基于51單片機(jī)12c5a60s2的彩燈帶流水,可調(diào)節(jié)亮度,可用手機(jī)進(jìn)行控制,手動(dòng)調(diào)節(jié)pwm,自動(dòng)調(diào)節(jié)
2017-6-22 19:17 上傳
調(diào)光基于12c5a60s2程序:
- #include<STC12C5A60S2.h>
- //#include<LCD1602.h>
- #include<PWM.h>
- #include<ADC.h>
- #include<intrins.h>
- #define uchar unsigned char
- #define uint unsigned int
- #define FSCLK 11059200
- #define Number 29
- unsigned char Receive,i;
- unsigned int n,flag;
- unsigned char Receive_table[15];
- #define RELOAD_COUNT 0xFA
- sbit LED0=P0^2;
- sbit DAI = P3^2;
- sbit k1=P2^0;
- sbit k2=P2^1;
- sbit k3=P2^2;
- sbit k4=P2^3;
- sbit k5=P2^4;
- sbit k6=P2^5;
- sbit k7=P2^6;
- sbit k8=P2^7;
- sbit p13=P1^3;
- uint speed = 0;
- uchar flag_clr = 0;
- uchar Table_R[8]={ 0, 0,255, 0,255,255,255,0};
- uchar Table_G[8]={255, 0, 0,255, 0,255,255,0};
- uchar Table_B[8]={ 0,255, 0,255,255, 0,255,0};
- uchar code Table[256] = {
- 0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,
- 20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,
- 40,41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,
- 60,61,62,63,64,65,66,67,68,69,70,71,72,73,74,75,76,77,78,79,
- 80,81,82,83,84,85,86,87,88,89,90,91,92,93,94,95,96,97,98,99,
- 100,101,102,103,104,105,106,107,108,109,110,111,112,113,114,115,116,117,118,119,
- 120,121,122,123,124,125,126,127,128,129,130,131,132,133,134,135,136,137,138,139,
- 140,141,142,143,144,145,146,147,148,149,150,151,152,153,154,155,156,157,158,159,
- 160,161,162,163,164,165,166,167,168,169,170,171,172,173,174,175,176,177,178,179,
- 180,181,182,183,184,185,186,187,188,189,190,191,192,193,194,195,196,197,198,199,
- 200,201,202,203,204,205,206,207,208,209,210,211,212,213,214,215,216,217,218,219,
- 220,221,222,223,224,225,226,227,228,229,230,231,232,233,234,235,236,237,238,239,
- 240,241,242,243,244,245,246,247,248,249,250,251,252,253,254,255
- unsigned char CCAPOH,ID;
- float res0,res1;
- ** 函數(shù)功能 :延時(shí)函數(shù)
- ** 函數(shù)說(shuō)明 :利用軟件延時(shí),占用CPU,經(jīng)調(diào)試最小單位大約為1ms
- ** 入口參數(shù) :time:需要延時(shí)的時(shí)間,單位ms
- ** 出口參數(shù) :無(wú)
- void Delay_ms(uint time)
- uint i,j;
- for(i = 0;i < time;i ++)
- for(j = 0;j < 930;j ++);
- void ms_delay(unsigned int t)
- unsigned int i,j;
- for(i=t;i>0;i--)
- for(j=110;j>0;j--);
- void us_delay(unsigned int t)
- while(t--);
- void rst()
- uint s;
- DAI=0;
- for(s=0;s<1000;s++);
- {_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();}
- void Delay_Fash (uint x) // 1ms Delay
- uint t;
- t = 0;
- while (x--)
- for (t = 0; t < 5000; t++);
- void Delay(uint x) // 1ms Delay
- uint t;
- t = 0;
- while (x--)
- for (t = 0; t < 330; t++);
- /*uart初始化*/
- void Uart_Init()//使用獨(dú)立的波特率發(fā)生器(STC12C560S2或帶有獨(dú)立波特率發(fā)生器//、//的單片機(jī)均可)
- SCON=0x50; //設(shè)置為串行口以方式1工作,8位異步通訊,允許接收中斷。
- PCON=0x80; //SMOD波特率選擇位為1,SMOD=1.
