查看: 4110|回復(fù): 1
程序問題 求大神解答 紅字部分 有點問題
ID:129825 發(fā)表于 2017-7-20 20:04 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>                 //調(diào)用單片機(jī)頭文件
#define uchar unsigned char  //無符號字符型 宏定義        變量范圍0~255
#define uint  unsigned int         //無符號整型 宏定義        變量范圍0~65535
//數(shù)碼管段選定義      0     1    2    3    4    5        6         7          8           9
uchar code smg_du[]={0x28,0xee,0x32,0xa7,0xe4,0xa1,0x51,0xea,0x80,0xa0,
                                           0x60,0x25,0x39,0x26,0x31,0x71,0xff};         //斷碼
//數(shù)碼管位選定義
uchar code smg_we[]={0xef,0xdf,0xbf,0x7f};
uchar dis_smg[8] = {0x28,0xee,0x32,0xa2,0xe4,0x92,0x82,0xf8};
uchar smg_i = 3;    //顯示數(shù)碼管的個位數(shù)
sbit dq   = P2^4;        //18b20 IO口的定義
sbit beep = P3^3;
bit flag_lj_en;                 //按鍵連加使能
bit flag_lj_3_en;         //按鍵連3次連加后使能  加的數(shù)就越大了
uchar key_time,key_value;      //用做連加的中間變量
bit key_500ms  ;
sbit pwm = P2^3;
uchar f_pwm_l ;          //越小越暗
uint temperature ;  //
bit flag_300ms ;
uchar menu_1;       //菜單設(shè)計的變量
uint t_high = 300,t_low = 100;           //溫度上下限報警值
//數(shù)碼管位選定義
sbit smg_we1 = P3^7;            //數(shù)碼管位選定義
sbit smg_we2 = P3^6;
sbit smg_we3 = P3^5;
sbit smg_we4 = P3^4;
uchar danwei;
/***********************1ms延時函數(shù)*****************************/
void delay_1ms(uint q)
        uint i,j;
        for(i=0;i<q;i++)
                for(j=0;j<120;j++);
/***********************小延時函數(shù)*****************************/
void delay_uint(uint q)
        while(q--);
/***********************數(shù)碼位選函數(shù)*****************************/
void smg_we_switch(uchar i)
        switch(i)
                case 0: smg_we1 = 0;  smg_we2 = 1; smg_we3 = 1;  smg_we4 = 1; break;
                case 1: smg_we1 = 1;  smg_we2 = 0; smg_we3 = 1;  smg_we4 = 0; break;
                case 2: smg_we1 = 1;  smg_we2 = 1; smg_we3 = 0;  smg_we4 = 1; break;
                case 3: smg_we1 = 1;  smg_we2 = 1; smg_we3 = 1;  smg_we4 = 0; break;
/***********100us的延時函數(shù)***12M晶振**************/
void delay_100us(uchar z)
{                                //12M
   uchar x,y;
   for(x=0;x<z;x++)
     for(y=0;y<20;y++);
uchar flag_moshi;
sbit hw_P32=P3^2;           //紅外遙控IO口的定義
bit flag_jiema_en = 0; //紅外解碼成功標(biāo)志位
uchar hw_table[4];           //紅外解碼數(shù)據(jù)緩沖區(qū)
/***********************數(shù)碼顯示函數(shù)*****************************/
void display()
        static uchar i;
        i++;
        if(i >= smg_i)
                i = 0;
        P1 = 0xff;                         //消隱
        smg_we_switch(i);                 //位選
        P1 = dis_smg;                 //段選
/***********************18b20初始化函數(shù)*****************************/
void init_18b20()
        bit q;
        dq = 1;                                //把總線拿高
        delay_uint(1);            //15us
        dq = 0;                                //給復(fù)位脈沖
        delay_uint(80);                //750us
        dq = 1;                                //把總線拿高 等待
        delay_uint(10);                //110us
        q = dq;                                //讀取18b20初始化信號
        delay_uint(20);                //200us
        dq = 1;                                //把總線拿高 釋放總線
/*************寫18b20內(nèi)的數(shù)據(jù)***************/
void write_18b20(uchar dat)
        uchar i;
        for(i=0;i<8;i++)
        {                                         //寫數(shù)據(jù)是低位開始
                dq = 0;                         //把總線拿低寫時間隙開始
                dq = dat & 0x01; //向18b20總線寫數(shù)據(jù)了
                delay_uint(5);         // 60us
                dq = 1;                         //釋放總線
                dat >>= 1;
/*************讀取18b20內(nèi)的數(shù)據(jù)***************/
uchar read_18b20()
        uchar i,value;
        for(i=0;i<8;i++)
                dq = 0;                         //把總線拿低讀時間隙開始
                value >>= 1;         //讀數(shù)據(jù)是低位開始
                dq = 1;                         //釋放總線
