看看吧,注意仿真要proteus8.6以上才能打開.
2017-6-21 17:44 上傳
單片機源程序如下:
- #include <REG51.H>
- #include <intrins.h>
- //#include "LCD1602.h"
- //#include "DS1302.h"
- #define uint unsigned int
- #define uchar unsigned char
- sbit DS1302_CLK = P1^7; //實時時鐘時鐘線引腳
- sbit DS1302_IO = P1^6; //實時時鐘數(shù)據(jù)線引腳
- sbit DS1302_RST = P1^5; //實時時鐘復位線引腳
- sbit wireless_1 = P3^0;
- sbit wireless_2 = P3^1;
- sbit wireless_3 = P3^2;
- sbit wireless_4 = P3^3;
- sbit ACC0 = ACC^0;
- sbit ACC7 = ACC^7;
- char hide_sec,hide_min,hide_hour,hide_day,hide_week,hide_month,hide_year; //秒,分,時到日,月,年位閃的計數(shù)
- sbit Set = P2^0; //模式切換鍵
- sbit Up = P2^1; //加法按鈕
- sbit Down = P2^2; //減法按鈕
- sbit out = P2^3; //立刻跳出調(diào)整模式按鈕
- sbit DQ = P1^0; //溫度傳送數(shù)據(jù)IO口
- char done,count,temp,flag,up_flag,down_flag;
- uchar temp_value; //溫度值
- uchar TempBuffer[5],week_value[2];
- void show_time(); //液晶顯示程序
- /***********1602液晶顯示部分子程序****************/
- //Port Definitions**********************************************************
- sbit LcdRs = P2^5;
- sbit LcdRw = P2^6;
- sbit LcdEn = P2^7;
- sfr DBPort = 0x80; //P0=0x80,P1=0x90,P2=0xA0,P3=0xB0.數(shù)據(jù)端口
- //內(nèi)部等待函數(shù)**************************************************************************
- unsigned char LCD_Wait(void)
- LcdRs=0;
- LcdRw=1; _nop_();
- LcdEn=1; _nop_();
- LcdEn=0;
- return DBPort;
- //向LCD寫入命令或數(shù)據(jù)************************************************************
- #define LCD_COMMAND 0 // Command
- #define LCD_DATA 1 // Data
- #define LCD_CLEAR_SCREEN 0x01 // 清屏
- #define LCD_HOMING 0x02 // 光標返回原點
- void LCD_Write(bit style, unsigned char input)
- LcdEn=0;
- LcdRs=style;
- LcdRw=0; _nop_();
- DBPort=input; _nop_();//注意順序
- LcdEn=1; _nop_();//注意順序
- LcdEn=0; _nop_();
- LCD_Wait();
- //設(shè)置顯示模式************************************************************
- #define LCD_SHOW 0x04 //顯示開
- #define LCD_HIDE 0x00 //顯示關(guān)
- #define LCD_CURSOR 0x02 //顯示光標
- #define LCD_NO_CURSOR 0x00 //無光標
- #define LCD_FLASH 0x01 //光標閃動
- #define LCD_NO_FLASH 0x00 //光標不閃動
- void LCD_SetDisplay(unsigned char DisplayMode)
- LCD_Write(LCD_COMMAND, 0x08|DisplayMode);
- //設(shè)置輸入模式************************************************************
- #define LCD_AC_UP 0x02
- #define LCD_AC_DOWN 0x00 // default
- #define LCD_MOVE 0x01 // 畫面可平移
- #define LCD_NO_MOVE 0x00 //default
- void LCD_SetInput(unsigned char InputMode)
- LCD_Write(LCD_COMMAND, 0x04|InputMode);
- //初始化LCD************************************************************
- void LCD_Initial()
- LcdEn=0;
- LCD_Write(LCD_COMMAND,0x38); //8位數(shù)據(jù)端口,2行顯示,5*7點陣
- LCD_SetDisplay(LCD_SHOW|LCD_NO_CURSOR); //開啟顯示, 無光標
- LCD_Write(LCD_COMMAND,LCD_CLEAR_SCREEN); //清屏
- LCD_SetInput(LCD_AC_UP|LCD_NO_MOVE); //AC遞增, 畫面不動
- //液晶字符輸入的位置************************
- void GotoXY(unsigned char x, unsigned char y)
- if(y==0)
- LCD_Write(LCD_COMMAND,0x80|x);
- if(y==1)
- LCD_Write(LCD_COMMAND,0x80|(x-0x40));
- //將字符輸出到液晶顯示
- void Print(unsigned char *str)
- while(*str!='\0')
- LCD_Write(LCD_DATA,*str);
- str++;
- /***********DS1302時鐘部分子程序******************/
- typedef struct __SYSTEMTIME__
- unsigned char Second;
- unsigned char Minute;
- unsigned char Hour;
- unsigned char Week;
- unsigned char Day;
- unsigned char Month;
- unsigned char Year;
- unsigned char DateString[11];
- unsigned char TimeString[9];
- }SYSTEMTIME; //定義的時間類型
- SYSTEMTIME CurrentTime;
- #define AM(X) X
- #define PM(X) (X+12) // 轉(zhuǎn)成24小時制
