這個(gè)是我用3天時(shí)間設(shè)計(jì)完成基于單片機(jī)的籃球計(jì)分器設(shè)計(jì),
可以實(shí)現(xiàn)A B隊(duì)加分,減分。利用LCD1602顯示開場(chǎng)字幕,比賽節(jié)數(shù),雙方比分,比賽倒計(jì)時(shí),交換場(chǎng)地,有計(jì)時(shí)電路,記分電路,顯示電路等。
文件包含程序代碼和proteus仿真.
2017-7-5 20:10 上傳
2017-7-5 20:10 上傳
2017-7-5 20:09 上傳
- #include<reg52.h>
- #define uint unsigned int
- #define uchar unsigned char
- uchar code table[]=".. Play ball! ..";
- uchar code table1[]="!!GO GO GO!!" ;
- sbit key_ST=P1^5; //功能鍵(開始/暫停)
- sbit key_A1=P1^0; //功能鍵(A隊(duì)分?jǐn)?shù)加1)
- sbit key_A2=P1^3; //功能鍵(A隊(duì)分?jǐn)?shù)加2)
- sbit key_1A=P1^6; //功能鍵(A隊(duì)分?jǐn)?shù)減1)
- sbit key_B1=P1^1; //功能鍵(B隊(duì)分?jǐn)?shù)加1)
- sbit key_B2=P1^4; //功能鍵(B隊(duì)分?jǐn)?shù)加2)
- sbit key_1B=P1^7; //功能鍵(B隊(duì)分?jǐn)?shù)減1)
- sbit key_EX=P1^2; //功能鍵(交換場(chǎng)地,A/B兩隊(duì)分?jǐn)?shù)交換)
- sbit key_JS=P3^0; //功能鍵(比賽節(jié)數(shù)加1)
- sbit lcdrs=P3^5; //LCD顯示的數(shù)據(jù)/命令選擇端
- sbit lcden=P3^4; //LCD顯示的使能信號(hào)
- uchar flag,ms,mg,ss,sg,ags,agg,bgs,bgg,num,num2,js=1,C,D,t,min=0;
- int sec=12;
- void delayms(uint xms) //定義延時(shí)函數(shù)
- uint i,j;
- for(i=xms;i>0;i--)
- for(j=110;j>0;j--);
- void write_data(uchar date) //定義為數(shù)據(jù)模式
- lcdrs=1; //清屏
- P0=date;
- delayms(5);
- lcden=1;
- delayms(5);
- lcden=0;
- void write_com(uchar com) //定義為命令模式
- lcdrs=0; //RS=0 寫命令
- P0=com;
- delayms(5);
- lcden=1; //E=1
- delayms(5);
- lcden=0; //E=0 當(dāng)E由1變0時(shí)LCD執(zhí)行命令
- void lcd_init() //LCD顯示屏的初始化
- lcden=0; //E=0
- write_com(0x38); //00111000兩行顯示,5*7點(diǎn)陣,8位數(shù)據(jù)
- write_com(0x0c); //00001100開整體顯示,光標(biāo)關(guān),無閃爍
- write_com(0x06); //00000110寫入1個(gè)字符后,地址指針加一
- write_com(0x01); //00000001清屏
- void init() //LCD顯示屏的初始化2(即輸出“T-”、“Q-”、“A:”、“B:”)
- lcden=0; //E=0
- write_com(0x82); //在02位置輸出
- write_data('T');
- write_data('-');
- write_com(0x8a);
- write_data('Q');
- write_data('-');
- write_com(0x80+0x43);
- write_data('A');
- write_data(':');
- write_com(0x80+0x49);
- write_data('B');
- write_data(':');
- void init_start()
- lcden=0; //E=0
- write_com(0x80+0x10); //在第一行10位置顯示
- for(num2=0;num2<16;num2++) //寫第二行字
- write_data(table1[num2]);
- delayms(5);
- write_com(0x80+0x50); //在第一行50位置輸出
- for(num2=0;num2<17;num2++)
- write_data(table[num2]); //輸出第一行
- delayms(5);
- write_com(0x1c); //00011100移動(dòng)顯示的字符
- delayms(400);
- void display(uchar min,int sec,uchar C,uchar D,uchar js) //顯示函數(shù),顯示分,秒,節(jié)數(shù)
- ss=sec/10; //秒的十位
- sg=sec%10; //秒的各位
- ms=min/10; //分的十位
- mg=min%10; //分的各位
- ags=C/10; //A隊(duì)分?jǐn)?shù)的十位
- agg=C%10; //A隊(duì)分?jǐn)?shù)的各位
- bgs=D/10; //B對(duì)分?jǐn)?shù)的十位
- bgg=D%10; //B隊(duì)分?jǐn)?shù)的各位
- write_com(0x84); //在04位置輸出
- write_data(0x30+ms); // LCD1602只能識(shí)別ASCII碼數(shù)據(jù),所以需要把數(shù)據(jù)先轉(zhuǎn)換成其對(duì)應(yīng)的ASCII碼,才能正確顯示 ...
