查看: 1925|回復(fù): 0
簡(jiǎn)易計(jì)算器
ID:216174 發(fā)表于 2017-6-30 18:28 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include <reg52.h>
sbit leden=P2^7;
sbit rs=P2^5;
sbit wr=P2^6;
//sbit busy=P0^7;
uchar i,j,num,num_1,temp;
long a,b, c;
float a_c,b_c;
uchar flag,fuhao;
uchar code table[]={7,8,9,0,
                    4,5,6,0,
                                        1,2,3,0};
uchar code table1[]={7,8,9,0x2f-0x30,
                     4,5,6,0x2a-0x30,
                                         1,2,3,0x2d-0x30,
                                         0x01-0x30,0,0x3d-0x30,0x2b-0x30};
void delay(uchar n)
uchar i,j;
for(i=n;i>0;i--)
    for(j=200;j>0;j--) ;
void check()
do{P0=0xff;
    rs=0;wr=1;leden=0;delay(5);leden=1;}while(busy==1);
void write(uint w)
   rs=0;
   wr=0;
   leden=0;
   P0=w;
   leden=1;
   delay(10);//check();
   leden=0;
void write_data(uint q)
   wr=0;
   leden=0;
   P0=q;
   leden=1;
     delay(10);
   leden=0;
void init()
          num=1;
   leden=1;
   write(0x38);
   write(0x08);
   write(0x01);
   write(0x06);
   write(0x0f);
   num_1=0;
   i=0;j=0;a=0;b=0;c=0;flag=0;fuhao=0;
void keyscan()
   P1=0Xfe;
   if(P1!=0xfe)
    delay(10);
        if(P1!=0xfe)
          temp=P1&0xf0;
          switch(temp)
                case 0xe0:num=0;break;
                case 0xd0:num=1;break;
                case 0xb0:num=2;break;
                case 0x70:num=3;break;
        while(P1!=0xfe);
        if(num==0||num==2||num==1)
          if(j!=0)
            write(0x01);
                j=0;
          if(flag==0)
            a=a*10+table[num];
             b=b*10+table[num];
           flag=1;
           fuhao=4;//????;
         i=table1[num];
         write_data(0x30+i);
          P1=0xfd;
   if(P1!=0xfd)
    delay(10);
        if(P1!=0xfd)
          temp=P1&0xf0;
          switch(temp)
                case 0xe0:num=4;break;
                case 0xd0:num=5;break;
                case 0xb0:num=6;break;
                case 0x70:num=7;break;
        while(P1!=0xfd);
        if(num==4||num==5||num==6)
         if(j!=0)
            write(0x01);
                j=0;
          if(flag==0)
            a=a*10+table[num];
             b=b*10+table[num];
           flag=1;
           fuhao=3;//????;
         i=table1[num];
         write_data(0x30+i);
   P1=0xfb;
  if(P1!=0xfb)
    delay(10);
        if(P1!=0xfb)
          temp=P1&0xf0;
          switch(temp)
                case 0xe0:num=8;break;
                case 0xd0:num=9;break;
                case 0xb0:num=10;break;
                case 0x70:num=11;break;
        while(P1!=0xfb);
        if(num==8||num==9||num==10)
         if(j!=0)
            write(0x01);
                j=0;
          if(flag==0)
            a=a*10+table[num];
             b=b*10+table[num];
         else if(num==11)
           flag=1;
           fuhao=2;//jian???;
         i=table1[num];
         write_data(0x30+i);
        P1=0xf7;
    if(P1!=0xf7)
    delay(10);
        if(P1!=0xf7)
          temp=P1&0xf0;
          switch(temp)
                case 0xe0:num=12;break;
                case 0xd0:num=13;break;
                case 0xb0:num=14;break;
                case 0x70:num=15;break;
        while(P1!=0xf7);
   switch(num)
     case 12:{write(0x01);a=0;b=0;flag=0;fuhao=0;}break;
         case 13:
                           if(flag==0)
                             {a=a/10;write_data(0x30);}
                           else if(flag==1)
                             {b=b*10;write_data(0x30);}
                        } break;
         case 14: {j=1;
                    if(fuhao==1)
                                {write(0x80+0x4f);write(0x04);c=a+b;
                                  while(c!=0)
                                         write_data(0x30+c%10);
                                         c=c/10;
                                 write_data(0x3d);a=0;b=0;flag=0;fuhao=0;}
                                else if(fuhao==2)
                                {write(0x80+0x4b);write(0x04);
                                  if(a-b>0)
                                     {c=a-b;}
                                  else { c=b-a;        }
                                  while(c!=0)
                                         c=c/10;
                                  if(a-b<0)
                                 write_data(0x2d);write_data(0x3d);a=0;b=1;flag=0;fuhao=0;}
                                 else if(fuhao==3)
                                 {write(0x80+0x4f);write(0x04);c=a*b;
                                  while(c!=0)
                                         c=c/10;
                                 else if(fuhao==4)
                                  write(0x80+0x4f);write(0x04);        i=0;
                                  c=a/b/c;
                                  while(c!=0)
                                         c=c/10;
                                          i++;
                                          if(i==3)
                                             write(0x2e);
                                  if(a/b<=0)
                                 write_data(0x30);write_data(0x3d);a=0;b=0;flag=0;fuhao=0;
                                 } break;
        case 15:{write_data(0x30+table1[num]);flag=1;fuhao=1;}        break;
   P1=0xf0;
  init();
    keyscan()