- #define DS1302_SECOND 0x80 //時鐘芯片的寄存器位置,存放時間
- #define DS1302_MINUTE 0x82
- #define DS1302_HOUR 0x84
- #define DS1302_WEEK 0x8A
- #define DS1302_DAY 0x86
- #define DS1302_MONTH 0x88
- #define DS1302_YEAR 0x8C
- void DS1302InputByte(unsigned char d) //實時時鐘寫入一字節(jié)(內(nèi)部函數(shù))
- unsigned char i;
- ACC = d;
- for(i=8; i>0; i--)
- DS1302_IO = ACC0; //相當于匯編中的 RRC
- DS1302_CLK = 1;
- DS1302_CLK = 0;
- ACC = ACC >> 1;
- unsigned char DS1302OutputByte(void) //實時時鐘讀取一字節(jié)(內(nèi)部函數(shù))
- unsigned char i;
- ACC = ACC >>1; //相當于匯編中的 RRC
- ACC7 = DS1302_IO;
- DS1302_CLK = 1;
- DS1302_CLK = 0;
- return(ACC);
- void Write1302(unsigned char ucAddr, unsigned char ucDa) //ucAddr: DS1302地址, ucData: 要寫的數(shù)據(jù)
- DS1302_RST = 0;
- DS1302_CLK = 0;
- DS1302_RST = 1;
- DS1302InputByte(ucAddr); // 地址,命令
- DS1302InputByte(ucDa); // 寫1Byte數(shù)據(jù)
- DS1302_CLK = 1;
- DS1302_RST = 0;
- unsigned char Read1302(unsigned char ucAddr) //讀取DS1302某地址的數(shù)據(jù)
- unsigned char ucData;
- DS1302_RST = 0;
- DS1302_CLK = 0;
- DS1302_RST = 1;
- DS1302InputByte(ucAddr|0x01); // 地址,命令
- ucData = DS1302OutputByte(); // 讀1Byte數(shù)據(jù)
- DS1302_CLK = 1;
- DS1302_RST = 0;
- return(ucData);
- void DS1302_GetTime(SYSTEMTIME *Time) //獲取時鐘芯片的時鐘數(shù)據(jù)到自定義的結(jié)構(gòu)型數(shù)組
- unsigned char ReadValue;
- ReadValue = Read1302(DS1302_SECOND);
- Time->Second = ((ReadValue&0x70)>>4)*10 + (ReadValue&0x0F);
- ReadValue = Read1302(DS1302_MINUTE);
- Time->Minute = ((ReadValue&0x70)>>4)*10 + (ReadValue&0x0F);
- ReadValue = Read1302(DS1302_HOUR);
- Time->Hour = ((ReadValue&0x70)>>4)*10 + (ReadValue&0x0F);
- ReadValue = Read1302(DS1302_DAY);
- Time->Day = ((ReadValue&0x70)>>4)*10 + (ReadValue&0x0F);
- ReadValue = Read1302(DS1302_WEEK);
- Time->Week = ((ReadValue&0x70)>>4)*10 + (ReadValue&0x0F);
- ReadValue = Read1302(DS1302_MONTH);
- Time->Month = ((ReadValue&0x70)>>4)*10 + (ReadValue&0x0F);
- ReadValue = Read1302(DS1302_YEAR);
- Time->Year = ((ReadValue&0x70)>>4)*10 + (ReadValue&0x0F);
- void DateToStr(SYSTEMTIME *Time) //將時間年,月,日,星期數(shù)據(jù)轉(zhuǎn)換成液晶顯示字符串,放到數(shù)組里DateString[]
- { if(hide_year<2) //這里的if,else語句都是判斷位閃爍,<2顯示數(shù)據(jù),>2就不顯示,輸出字符串為 2007/07/22
- Time->DateString[0] = '2';
- Time->DateString[1] = '0';
- Time->DateString[2] = Time->Year/10 + '0';
- Time->DateString[3] = Time->Year%10 + '0';
- else
- Time->DateString[0] = ' ';
- Time->DateString[1] = ' ';
- Time->DateString[2] = ' ';
- Time->DateString[3] = ' ';
- Time->DateString[4] = '/';
- if(hide_month<2)
- Time->DateString[5] = Time->Month/10 + '0';
- Time->DateString[6] = Time->Month%10 + '0';
- else
- Time->DateString[5] = ' ';
- Time->DateString[6] = ' ';
- Time->DateString[7] = '/';
- if(hide_day<2)
- Time->DateString[8] = Time->Day/10 + '0';
- Time->DateString[9] = Time->Day%10 + '0';
- else
- Time->DateString[8] = ' ';
- Time->DateString[9] = ' ';
- if(hide_week<2)
- week_value[0] = Time->Week%10 + '0'; //星期的數(shù)據(jù)另外放到 week_value[]數(shù)組里,跟年,月,日的分開存放,因為等一下要在最后顯示
- else
- week_value[0] = ' ';
- week_value[1] = '\0';
- Time->DateString[10] = '\0'; //字符串末尾加 '\0' ,判斷結(jié)束字符
- void TimeToStr(SYSTEMTIME *Time) //將時,分,秒數(shù)據(jù)轉(zhuǎn)換成液晶顯示字符放到數(shù)組 TimeString[];
- { if(hide_hour<2)
- Time->TimeString[0] = Time->Hour/10 + '0';
- Time->TimeString[1] = Time->Hour%10 + '0';
- else
- Time->TimeString[0] = ' ';
- Time->TimeString[1] = ' ';
復制代碼
溫度計.zip
(225.25 KB, 下載次數(shù): 64)
2017-6-21 14:42 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
