脈搏測(cè)試儀(電子設(shè)計(jì)競(jìng)賽試題)
2017-7-18 00:37 上傳
- #include <MSP430x14x.h> //F149的頭文件
- #include "LCD12864.h"
- #include "key.h"
- #define uchar unsigned char
- #define uint unsigned int
- void put(char x,char y,int c); //電壓顯示
- void put_time(char x,char y,char z);//時(shí)間顯示
- void put_HZ(char A,char B,char shu);
- void put_one(char A,char B,char shu);
- void draw(double a);
- void pict(uint n);
- void count();
- void clear();
- void huaxian();
- void key_action();
- uint minute=0,second=0,second_1=0;
- uint n=0,number=0,temp0=0,temp2=0;//定義周期個(gè)數(shù),邊沿
- double u,fanhui=0;
- uint data[128],save[128],z[128];
- uint y,start=0,time_flag=0;
- uint basic_flag=0; //基本模式標(biāo)志
- uchar key_val,jilu=0;
- uint cont_flag=0;
- uint comp_max,comp_min;//最大值和最小值上限下限
- uint key1_val=0,key2_val=0;//按鍵鍵值 (代表按鍵按幾次)
- uint ceshi[128]={
- 23,25,18,10,5,2,8,12,23,25,18,10,5,2,8,12,
- //系統(tǒng)時(shí)鐘初始化
- void sys_Init()
- volatile unsigned int i;
- BCSCTL1&=~XT2OFF; //打開XT2振蕩器
- do
- IFG1 &= ~OFIFG; // 清除振蕩器失效標(biāo)志
- for (i = 0xFF; i > 0; i--); // 延時(shí),等待XT2起振
- } while ((IFG1 & OFIFG) != 0); // 判斷XT2是否起振
- BCSCTL2 =SELM_2+SELS; //選擇MCLK=SMCLK為XT2
- //定時(shí)器A初始化
- void timer0()
- TACTL = TASSEL_2 + MC_2; // 設(shè)置定時(shí)器A使用MCLK,不分頻,連續(xù)計(jì)數(shù)模式
- CCR0 = 40000; //CCR0初值
- CCTL0 = CCIE; // 允許CCR0 中斷
- //ADC初始化
- void ADC_Init()
- P6SEL |= 0x02; // P6.1為ADC輸入
- ADC12CTL0 = REFON+ REF2_5V; // REFON為打開內(nèi)部電壓發(fā)生器的意思,REF2_5V為設(shè)置參考電壓選擇為2.5v的意思
- ADC12CTL0 |= SHT0_2 + ADC12ON; // 設(shè)置采樣保持時(shí)間為4個(gè)ADC12CLK(SHT_2),開啟ADC12模塊(ADC12ON)
- ADC12CTL1 = SHP;
- ADC12MCTL0 = INCH_1+SREF_1; // Vr+=Vref+=2.5V
- ADC12IE = 0x01; // 設(shè)置ADC12的中斷使能,不用對(duì)應(yīng)A1通道
- ADC12CTL0 |= ENC; // // 使能AD轉(zhuǎn)換
- uchar flag=0;
- void main(void)
- WDTCTL = WDTPW + WDTHOLD; // Stop WDT,關(guān)閉看門狗定時(shí)器
- sys_Init();
- timer0();
- ADC_Init();
- P2DIR |=0XFF;
- LCD_init(); //液晶模塊的初始化
- Write_Cmd(0x01);
- GUI_Fill_GDRAM(0x00); //清屏函數(shù)
- LCD_write_string(0,0,"系統(tǒng)啟動(dòng)。。");
- LCD_write_string(0,1,"通信工程系fu!");
- LCD_write_string(0,2,"通工系fu!");
- LCD_write_string(0,3,"系統(tǒng)啟動(dòng)fu。。");
- _EINT(); //開啟總中斷(fuliang)
- //_BIS_SR(LPM0_bits + GIE); // 進(jìn)入 LPM0 低功耗模式,允許中斷,CPU停止工作,單片機(jī)等待
- while(1)
- if(start==1) //每20ms判斷成立一次,下面的句子才能運(yùn)行
- switch(key2_val) //每20ms運(yùn)行一次,switch這些句子能否運(yùn)行要取決于“shart=1”
- case 1: //本按鍵按一次的情況
- if(flag==1) //設(shè)置flag變量目的只讓這里面的程序執(zhí)行一次,
- LCD_write_string(0,0,"回放模式"); //雖然程序只執(zhí)行一次,但下面并沒有清屏,所以只要按
- //鍵不再一次按下,字符不會(huì)消失
- for(int i=0;i<128;i++)
- z[i]=save[i];
- count();//顯示次數(shù)
- for(int i=0;i<128;i+=16)
- pict(i);
- flag=0;
- break;
- case 2: //本按鍵再次按下情況
- LCD_write_string(0,0,"光電脈搏動(dòng)態(tài)顯示");
- z[i]=save[i];
- pict(i);
- break;
- case 3: //本按鍵第三次按下情況
- LCD_write_string(0,0,"監(jiān)護(hù)模式");
- time_flag=1;//倒計(jì)時(shí)標(biāo)志
- put_time(7,1,60-second_1);
- put_HZ(0,3,cont_flag);
- default: break;
- start=0; //最后要記得清零