- BRT=0xfa;//波特率9600 256-晶振頻率/波特率x16=BRT
- AUXR=0x11; //T0、T1不12分頻,速度是89C51的12倍,啟動(dòng)獨(dú)立波特率//發(fā)生器,每個(gè)時(shí)鐘計(jì)數(shù)一次
- //設(shè)置串口1的波特率發(fā)生器為獨(dú)立波特率發(fā)生器,
- // AUXR1=0x80; //切換到P1口
- ES=1; //開(kāi)啟串口中斷
- EA=1; //開(kāi)啟總中斷
- void Send_Uart(unsigned char value){//向WIFI模塊發(fā)送數(shù)據(jù)
- ES=0;
- TI=0;
- SBUF=value;//發(fā)送完后TI變1
- while(!TI);
- TI=0;
- ES=1;
- /*給esp8266發(fā)送指令*/
- void ESP8266_Set(unsigned char *puf)
- while(*puf){
- Send_Uart(*puf);
- us_delay(5);
- puf++;
- us_delay(5);
- Send_Uart('\r');
- us_delay(5);
- Send_Uart('\n');
- ms_delay(20000);
- void code0()
- DAI=1;
- _nop_();
- DAI=0;
- _nop_(); _nop_();_nop_();_nop_();
- _nop_();_nop_();_nop_();_nop_();
- void code1()
- DAI=1;
- DAI=0;
- _nop_();_nop_(); _nop_(); _nop_();
- //打開(kāi)燈
- void bright()
- { unsigned int j;
- for(j=0;j<720;j++)code1();
- //關(guān)閉燈函數(shù)
- void dark()
- { unsigned int j;
- for(j=0;j<720;j++)code0();
- void send_2811_24bits(uchar dat1,uchar dat2,uchar dat3)
- uchar a;
- // uchar b;
- for(a=0;a<8;a++) //dat1
- if(dat1&0x80)
- code1();
- else
- code0();
- dat1=dat1<<1;
- for(a=0;a<8;a++) //dat2
- if(dat2&0x80)
- code1();
- else
- code0();
- dat2=dat2<<1;
- for(a=0;a<8;a++) //dat3
- if(dat3&0x80)
- code1();
- else
- code0();
- dat3=dat3<<1;
- void Jump()
- uint i;
- uchar Colour = 0; //這個(gè)參數(shù)值域:0~7
- uchar Count = 0; //跳變次數(shù) //這個(gè)參數(shù)值域:0~1
- speed = 150;
- while(1)
- { if(k5==0)
- Delay_ms(5);
- if(k5==0)
- return;
- ID=0;
- for(i=0;i<50;i++) //Number = 50
- send_2811_24bits(Table_R[Colour],Table_G[Colour],Table_B[Colour]);
- rst();
- Delay(speed);
- Colour++;
- if(Colour>=7)
- Colour = 0;
- Count++;
- if(Count>1)
- Count = 0;
- return;
- void Flow()
- uint i,Stack;
- uchar Colour1,Colour2;
- Stack = 0;
- Colour1 = 0;
- Colour2 = 6;
- speed=5; //17
- while(1)
- { if(k5==0)
- Delay_ms(5);
- if(k5==0)
- return;
- ID=0;
- for(i=0;i<Number;i++)
- if(i<Stack)
- send_2811_24bits(Table_R[Colour1],Table_G[Colour1],Table_B[Colour1]);
- else
- send_2811_24bits(Table_R[Colour2],Table_G[Colour2],Table_B[Colour2]);
- rst();
- Delay_Fash(speed);
- Stack++;
- if(Stack>Number)
- Stack = 1;
- Colour2 = Colour1;
- Colour1++;
- if(Colour1>6)
- return;
- void Pass()
- int i,Stack,Stack_Buf;
- uchar Pass_Sec;
- char Colour,Colour_Buf;
- uchar TIMES=0;
- Pass_Sec = 12;
- Colour_Buf = 0;
- Stack_Buf = 0;
- speed = 5;
- while(1)
- { if(k5==0)
- Delay_ms(5);
- if(k5==0)
- return;
- ID=0;
- Stack = Stack_Buf;
- Colour = Colour_Buf;
- Stack++;
- if(Stack > Pass_Sec)
- Stack = 0;
- Colour++;
- if(Colour>6)
- Colour=0;
- rst();
- Stack_Buf--;
- if(Stack_Buf<0)
- Stack_Buf = Pass_Sec;
- Colour_Buf--;
- if(Colour_Buf<0)
- Colour_Buf = 6;
- if(Colour_Buf==0)
- TIMES++;
- if(TIMES>1)
- return;
