#include "24l01.h"
#include "lcd.h"
#include "delay.h"
#include "spi.h"
#include "usart.h"
const u8 TX_ADDRESS[TX_ADR_WIDTH]={0x34,0x43,0x10,0x10,0x01}; //發(fā)送地址
const u8 RX_ADDRESS[RX_ADR_WIDTH]={0x34,0x43,0x10,0x10,0x01};
//初始化24L01的IO口
void NRF24L01_Init(void)
SPI_InitTypeDef SPI_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB|RCC_APB2Periph_GPIOG, ENABLE); //使能PB,G端口時鐘
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12; //PB12上拉 防止W25X的干擾
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽輸出
GPIO_Init(GPIOB, &GPIO_InitStructure); //初始化指定IO
GPIO_SetBits(GPIOB,GPIO_Pin_12);//上拉
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7|GPIO_Pin_8; //PG8 7 推挽
GPIO_Init(GPIOG, &GPIO_InitStructure);//初始化指定IO
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD; //PG6 輸入
GPIO_ResetBits(GPIOG,GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8);//PG6,7,8上拉
SPI2_Init(); //初始化SPI
SPI_Cmd(SPI2, DISABLE); // SPI外設(shè)不使能
SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex; //SPI設(shè)置為雙線雙向全雙工
SPI_InitStructure.SPI_Mode = SPI_Mode_Master; //SPI主機
SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b; //發(fā)送接收8位幀結(jié)構(gòu)
SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low; //時鐘懸空低
SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge; //數(shù)據(jù)捕獲于第1個時鐘沿
SPI_InitStructure.SPI_NSS = SPI_NSS_Soft; //NSS信號由軟件控制
SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_16; //定義波特率預(yù)分頻的值:波特率預(yù)分頻值為16
SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; //數(shù)據(jù)傳輸從MSB位開始
SPI_InitStructure.SPI_CRCPolynomial = 7; //CRC值計算的多項式
SPI_Init(SPI2, &SPI_InitStructure); //根據(jù)SPI_InitStruct中指定的參數(shù)初始化外設(shè)SPIx寄存器
SPI_Cmd(SPI2, ENABLE); //使能SPI外設(shè)
NRF24L01_CE=0; //使能24L01
NRF24L01_CSN=1; //SPI片選取消
//檢測24L01是否存在
//返回值:0,成功;1,失敗
u8 NRF24L01_Check(void)
u8 buf[5]={0XA5,0XA5,0XA5,0XA5,0XA5};
u8 i;
SPI2_SetSpeed(SPI_BaudRatePrescaler_4); //spi速度為9Mhz(24L01的最大SPI時鐘為10Mhz)
NRF24L01_Write_Buf(NRF_WRITE_REG+TX_ADDR,buf,5);//寫入5個字節(jié)的地址.
NRF24L01_Read_Buf(TX_ADDR,buf,5); //讀出寫入的地址
for(i=0;i<5;i++)if(buf!=0XA5)break;
if(i!=5)return 1;//檢測24L01錯誤
return 0; //檢測到24L01
//SPI寫寄存器
//reg:指定寄存器地址
//value:寫入的值
u8 NRF24L01_Write_Reg(u8 reg,u8 value)
u8 status;
NRF24L01_CSN=0; //使能SPI傳輸
status =SPI2_ReadWriteByte(reg);//發(fā)送寄存器號
SPI2_ReadWriteByte(value); //寫入寄存器的值
NRF24L01_CSN=1; //禁止SPI傳輸
return(status); //返回狀態(tài)值
//讀取SPI寄存器值
//reg:要讀的寄存器
u8 NRF24L01_Read_Reg(u8 reg)
u8 reg_val;
NRF24L01_CSN = 0; //使能SPI傳輸
SPI2_ReadWriteByte(reg); //發(fā)送寄存器號
reg_val=SPI2_ReadWriteByte(0XFF);//讀取寄存器內(nèi)容
NRF24L01_CSN = 1; //禁止SPI傳輸
return(reg_val); //返回狀態(tài)值
//在指定位置讀出指定長度的數(shù)據(jù)
//reg:寄存器(位置)
//*pBuf:數(shù)據(jù)指針
//len:數(shù)據(jù)長度
//返回值,此次讀到的狀態(tài)寄存器值
u8 NRF24L01_Read_Buf(u8 reg,u8 *pBuf,u8 len)
u8 status,u8_ctr;
status=SPI2_ReadWriteByte(reg);//發(fā)送寄存器值(位置),并讀取狀態(tài)值
for(u8_ctr=0;u8_ctr<len;u8_ctr++)pBuf[u8_ctr]=SPI2_ReadWriteByte(0XFF);//讀出數(shù)據(jù)