- // Timer A0 interrupt service routine
- //CCR0比較捕捉中斷服務(wù)函數(shù)
- #pragma vector=TIMERA0_VECTOR
- __interrupt void Timer_A0 (void)
- static uchar temp;
- CCR0 += 40000; //8M/40000=200Hz==>5ms//計(jì)時(shí)
- if(++temp==200) //5ms*200=1s
- P2OUT ^=BIT0;
- temp=0;
- if(time_flag==1) //監(jiān)護(hù)模式倒計(jì)時(shí)標(biāo)志
- second_1++;
- if(second_1>59)
- time_flag=0;
- second_1=0;
- cont_flag=0;
- else second_1=0;
- second++;
- if(basic_flag==1&&second_1>58)//測(cè)試完成判斷
- Write_Cmd(0x01);
- LCD_write_string(0,0,"完成!");
- basic_flag=0;
- time_flag=0;
- if(basic_flag==1&&(second<10))
- Write_Cmd(0x01);
- LCD_write_string(0,0,"請(qǐng)重新放入!");
- if(second==1&&minute==0)
- Write_Cmd(0x01);
- LCD_write_string(0,0,"系統(tǒng)已工作ABC!");
- LCD_write_string(0,1,"光纖通信一班符亮");
- if(second>59)
- second=0;
- minute++;
- if(minute>19)
- minute=0;
- if(temp%4==0) //每5ms*4==20ms運(yùn)行一次按鍵程序,對(duì)應(yīng)下面的"start"標(biāo)志
- key_action();
- if(temp%10==0)
- cont_flag++;
- ADC12CTL0 |= ADC12SC; //啟動(dòng)ADC12轉(zhuǎn)換,讓ADC12每隔50ms轉(zhuǎn)換一次,
- //AD中斷
- #pragma vector=ADC_VECTOR
- __interrupt void ADC12_ISR (void)
- static double d=0;
- static int x=0;
- d=ADC12MEM0;//累加ad轉(zhuǎn)換的值,多次轉(zhuǎn)換可以保證轉(zhuǎn)換的精度
- u=d*25*100/4096;
- y=(int)((u/2500.0)*32);
- save[x]=31-y;
- x++;
- if(x>127)
- x=0;
- 函數(shù)名稱:display()
- 函數(shù)功能:在1602指定位置顯示兩位數(shù),被顯示的數(shù)值應(yīng)在0~99之間
- uchar ch[]=":0.000V";
- ch[1]=c/1000%10+'0';
- ch[3]= c/100%10+'0';
- ch[4]= c/10%10+'0';
- ch[5]= c%10+'0';
- LCD_write_string(x,y,ch); //顯示千位,v的單位為mV
- uchar time[]=" ";
- time[0]=z/10%10+'0';
- time[1]=z%10+'0';
- LCD_write_string(x,y,time);
- uchar hz[]="次數(shù): ";
- hz[5]=shu/100%10+'0';
- hz[6]=shu/10%10+'0';
- hz[7]=shu%10+'0';
- LCD_write_string(A,B,hz);
- uchar hz[]="個(gè)數(shù): ";
- hz[7]=shu%10+'0';
- //畫線//
- void pict(uint n)
- uint i,j;
- uint d[32],k;
- //Write_Cmd(0x34); //設(shè)置為8 位MPU 接口,擴(kuò)充指令集,繪圖模式關(guān)
- LCD_en_command(0x36);
- for(i=0;i<32;i++)
- d[i]=0;
- k=0x8000;
- for(i=n;i<n+16;i++)
- if(z[i]<=z[i+1])
- for(j=z[i];j<=z[i+1];j++)
- d[j]|=k;
- else
- for(j=z[i+1];j<=z[i];j++)
- d[j]|=k;
- k>>=1;
- for(j=0;j<32;j++)
- LCD_en_command(0x80+j); //垂直地址Y
- LCD_en_command(0x88+(n/16)); //水平地址X
- LCD_en_dat(d[j]>>8);
- LCD_en_dat(d[j]&0x00ff);
- // Write_Cmd(0x36); //打開繪圖模式
- LCD_en_command(0x30); //恢復(fù)基本指令集,關(guān)閉繪圖模式
- void key_action() //按鍵函數(shù),每20ms運(yùn)行一次這個(gè)函數(shù)
- start=1; //按鍵按下的情況為“1”,每20ms運(yùn)行一次(定時(shí)器里面是這么設(shè)置的)
- key_val=inkey();
- if(key_val!=0xff) //如果按鍵按下的情況,0xff表沒有按鍵按下
- Write_Cmd(0x01); //清除顯示
- if(key_val==1) //第一個(gè)按鍵按下
- key2_val++;
- if(key2_val==1)
- flag=1;
- if(key2_val==4)
- key2_val=0;
- if(key_val==2) //當(dāng)?shù)诙䝼(gè)按鍵按下情況
- // exit_flag++;
- key2_val=0;
- Write_Cmd(0x01);
- LCD_write_string(0,1,"基本模式");
- LCD_write_string(0,2,"請(qǐng)等待!");
- basic_flag=1; //基本模式標(biāo)志
- time_flag=1;
脈搏.zip
(492.68 KB, 下載次數(shù): 17)
2017-7-17 12:13 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