- void Case()
- int i,Stack,Stack_Buf,TIMES;
- uchar Pass_Sec;
- TIMES=0;
- Pass_Sec=7;
- Colour_Buf=0;
- Stack_Buf=0;
- speed=10;
- while(1)
- if(k5==0)
- Delay_ms(5);
- if(k5==0)
- return;
- ID=0;
- Stack=Stack_Buf;
- Colour=Colour_Buf;
- if(Stack<4)
- else
- send_2811_24bits(255,255,255);
- Stack++;
- if(Stack>Pass_Sec)
- Stack=0;
- rst();
- Stack_Buf--;
- if(Stack_Buf<0)
- Stack_Buf=Pass_Sec;
- TIMES++;
- if(TIMES>120)
- TIMES=0;
- Colour_Buf++;
- if(Colour_Buf>5)
- return;
- void adchange()
- res0=GetADCResult(ADC_CH0);
- CCAP0H =256-ADC_RES;
- res1=GetADCResult(ADC_CH1);
- void key()
- if(CCAP0H<255)
- if(k1==0)
- Delay_ms(5);
- if(k1==0)
- CCAP0H++;
- if( CCAP0H>0)
- if(k2==0)
- Delay_ms(5);
- if(k2==0)
- CCAP0H--;
- void changecolour1()
- {unsigned char i;
- rst();
- for(i=0;i<30;i++)
- if(k5==0)
- Delay_ms(5);
- if(k5==0)
- return;
- ID=0;
- send_2811_24bits(0,255,0);
- void changecolour2()
- {unsigned char i;
- rst();
- for(i=0;i<30;i++)
- if(k5==0)
- Delay_ms(5);
- if(k5==0)
- return;
- ID=0;
- send_2811_24bits(0,0,255);
- void changecolour3()
- {unsigned char i;
- rst();
- for(i=0;i<30;i++)
- if(k5==0)
- Delay_ms(5);
- if(k5==0)
- return;
- ID=0;
- send_2811_24bits(255,0,0);
- void shouji()
- if(Receive=='0')
- ID=6;
- CCAP0H=30;
- if(Receive=='1')
- ID=6;
- CCAP0H=60;
- if(Receive=='2')
- ID=6;
- CCAP0H=90;
- if(Receive=='3')
- ID=6;
- CCAP0H=120;
- if(Receive=='4')
- ID=6;
- CCAP0H=150;
- if(Receive=='5')
- ID=6;
- CCAP0H=180;
- if(Receive=='6')
- ID=6;
- CCAP0H=210;
- if(Receive=='7')
- ID=6;
- CCAP0H=254;
- if(Receive=='d')
- ID=6;
- CCAP0H=0;
- void main()
- CCAP0H=254;
- ID=0;
- TMOD|=0X10;
- TH1=0XFC; //給定時(shí)器賦初值,定時(shí)1ms
- TL1=0X18;
- EA=1;
- TR1=1;
- ET1=1;
- Uart_Init();
- PCA_init();
- Timer0_init();
- ADC_Init(ADC_PORT0 | ADC_PORT1); //配置通道P1^0 ,P1^1 為AD采集口,如要配置其他其他口,直接用或運(yùn)算加進(jìn)初始化函數(shù)中
- ESP8266_Set("AT+CWMODE=3");//選擇wifi應(yīng)用模式,此時(shí)為STA模式
- ms_delay(3000);
- // ESP8266_Set("AT+RST");
- ESP8266_Set("AT+CWJAP=\"WIFI\",\"12345678\"");//連接網(wǎng)絡(luò)
- ms_delay(15000);
- ESP8266_Set("AT+CIPMUX=0");//設(shè)置單連接模式,透?jìng)髦荒茉趩芜B接模式下進(jìn)行
- ms_delay(5000);
- ESP8266_Set("AT+CIPMODE=1");//設(shè)置透?jìng)髂J?br />
- ms_delay(5000);
- ESP8266_Set("AT+CIPSTART=\"TCP\",\"10.50.84.160\",8080");//連接到服務(wù)器
- while(1)
- shouji();
- switch(ID)
- case(0):bright();key();break;
- case(1):bright();adchange();break;
- case(2):Flow();Case();Pass();Jump();break;
- case(3):changecolour1();break;
- case(4):changecolour2();break;
- case(5):changecolour3();break;
- case(6):bright();break;
- void timer1() interrupt 3
- if(k3==0)
- Delay_ms(5);
- if(k3==0)
- ID=1;
全部資料下載地址:
調(diào)光基于12c5a60s2.zip
(60.05 KB, 下載次數(shù): 309)
2017-6-22 15:32 上傳
點(diǎn)擊文件名下載附件
程序代碼60s2 下載積分: 黑幣 -5
