查看: 1604|回復(fù): 0
超聲波測距
ID:192612 發(fā)表于 2017-7-20 11:02 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
sbit trig=P2^0;           //
sbit echo=P3^2;
sbit dula=P2^6;
sbit wela=P2^7;
uint time;
uchar s,bai,shi,ge;
uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
void delay(uint z)
    uint i,j;
    for(i=z;i>0;i--)
        for(j=110;j>0;j--);
void delay20us(void)   //誤差 -0.46875us
    unsigned char a,b;
    for(b=3;b>0;b--)
        for(a=1;a>0;a--);
void display(uint temp)
    bai=temp%1000/100;
    shi=temp%100/10;
    ge=temp%10;
    dula=1;
    P0=table[bai];
    dula=0;
    P0=0xff;
    wela=1;
    P0=0xfe;
    wela=0;
    delay(5);
    dula=1;
    P0=table[shi];
    dula=0;
    P0=0xff;
    wela=1;
    P0=0xfd;
    wela=0;
    delay(5);
    dula=1;
    P0=table[ge];
    dula=0;
    P0=0xff;
    wela=1;
    P0=0xfb;
    wela=0;
    delay(5);
    trig=0;
    EA=1;
    ET0=1;
    TH0=0;
    TL0=0;
    TMOD=0X01;
    trig=1;
    delay20us();
    trig=0;
    while(!echo);
    TR0=1;
    while(echo);
    TR0=0;
    time=TH0*256+TL0;
    TH0=0;
    TL0=0;
    s=time/58;
    display(s);
void TO()  interrupt 1
    TH0=0;
    TL0=0;