                if(dq == 1)                 //開始讀寫數(shù)據(jù)
                        value |= 0x80;
                delay_uint(5);         //60us        讀一個時間隙最少要保持60us的時間
        return value;                 //返回數(shù)據(jù)
/*************讀取溫度的值 讀出來的是小數(shù)***************/
uint read_temp()
        uint value;
        uchar low;                           //在讀取溫度的時候如果中斷的太頻繁了,就應(yīng)該把中斷給關(guān)了,否則會影響到18b20的時序
        init_18b20();                   //初始化18b20
        write_18b20(0xcc);           //跳過64位ROM
        write_18b20(0x44);           //啟動一次溫度轉(zhuǎn)換命令
        delay_uint(50);                   //500us
        write_18b20(0xbe);           //發(fā)出讀取暫存器命令
        low = read_18b20();           //讀溫度低字節(jié)
        value = read_18b20();  //讀溫度高字節(jié)
        value <<= 8;                   //把溫度的高位左移8位
        value |= low;                   //把讀出的溫度低位放到value的低八位中
        value *= 0.625;               //轉(zhuǎn)換到溫度值 小數(shù)
        return value;                   //返回讀出的溫度 帶小數(shù)
/*************定時器0初始化程序***************/
void time_init()
        EA   = 1;                   //開總中斷
        TMOD = 0X11;          //定時器0、定時器1工作方式1
        ET0  = 1;                  //開定時器0中斷
        TR0  = 1;                  //允許定時器0定時
        ET1  = 1;                  //開定時器0中斷
/********************獨立按鍵程序*****************/
uchar key_can;         //按鍵值
void key()         //獨立按鍵程序
        static uchar key_new;
        key_can = 20;                   //按鍵值還原
        P2 |= 0x07;
        if((P2 & 0x07) != 0x07)                //按鍵按下
                if(key_500ms == 1)        //連加
                        key_500ms = 0;
                        key_new = 1;
                delay_1ms(1);                     //按鍵消抖動
                if(((P2 & 0x07) != 0x07) && (key_new == 1))
                {                                                //確認(rèn)是按鍵按下
                        key_new = 0;
                        switch(P2 & 0x07)
                                case 0x06: key_can = 1; break;           //得到k2鍵值
                                case 0x05: key_can = 2; break;           //得到k3鍵值
                                case 0x01: key_can = 3; break;           //得到k4鍵值
                        flag_lj_en = 1;         //連加使能
                if(key_new == 0)
                        key_new = 1;
                        flag_lj_en = 0;                //關(guān)閉連加使能
                        flag_lj_3_en = 0;        //關(guān)閉3秒后使能
                        key_value = 0;                //清零
                        key_500ms = 0;
/****************按鍵處理數(shù)碼管顯示函數(shù)***************/
void key_with()
        if(key_can == 1)          //設(shè)置鍵
                f_pwm_l = 30;
                menu_1 ++;
                flag_moshi = 0;   //自動模式
                if(menu_1 >= 4)
                        menu_1 = 0;
                        smg_i = 3;                  //數(shù)碼管顯示3位
        if(menu_1 == 1)                        //設(shè)置高溫報警
                smg_i = 4;                  //數(shù)碼管顯示4位
                if(key_can == 2)
                        if(flag_lj_3_en == 0)
                                t_high ++ ;                //按鍵按下未松開自動加三次
                                t_high += 10;        //按鍵按下未松開自動加三次之后每次自動加10
                        if(t_high > 990)
                                t_high = 990;
                if(key_can == 3)
                                t_high -- ;                //按鍵按下未松開自動減三次
                                t_high -= 10;        //按鍵按下未松開自動減三次之后每次自動減10
                        if(t_high <= t_low)
                                t_high = t_low + 1;
                dis_smg[0] = smg_du[t_high % 10];                   //取小數(shù)顯示
                dis_smg[1] = smg_du[t_high / 10 % 10] & 0xdf;  //取個位顯示
                dis_smg[2] = smg_du[t_high / 100 % 10] ;           //取十位顯示
                dis_smg[3] = 0x64;         //H
        if(menu_1 == 2)                        //設(shè)置低溫報警
