查看: 1793|回復(fù): 0
單片機跑馬燈程序
ID:216758 發(fā)表于 2017-7-3 12:59 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
單片機跑馬燈
單片機源程序如下:
  1. #include "stc_ice.h"
  2. extern void TIM2_INIT (void);                //聲明完成定時器/計數(shù)器2初始化的函數(shù)
  3. extern bit second_ok;                                                //聲明外部位變量second_ok
  4. void change_LED (void);                                 //聲明變換LED狀態(tài)的函數(shù)
  5. sbit beep = P1^6;
  6. u8 bdata led = 0x80;
  7. sbit led_7 = led^7;
  8. sbit led_6 = led^6;
  9. sbit led_5 = led^5;
  10. sbit led_4 = led^4;
  11. sbit led_3 = led^3;
  12. sbit led_2 = led^2;
  13. sbit led_1 = led^1;
  14. sbit led_0 = led^0;
  15. void main (void)
  16. {
  17.         beep = 0;
  18.         TIM2_INIT ();        //調(diào)用完成定時器/計數(shù)器2初始化的函數(shù)
  19.         while (1)
  20.         {
  21.                 if (second_ok)                                                         //1秒定時到
  22.                         change_LED ();
  23.         }
  24. }
  25. void change_LED (void)
  26. {
  27.         second_ok = 0;
  28.         if ((led <<= 1) == 0)
  29.                 led = 1;
  30.         #if IAP15f
  31.                 P37 = ~led_7;
  32.                 P36 = ~led_6;
  33.                 P35 = ~led_5;
  34.                 P34 = ~led_4;
  35.                 P33 = ~led_3;
  36.                 P32 = ~led_2;
  37. ……………………
  38. …………限于本文篇幅 余下代碼請從51黑下載附件…………
第一章--跑馬燈.zip (58.17 KB, 下載次數(shù): 6)
