- case 0:
- DIG1=1;
- DIG2=0;
- DIG3=0;
- DIG4=0;
- P2=ledTab[led_show1];
- led_di=led_dian1;
- led_step=1;
- break;
- case 1:
- DIG1=0;
- DIG2=1;
- DIG3=0;
- DIG4=0;
- P2=ledTab[led_show2];
- led_di=led_dian2;
- led_step=2;
- break;
- case 2:
- DIG1=0;
- DIG2=0;
- DIG3=1;
- DIG4=0;
- P2=ledTab[led_show3];
- led_di=led_dian3;
- led_step=3;
- break;
- case 3:
- DIG1=0;
- DIG2=0;
- DIG3=0;
- DIG4=1;
- P2=ledTab[led_show4];
- led_di=led_dian4;
- led_step=0;
- break;
- void Time0Interrupt(void) interrupt 1 using 3
- //TR0=0;
- ledTime();
- if(Time_Show>0)
- Time_Show--;
- if(PwmBitVat>TimeMotor)
- MOTOR1=1;
- else
- MOTOR1=0;//低電平打開電機
- if(PwmBitVat++>256)
- PwmBitVat=0;
- //TL0=Time0L1;
- //TH0=Time0H1;
- //TR0=1;
- //void ADC_ISR() interrupt 5
- // ADC_CONTR &= ~ADC_FLAG;
- // switch(ADC_ch)
- // case 0:
- // ADC_ch=1;
- // ADC_VAL[0]=(ADC_RES<<2)|(ADC_RESL&0x03);
- // ADC_CONTR = ADC_POWER | ADC_SPEEDLL | 5 | ADC_START;
- // break;
- // case 1:
- // ADC_ch=0;
- // ADC_VAL[1]=(ADC_RES<<2)|(ADC_RESL&0x03);
- // ADC_CONTR = ADC_POWER | ADC_SPEEDLL | 4 | ADC_START;
- // break;
- void led_showP(float fshowPa)
- static float tmp_showPa=-1;
- float tmp_show=fshowPa;
- float temp_dian;
- unsigned char shorteger,shordian;
- if(fshowPa==tmp_showPa)
- return;
- tmp_showPa=fshowPa;
- shorteger=(unsigned char)abs((int)fshowPa);
- temp_dian=tmp_show-(float)shorteger;
- led_show1=shorteger/10;
- led_show2=shorteger%10;
- led_dian1=0;
- led_dian2=1;
- //小數(shù)點后兩位
- shordian=(unsigned char)(temp_dian*100.0);
- led_show3=shordian/10;
- led_show4=shordian%10;
- led_dian3=0;
- led_dian4=0;
- unsigned short GetADCResult(unsigned char ch)
- ADC_CONTR = ADC_POWER | ADC_SPEEDLL | ch | ADC_START;
- while(!(ADC_CONTR&ADC_FLAG));
- ADC_CONTR &= ~ADC_FLAG;
- return (ADC_RES<<2)|(ADC_RESL&0x03);
- //-20-0 0.5=4.5(102.4-921.6)
- void main(void)
- unsigned short xdata sensorV;
- unsigned short xdata RtV;
- unsigned char xdata TimeShowRt=0;
- float xdata Actual;
- float xdata tmp_TimeMotor;
- float xdata SetSpeed;
- char xdata tmp_SetSpeed=-128;
- float xdata getSpeed;
- pid_t xdata gpid;
- //GPIO1
- PP1(0);//輸出
- PP1(1);//輸出
- PP1(2);//輸出
- PP1(3);//輸出
- RP1(4);//輸入
- RP1(5);//輸入
- //GPIO2
- PP2(0);//輸出
- PP2(1);//輸出
- PP2(2);//輸出
- PP2(3);//輸出
- PP2(4);//輸出
- PP2(5);//輸出
- PP2(6);//輸出
- PP2(7);//輸出
- //GPIO3
- PP3(2);//輸出
- PP3(3);//輸出
- PP3(4);//輸出
- PP3(5);//輸出
- RP3(6);//輸入
- PP3(7);//輸出
- InitUart();
- InitTime0();
- ADC_Init();
- EA = 1; // 打開總中斷
- SendTxdBuf(0x89);
- RtV=GetADCResult(4);
- SetSpeed=0.019531*RtV-20.0;
- tmp_SetSpeed=(char)SetSpeed;
- PID_init(&gpid);
- gpid.Kp=0.4;//作用是加快系統(tǒng)的響應速度,提高系統(tǒng)的調(diào)節(jié)精度,副作用是會導致超調(diào);
- gpid.Ki=0.2;//作用是消除穩(wěn)態(tài)誤差,副作用是導致積分飽和現(xiàn)象
- gpid.Kd=0.2;//作用是改善系統(tǒng)的動態(tài)性能,副作用是延長系統(tǒng)的調(diào)節(jié)時間
復制代碼
軟件.rar
(112.24 KB, 下載次數(shù): 71)
2017-6-14 15:39 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
