經(jīng)測試 可以使用
2017-6-21 17:29 上傳
部分stm32單片機(jī)源程序預(yù)覽如下:
- /******************** (C) COPYRIGHT 2010 STMicroelectronics ********************
- * File Name : main.c
- * Author : MCD Application Team
- * Version : V3.1.1
- * Date : 04/07/2010
- * Description : Mass Storage demo main file
- * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
- * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
- * AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
- * INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
- * CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
- * INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
- /* Includes ------------------------------------------------------------------*/
- #include "main.h"
- #include "usb_lib.h"
- #include "hw_config.h"
- #include "usb_pwr.h"
- #include "sdcard.h"
- //#include "lcd.h"
- #include "ff.h"
- //#include "pic.h"
- //#include "book.h"
- #include <stdio.h>
- #include <string.h>
- static vu32 TimingDelay = 0;
- extern SD_CardInfo SDCardInfo;
- extern SD_Error Status ;
- extern u8 ASCII_Table[95][16];
- FATFS fs;
- FIL fsrc, fdst; // file objects
- BYTE buffer[1024]; // file copy buffer
- FRESULT res; // FatFs function common result code
- UINT br, bw; // File R/W count
- BYTE buff_filename[15][20]; //最多只能讀9個文件,保存9個文件名,文件名采用短文件名,最多13個字符
- extern uint16_t MAL_Init (uint8_t lun);
- /* Private typedef -----------------------------------------------------------*/
- /* Private define ------------------------------------------------------------*/
- /* Private macro -------------------------------------------------------------*/
- /* Private variables ---------------------------------------------------------*/
- /* Extern variables ----------------------------------------------------------*/
- /* Private function prototypes -----------------------------------------------*/
- /* Private functions ---------------------------------------------------------*/
- //#define Lcd_On GPIO_SetBits(GPIOB,GPIO_Pin_5);
- //#define Lcd_Off GPIO_ResetBits(GPIOB,GPIO_Pin_5);
- //#define Pow_On GPIO_SetBits(GPIOD,GPIO_Pin_3);
- //#define Pow_Off GPIO_ResetBits(GPIOD,GPIO_Pin_3);
- //#define Set_Rst GPIO_SetBits(GPIOF,GPIO_Pin_11);
- //#define Clr_Rst GPIO_ResetBits(GPIOF,GPIO_Pin_11);
- u8 stringcopy(BYTE *buff_to,BYTE *buff_from)
- u8 i=0;
- for(i=0;i<13;i++)
- buff_to[i] = buff_from[i];
- return 1;
- void ReadSDFile(void)
- // FIL file;
- FILINFO finfo;
- DIR dirs;
- int i_name=0;
- // char *fn;
- XCHAR path[50]={"picture"};
- disk_initialize(0);
- f_mount(0, &fs);
- res = f_opendir(&dirs, path);
- if (res == FR_OK)
- while (f_readdir(&dirs, &finfo) == FR_OK)
- if (finfo.fattrib & AM_ARC)
- if(!finfo.fname[0]) //文件名不為空,如果為空,則表明該目錄下面的文件已經(jīng)讀完了
- break;
- //res = f_open(&fsrc, finfo.lfname, FA_OPEN_EXISTING | FA_READ);
- stringcopy(buff_filename[i_name], (BYTE*)finfo.fname);
- i_name++;
- // res = f_read(&fsrc, &buffer, 50, &br);
- f_close(&fsrc);
- f_mount(0,NULL);
- void ReadSDFiles(void)
- f_mount(0, &fs);
- res = f_open(&fsrc,"picture/test.txt",FA_OPEN_EXISTING | FA_READ);
- res = f_read(&fsrc, &buffer,9, &br);
- f_close(&fsrc);
- f_mount(0,NULL);
- void WriteSDFile(void)
- FIL file;
- // FILINFO finfo;
- //DIR dirs;
- // int i_name=0;
- //char *fn;
- //XCHAR path[50]={"picture"};
- res = f_mount(0, &fs);
- res = f_open(&file, "1055.txt", FA_CREATE_ALWAYS | FA_WRITE); //創(chuàng)建一個新的文件
- res = f_lseek(&file,file.fsize);
- f_printf (&file,"20100508sdsd看看看%s\r\n" );
- f_close(&file);
- f_mount(0, NULL);
- *sd init and config
- SD_Error SD_InitAndConfig(void)
- //////// SDCARD Initialisation //////////////////////////////////////
- /////////////////Section adapted from ST example/////////////////////
- /*-------------------------- SD Init ----------------------------- */
- Status = SD_Init();
- if (Status == SD_OK)
- /*----------------- Read CSD/CID MSD registers ------------------*/
- Status = SD_GetCardInfo(&SDCardInfo);
- /*----------------- Select Card --------------------------------*/
- Status = SD_SelectDeselect((u32) (SDCardInfo.RCA << 16));
- Status = SD_EnableWideBusOperation(SDIO_BusWide_4b);
- /* Set Device Transfer Mode to DMA */
- Status = SD_SetDeviceMode(SD_DMA_MODE);//oet
- // Status = SD_SetDeviceMode(SD_POLLING_MODE);
- // Status = SD_SetDeviceMode(SD_INTERRUPT_MODE);
- return Status;
- *Usb Connect
- void UsbConnect(void)
- USB_Cable_Config(ENABLE);
- USB_Init();
- while (bDeviceState != CONFIGURED);
- * Delay ms us
- void delay_us(unsigned long i)
- while( i--)
- // 毫秒級延時(shí)函數(shù)
- void delay_ms(unsigned long time)
- while(time--)
- delay_us(1000);
- * Function Name : Delay
- * Description : Inserts a delay time.
- * Input : nCount: specifies the delay time length (time base 10 ms).
- * Output : None
- * Return : None
- void Delay(u32 nCount)
- delay_ms(nCount*10);
- * Function Name : main.
- * Description : Main routine.
- * Input : None.
- * Output : None.
- * Return : None.
- int main(void)
- Set_System();
- Set_USBClock();
- USB_Interrupts_Config();
- //Pow_On;
- SD_InitAndConfig();
- USB_Init();
- //Set_Rst;
- // Delay(20);
- //Clr_Rst;
- // Delay(20);
- // Set_Rst;
- // Delay(20);
- // STM3210E_LCD_Init();
- // LCD_Clear(Black);
- // Lcd_On;
- // LCD_SetBackColor(Black);
- //LCD_SetTextColor(Yellow);
- // ReadSDFile();
- WriteSDFile();
- //delay_ms(500);
- // LCD_DisplayStringLine(Line0,"File read success");
- // LCD_DisplayStringLine(Line1,buff_filename[0]);
- // LCD_DisplayStringLine(Line2,buff_filename[1]);
- // LCD_DisplayStringLine(Line3," ");
- // LCD_DisplayStringLine(Line4," ");
- // LCD_DisplayStringLine(Line3,buff_filename[2]);
- // LCD_DisplayStringLine(Line4,buff_filename[3]);
- // LCD_DisplayStringLine(Line5,buff_filename[4]);
- // LCD_DisplayStringLine(Line6,buff_filename[5]);
M3_SDIO USB FATFS.rar
(734.01 KB, 下載次數(shù): 176)
2017-6-21 17:52 上傳
點(diǎn)擊文件名下載附件
可用 下載積分: 黑幣 -5