                if(key_can == 2)
                                t_low ++ ;                        //按鍵按下未松開自動加三次
                                t_low += 10;                //按鍵按下未松開自動加三次之后每次自動加10
                        if(t_low >= t_high)
                                t_low = t_high - 1;
                if(key_can == 3)
                                t_low -- ;                        //按鍵按下未松開自動減三次
                                t_low -= 10;                //按鍵按下未松開自動加三次之后每次自動加10
                        if(t_low <= 10)
                                t_low = 10;
                dis_smg[0] = smg_du[t_low % 10];                   //取小數(shù)顯示
                dis_smg[1] = smg_du[t_low / 10 % 10] & 0xdf;   //取個位顯示
                dis_smg[2] = smg_du[t_low / 100 % 10] ;               //取十位顯示
                dis_smg[3] = 0x3D;          //L
        if(menu_1 == 3)
                flag_moshi = 1;   //手動模式
                if(key_can == 2)          //加檔
                        danwei ++;
                        if(danwei >= 4)
                                danwei = 0;
                if(key_can == 3)         //減檔
                        if(danwei == 0)
                                danwei = 4;
                        danwei --;
                if(danwei == 0)                //風(fēng)扇停止
                        TR1 = 0;
                        pwm = 1;
                if(danwei == 1)                //1檔
                        TR1 = 1;
                        f_pwm_l = 69;
                if(danwei == 2)                //2檔
                        TR1 = 1;
                        f_pwm_l = 30;
                if(danwei == 3)                //3檔
                        TR1 = 0;
                        pwm = 0;
                dis_smg[0] = smg_du[temperature / 10 % 10];                   //取小數(shù)顯示
                dis_smg[1] = smg_du[temperature / 100 % 10];   //取個位顯示
                dis_smg[2] = 0xf7;
                dis_smg[3] = smg_du[danwei];
/****************風(fēng)扇控制函數(shù)***************/
void fengshan_kz()
        if(temperature >= t_high)          //風(fēng)扇全開
                TR1 = 0;
                pwm = 0;
        else if((temperature < t_high)        && (temperature >= t_low))                   //風(fēng)扇緩慢
                f_pwm_l = 60;
                TR1 = 1;
        else if(temperature < t_low)         //關(guān)閉風(fēng)扇
                TR1 = 0;
                pwm = 1;
/***********外部中斷0初始化程序****************/
void init_int0()          //外部中斷0初始化程序
        EX0=1;                          //允許外部中斷0中斷
        EA=1;                           //開總中斷
        IT0 = 1;                   //外部中斷0負(fù)跳變中斷
/***********紅外遙控程序**************/
void hongwai_dis()
        if(flag_jiema_en == 1)
                flag_jiema_en = 0;
                beep = 0 ;
                delay_1ms(100);
                beep = 1;
                if(hw_table[2] == 0x47)         //設(shè)置鍵
                        key_can = 1;
                if(hw_table[2] == 0x40)         //加鍵
                        key_can = 2;
                if(hw_table[2] == 0x19)         //減鍵
                        key_can = 3;
                if(hw_table[2] == 0x16)                //0檔
                        TR1 = 0;
                        pwm = 1;
                        danwei = 0;
                if(hw_table[2] == 0x0c)                //1檔
                        TR1 = 1;
                        f_pwm_l = 69;
                        danwei = 1;
                if(hw_table[2] == 0x18)                //2檔
                        TR1 = 1;
                        f_pwm_l = 30;
                        danwei = 2;
                if(hw_table[2] == 0x5e)                //3檔
                        TR1 = 0;
                        pwm = 0;
                        danwei = 3;
                hw_table[2] = 0;                  //把數(shù)據(jù)清零
/****************主函數(shù)***************/
        uchar value;
