查看: 2891|回復(fù): 2
單片機(jī)數(shù)字時(shí)鐘實(shí)例
ID:214780 發(fā)表于 2017-6-26 15:21 | 只看該作者 回帖獎(jiǎng)勵(lì) |正序?yàn)g覽 |閱讀模式
  1. #include "reg51.h"
  2. #include "intrins.h"
  3. sbit EN = P1^0;
  4. unsigned char Hour=0,Minute=0,Second=0,FLAG = 0;
  5. unsigned long int count0;
  6. /*************  數(shù)碼管數(shù)值數(shù)組**************/
  7. unsigned char code Number[]={
  8. //   0    1    2    3    4    5    6    7    8    9    A    B    C    D    E    F
  9.     0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x77,0x7C,0x39,0x5E,0x79,0x71};
  10. void Delay100ms();
  11. void ini_init();
  12. void display();
  13. void delay(unsigned int i);
  14.
  15. int main()
  16. {
  17.         char i;
  18.         ini_init();
  19.         while(1)
  20.         {
  21.                 display();
  22.                 switch(P1)
  23.                 {
  24.                         case 0XFE:while(P1==0XFE);TR1 = ~TR1;        break;
  25.                         case 0XFD:while(P1==0XFD);Hour++;Hour>=24?(Hour = 0):(Hour = Hour);        break;
  26.                         case 0XFB:while(P1==0XFB);Minute++;(Minute>=60)?(Minute = 0):(Minute = Minute);        break;
  27.                         case 0XF7:while(P1==0XF7);Second++;(Second>=60)?(Second = 0):(Second = Second);        break;
  28.                         case 0XEF:while(P1==0XEF);Hour = Minute = Second =0;break;
  29.                         case 0X7F:while(P1==0X7F);P2=0X00;P0 = 0X00; TR1 = 0;FLAG = ~FLAG;break;
  30.                         default:
  31.                                 break;
  32.                 }
  33.         }
  34. }
  35. void Delay100ms()                //@11.0592MHz
  36. {
  37.         unsigned char i, j, k;
  38.         _nop_();
  39.         _nop_();
  40.         i = 5;
  41.         j = 52;
  42.         k = 195;
  43.         do
  44.         {
  45.                 do
  46.                 {
  47.                         while (--k);
  48.                 } while (--j);
  49.         } while (--i);
  50. }
  51. void ini_init()
  52. {
  53.         TMOD&=0x00;
  54.         TMOD|=0x20;
  55.         TH1=(256-250)>>8;
  56.         TL1=(256-250);
  57.         TR1=0;
  58.         ET1=1;
  59.   EA = 1;                         //open global interrupt switch
  60. }
  61. void T1_isr() interrupt 3
  62. {
  63.         if(count0--==0)
  64.         {
  65.                 count0 = 4000;
  66.                 Second++;
  67.                 if(Second>=60)
  68.                 {
  69.                         Second = 0;
  70.                         Minute++;
  71.                         if(Minute>=60)
  72.                         {
  73.                                 Minute=0;
  74.                                 Hour++;
  75.                                 if(Hour>=24)
  76.                                         Hour = 0;
  77.                         }
  78.                 }
  79.
  80.         }
  81. }
  82. void delay(unsigned int i)
  83. {
  84.     char j;
  85.     for(i; i > 0; i--)
  86.         for(j = 200; j > 0; j--);
  87. }
  88. void display()
  89. {
  90.         if(FLAG == 0)
  91.         {
  92.                 P2 = 0X7F;
  93.                 P0 = Number[Hour/10];
  94.                 delay(100);
  95.
  96.                 P2 = 0XBF;
  97.                 P0 = Number[Hour%10];
  98.                 delay(100);
  99.
  100.                 P2 = 0XEF;
  101.                 P0 = Number[Minute/10];
  102. ……………………
  103. …………限于本文篇幅 余下代碼請從51黑下載附件…………
數(shù)字電子鐘.rar (27.05 KB, 下載次數(shù): 25)
ID:284994 發(fā)表于 2018-3-30 12:13 | 只看該作者
怎么不發(fā)圖呢?
ID:296909 發(fā)表于 2018-3-26 19:12 | 只看該作者
原理圖呢
