#include<reg52.h>
sbit sw_0=P3^3;//開關(guān)端口定義 switch
sbit sw_1=P3^4;
sbit sw_2=P3^5;
sbit sw_3=P3^6;
//sbit PS0=P2^4;
//sbit PS1=P2^5;
//sbit PS2=P2^6;
//sbit PS3=P2^7;
sfr P_data=0x80;
sbit P_K_L=P2^2;
uchar code tab[]={0xfc,0x60,0xda,0xf2,0x66,0xb6,0xbe,0xe0,0xfe,0xf6,0xee,0x3e,0x9c,0x7a,0x9e,0x8e}; //字段轉(zhuǎn)換表
uchar rec[50]; //不能超過50
uchar code error[]={0x40,0x30,0x46,0x2a,0x2a,0x37,0x36,0x0d}; //數(shù)據(jù)不正確
uchar send[]={0x40,0x30,0x46,0x30,0x32,0x00,0x00,0x00,0x00,0x00,0x00,0x0d}; //正確的數(shù)據(jù)
uchar i;
uchar t;
uint sw_in(void); //開關(guān)量輸入采集
void display(uint);
void delay(uint);
uint dth(uint); //16~10
uchar ath(uchar,uchar); //ASCII~16
uint hta(uchar); //16~ASCII
void uart(void);
void main(void)
uint a,b,c,t;
TMOD=0x20;
TL1=0xfd;
TH1=0xfd;
SCON=0x50;
TR1=1; //為1是定時器T1開始計數(shù);0時不計數(shù)。
IE=0x90;
c=sw_in();
t=dth(c);
a=hta(t>>8);
send[5]=a>>8;
send[6]=(uchar)a;
a=hta(t);
send[7]=a>>8;
send[8]=(uchar)a;
b=0;
for(a=1;a<9;a++)
b^=send[a];
b=hta(b);
send[9]=b>>8;
send[10]=(uchar)b;
for(a=0;a<100;a++)
display(c);
//數(shù)碼管顯示函數(shù)沒寫
uint dth(uint a)
uint b,c;
b=a%16;
if(b>9)
c=b+6;
c=b;
a=a/16;
b=a%16;
if(b>9)
c+=(b+6)*10;
c=c+b*100;
a=a/16;
b=a%16;
if(b>9)
c+=(b+6)*1000;
c=c+b*1000;
return c;
void delay(uint delay_time)
for(delay_time=20;delay_time>0;delay_time--)
uchar ath(uchar a,uchar b)
if(a<0x40)
a-=0x30;
else if(a<0x47)
a-=0x37;
else if(a<67)
a-=0x57;
if(b<0x40)
b=-0x30;
else if(b<0x47)
b-=0x37;
else if(b<67)
b-=0x57;
return((a<<4)+b);
uint hta(uchar a)
uint b;
b=a>>4;
a&=0x0f;
if(a<0x0a)
a+=0x30;
a+=0x37;
if(b<0x0a)
b+=0x30;
b+=0x37;
b=((b<<8)+a);
return b;
void uart(void) interrupt 4 //檢查過了
uchar a,b;
if(RI)
a=SBUF;
RI=0;
if(a==0x40)//
i=0;
rec[i]=a;
i++;
if(a==0x0d)//
if(ath(rec[1],rec[2])==15)
b=0;
for(a=1;a<i-3;a++)
b^=rec[a];
if(b==ath(rec[i-3],rec[i-2]))
if((ath(rec[3],rec[4])&0x01)==0) //
for(a=0;a<12;a++) //
SBUF=send[a];
while(TI!=1);
TI=0;
else //
for(a=0;a<8;a++) //
SBUF=error[a];
while(TI!=1);
TI=0;
TI=0;
開關(guān)量輸入,pc端和單片機相連