NRF24L01_CSN=1; //關(guān)閉SPI傳輸
return status; //返回讀到的狀態(tài)值
//在指定位置寫指定長度的數(shù)據(jù)
//reg:寄存器(位置)
//len:數(shù)據(jù)長度
u8 NRF24L01_Write_Buf(u8 reg, u8 *pBuf, u8 len)
u8 status,u8_ctr;
status = SPI2_ReadWriteByte(reg);//發(fā)送寄存器值(位置),并讀取狀態(tài)值
for(u8_ctr=0; u8_ctr<len; u8_ctr++)SPI2_ReadWriteByte(*pBuf++); //寫入數(shù)據(jù)
NRF24L01_CSN = 1; //關(guān)閉SPI傳輸
//啟動NRF24L01發(fā)送一次數(shù)據(jù)
//txbuf:待發(fā)送數(shù)據(jù)首地址
//返回值:發(fā)送完成狀況
u8 NRF24L01_TxPacket(u8 *txbuf)
u8 sta;
SPI2_SetSpeed(SPI_BaudRatePrescaler_8);//spi速度為9Mhz(24L01的最大SPI時鐘為10Mhz)
NRF24L01_CE=0;
NRF24L01_Write_Buf(WR_TX_PLOAD,txbuf,TX_PLOAD_WIDTH);//寫數(shù)據(jù)到TX BUF 32個字節(jié)
NRF24L01_CE=1;//啟動發(fā)送
while(NRF24L01_IRQ!=0);//等待發(fā)送完成
sta=NRF24L01_Read_Reg(STATUS); //讀取狀態(tài)寄存器的值
NRF24L01_Write_Reg(NRF_WRITE_REG+STATUS,sta); //清除TX_DS或MAX_RT中斷標(biāo)志
if(sta&MAX_TX)//達(dá)到最大重發(fā)次數(shù)
NRF24L01_Write_Reg(FLUSH_TX,0xff);//清除TX FIFO寄存器
return MAX_TX;
if(sta&TX_OK)//發(fā)送完成
return TX_OK;
return 0xff;//其他原因發(fā)送失敗
//返回值:0,接收完成;其他,錯誤代碼
u8 NRF24L01_RxPacket(u8 *rxbuf)
u8 sta;
SPI2_SetSpeed(SPI_BaudRatePrescaler_8); //spi速度為9Mhz(24L01的最大SPI時鐘為10Mhz)
if(sta&RX_OK)//接收到數(shù)據(jù)
NRF24L01_Read_Buf(RD_RX_PLOAD,rxbuf,RX_PLOAD_WIDTH);//讀取數(shù)據(jù)
NRF24L01_Write_Reg(FLUSH_RX,0xff);//清除RX FIFO寄存器
return 0;
return 1;//沒收到任何數(shù)據(jù)
//該函數(shù)初始化NRF24L01到RX模式
//設(shè)置RX地址,寫RX數(shù)據(jù)寬度,選擇RF頻道,波特率和LNA HCURR
//當(dāng)CE變高后,即進入RX模式,并可以接收數(shù)據(jù)了
void NRF24L01_RX_Mode(void)
NRF24L01_CE=0;
NRF24L01_Write_Buf(NRF_WRITE_REG+RX_ADDR_P0,(u8*)RX_ADDRESS,RX_ADR_WIDTH);//寫RX節(jié)點地址
NRF24L01_Write_Reg(NRF_WRITE_REG+EN_AA,0x01); //使能通道0的自動應(yīng)答
NRF24L01_Write_Reg(NRF_WRITE_REG+EN_RXADDR,0x01);//使能通道0的接收地址
NRF24L01_Write_Reg(NRF_WRITE_REG+RF_CH,40); //設(shè)置RF通信頻率
NRF24L01_Write_Reg(NRF_WRITE_REG+RX_PW_P0,RX_PLOAD_WIDTH);//選擇通道0的有效數(shù)據(jù)寬度
NRF24L01_Write_Reg(NRF_WRITE_REG+RF_SETUP,0x0f);//設(shè)置TX發(fā)射參數(shù),0db增益,2Mbps,低噪聲增益開啟
NRF24L01_Write_Reg(NRF_WRITE_REG+CONFIG, 0x0f);//配置基本工作模式的參數(shù);PWR_UP,EN_CRC,16BIT_CRC,接收模式
NRF24L01_CE = 1; //CE為高,進入接收模式
//該函數(shù)初始化NRF24L01到TX模式
//設(shè)置TX地址,寫TX數(shù)據(jù)寬度,設(shè)置RX自動應(yīng)答的地址,填充TX發(fā)送數(shù)據(jù),選擇RF頻道,波特率和LNA HCURR
//PWR_UP,CRC使能
//CE為高大于10us,則啟動發(fā)送.
void NRF24L01_TX_Mode(void)
NRF24L01_CE=0;
NRF24L01_Write_Buf(NRF_WRITE_REG+TX_ADDR,(u8*)TX_ADDRESS,TX_ADR_WIDTH);//寫TX節(jié)點地址
NRF24L01_Write_Buf(NRF_WRITE_REG+RX_ADDR_P0,(u8*)RX_ADDRESS,RX_ADR_WIDTH); //設(shè)置TX節(jié)點地址,主要為了使能ACK
NRF24L01_Write_Reg(NRF_WRITE_REG+EN_RXADDR,0x01); //使能通道0的接收地址
NRF24L01_Write_Reg(NRF_WRITE_REG+SETUP_RETR,0x1a);//設(shè)置自動重發(fā)間隔時間:500us + 86us;最大自動重發(fā)次數(shù):10次
NRF24L01_Write_Reg(NRF_WRITE_REG+RF_CH,40); //設(shè)置RF通道為40
NRF24L01_Write_Reg(NRF_WRITE_REG+RF_SETUP,0x0f); //設(shè)置TX發(fā)射參數(shù),0db增益,2Mbps,低噪聲增益開啟
NRF24L01_Write_Reg(NRF_WRITE_REG+CONFIG,0x0e); //配置基本工作模式的參數(shù);PWR_UP,EN_CRC,16BIT_CRC,接收模式,開啟所有中斷
NRF24L01_CE=1;//CE為高,10us后啟動發(fā)送
,我主要是想實現(xiàn)目的,能移植成功夠就行 |