        time_init();                            f_pwm_l = 50;
        init_int0();          //外部中斷0初始化程序
                key();                                        //按鍵程序
                hongwai_dis();          //紅外遙控程序
                if(key_can < 10)
                        key_with();                        //設(shè)置報警溫度
                if(flag_300ms == 1)            //300ms 處理一次溫度程序
                        flag_300ms = 0;
                        temperature = read_temp();        //先讀出溫度的值
                                value ++;
                                if(value >= 2)
                                        beep = ~beep;        //報警
                                beep = 1;
                                value = 0;
                        if(menu_1 == 0)
                                smg_i = 3;
                                dis_smg[0] = smg_du[temperature % 10];         //取溫度的小數(shù)顯示
                                dis_smg[1] = smg_du[temperature / 10 % 10] & 0xdf; //取溫度的個位顯示
                                dis_smg[2] = smg_du[temperature / 100 % 10] ;           //取溫度的十位顯示
                        if(menu_1 == 3)
                                dis_smg[2] = 0xf7;
                if(flag_moshi == 0)
                        fengshan_kz();        //風(fēng)扇控制函數(shù)
/*****************紅外解碼程序********************/
void int0() interrupt 0
        unsigned char i,j;
        delay_100us(40);     //防止干擾
        if(hw_P32 == 0)
        {                                     //引導(dǎo)碼9+4.5=13.5ms
                while(hw_P32 == 0); //等待9ms的低電平過完
                delay_100us(27);  //2.7ms
                if(hw_P32 == 1)          //引碼結(jié)束
                        delay_100us(20);  //2.7ms+2.0ms=4.7ms  說明4.5ms的高電平已經(jīng)過完 引導(dǎo)碼已經(jīng)結(jié)束
                        for(i=0;i<4;i++)
                                for(j=0;j<8;j++)
                                        while(hw_P32 == 0);   //等待過完0.56ms
                                        delay_100us(9);
                                        if(hw_P32 == 0)                //數(shù)據(jù)0的時間=0.56+0.565=1.125ms
                                        {                                        //數(shù)據(jù)1的時間=0.56+1.685=2.245ms
                                                hw_table >>= 1;    //低位在前
                                                delay_100us(10);   //0.9+1.0=1.9ms 延時讓1.685高電平的時間過完
                                                hw_table |= 0x80;  //1.9ms過完后 數(shù)據(jù)線已經(jīng)是低電平了
                                flag_jiema_en = 1;          //紅外解碼成功
/*************定時器0中斷服務(wù)程序***************/
void time0_int() interrupt 1
        static uchar value;                         //定時2ms中斷一次
        TH0 = 0xf8;
        TL0 = 0x30;     //2ms
        display();                //數(shù)碼管顯示函數(shù)
        value++;
        if(value >= 150)
                value = 0;
                flag_300ms = 1;
        if(flag_lj_en == 1)           //按下按鍵使能
                key_time ++;
                if(key_time >= 250) //500ms
                        key_time = 0;
                        key_500ms = 1; //500ms
                        key_value ++;
                        if(key_value > 3)
                                key_value = 10;
                                flag_lj_3_en = 1; //3次后1.5秒連加大些
/*******************定時器1用做單片機(jī)模擬PWM 調(diào)節(jié)***********************/
void Timer1() interrupt 3  //調(diào)用定時器1
        static uchar value_l;
        TH1=0xbe;    //    定時10ms中斷一次
        TL1=0x0c;         //500us
        if(pwm==1)
                value_l+=1;
                if(value_l > f_pwm_l)   //高電平
                        value_l=0;
                    if(f_pwm_l != 0)
                                pwm=0;
                value_l+=1;
                if(value_l  > 100 - f_pwm_l)
                        value_l=0;
                        pwm=1;
ID:123289 發(fā)表于 2017-7-20 23:37 | 只看該作者
畫出此程序的框圖,問題就解決了。