- //因?yàn)?X30是數(shù)字0的ASCII碼,當(dāng)要顯示顯示數(shù)字時(shí),必須要加上這個(gè)數(shù),不過還可以這樣寫:write_data(‘0’+h)
- write_data(0x30+mg);
- write_data(':');
- write_data(0x30+ss);
- write_data(0x30+sg);
- write_com(0x8c); //在0c位置輸出
- write_data(0x30+js);
- write_com(0x80+0x45);
- write_data(0x30+ags);
- write_data(0x30+agg);
- write_com(0x80+0x4b);
- write_data(0x30+bgs);
- write_data(0x30+bgg);
- void main()
- TMOD=0x01; //定義定時(shí)器0的工作方式為0001
- TH0=(65536-45872)/256; //裝初值50ms
- TL0=(65536-45872)%256;
- EA=1; //打開總中斷
- ET0=1; //打開定時(shí)器0的中斷
- TR0=0; //暫停計(jì)時(shí)
- lcd_init();
- init_start();
- while(1)
- if(key_ST==0)
- delayms(5);
- if(key_ST==0)
- if(flag==0)
- lcd_init(); //清屏設(shè)置屬性
- init(); //顯示“T-”、“Q-”、“A:”、“B:”
- flag=1;
- TR0=~TR0;
- while(!key_ST)
- display(min,sec,C,D,js);
- if(key_A1==0)
- delayms(5);
- if(key_A1==0)
- C++;
- while(!key_A1)
- if(key_A2==0)
- delayms(5);
- if(key_A2==0)
- C+=2;
- while(!key_A2)
- if(key_1A==0)
- delayms(5);
- if(key_1A==0)
- C--;
- while(!key_1A)
- if(key_B1==0)
- delayms(5);
- if(key_B1==0)
- D++;
- while(!key_B1)
- if(key_B2==0)
- delayms(5);
- if(key_B2==0)
- D+=2;
- while(!key_B2)
- if(key_1B==0)
- delayms(5);
- if(key_1B==0)
- D--;
- while(!key_1B)
- while(min==0&&sec==0)
- TR0=0; //定時(shí)器0暫停
- if(key_ST==0)
- delayms(5);
- if(key_ST==0)
- min=11;
- sec=60;
- TR0=~TR0;
- while(!key_ST) //等于0進(jìn)行
- if((key_EX==0)&&(js==2))
- delayms(10);
- if((key_EX==0)&&(js=2))
- write_data('B');
- write_data('A');
- t=C;
- C=D;
- D=t;
- while(!key_EX)
- if(key_JS==0)
- delayms(10);
- if(key_JS==0)
- js++;
- while(!key_JS)
- void T0_time()interrupt 1 //定時(shí)器0控制晶碼管顯示時(shí)間
- TH0=(65536-45872)/256; // 重裝初值
- num++;
- if(num==20)
- num=0;
- sec--;
- if(sec<0)
- sec=59;
- min--;
終結(jié).rar
(76.7 KB, 下載次數(shù): 230)
2017-7-5 10:53 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
