程序如下:
#include <STC12C2052AD.H> //STC頭文件
//“程序開發(fā)調(diào)試設(shè)置項(xiàng)”
#define DY_LI 9 //設(shè)置LED顯示的亮度(值域:1~9)
#define DY_DELAY 12 //設(shè)置每一個(gè)點(diǎn)顯示的時(shí)間長(zhǎng)度(1~20)
sbit DY_KEY = P3 ^ 7; //按鍵1
sbit DY_LED1_L1 =P3 ^ 0; //設(shè)置LED點(diǎn)陣屏連接的I/O口
sbit DY_LED1_L2 =P3 ^ 1; //設(shè)置LED點(diǎn)陣屏連接的I/O口
sbit DY_LED1_L3 =P3 ^ 2; //設(shè)置LED點(diǎn)陣屏連接的I/O口
sbit DY_LED1_L4 =P3 ^ 3; //設(shè)置LED點(diǎn)陣屏連接的I/O口
sbit DY_LED1_H1 =P1 ^ 0; //設(shè)置LED點(diǎn)陣屏連接的I/O口
sbit DY_LED1_H2 =P1 ^ 1; //設(shè)置LED點(diǎn)陣屏連接的I/O口
sbit DY_LED1_H3 =P1 ^ 2; //設(shè)置LED點(diǎn)陣屏連接的I/O口
sbit DY_LED1_H4 =P1 ^ 3; //設(shè)置LED點(diǎn)陣屏連接的I/O口
sbit DY_LED1_H5 =P1 ^ 4; //設(shè)置LED點(diǎn)陣屏連接的I/O口
sbit DY_LED1_H6 =P1 ^ 5; //設(shè)置LED點(diǎn)陣屏連接的I/O口
sbit DY_LED1_H7 =P1 ^ 6; //設(shè)置LED點(diǎn)陣屏連接的I/O口
sbit DY_LED1_H8 =P1 ^ 7; //設(shè)置LED點(diǎn)陣屏連接的I/O口
#define DY_P1M0SET 0x00 //設(shè)置I/O口工作方式//00000000(左到右,高到低位)
#define DY_P1M1SET 0xff //設(shè)置I/O口工作方式//00101000
#define DY_P3M0SET 0x00 //設(shè)置I/O口工作方式//00000000
#define DY_P3M1SET 0x00 //設(shè)置I/O口工作方式//10010100
bit PD;//秒點(diǎn)顯示標(biāo)志
unsigned char MENU;//菜單切換標(biāo)志位
data unsigned char DY_PWM,bn, cou = 0, TIME_YY,TIME_MO,TIME_DD,TIME_WW,TIME_HH,TIME_MM,TIME_SS;//設(shè)置時(shí)、分、秒存放區(qū)
data bit DAY_BIT = 0;//天數(shù)增加標(biāo)志位(用于日期進(jìn)位的啟動(dòng))
unsigned int aa;
unsigned char code disdata[]={
0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x40 //無小數(shù)點(diǎn)數(shù)碼管段碼表(0~9)
void delay (unsigned int a){ // 用于點(diǎn)掃描的延時(shí)
unsigned int i;
while( a-- != 0){
for(i = 0; i < DY_DELAY; i++);
void dis_off (void){
P1 = ~DY_P1M1SET; //關(guān)所有顯示
P3 = ~DY_P3M1SET;
delay(10-DY_PWM);
void displayHH1 (unsigned char d){ //第1列橫向顯示程序
unsigned char i;
i = d & 0x01;
if(i == 0x01){
DY_LED1_L1 = 0;DY_LED1_H1 = 1;}delay(DY_PWM);dis_off();
i = d & 0x02;
if(i == 0x02){
DY_LED1_L1 = 0;DY_LED1_H2 = 1;}delay(DY_PWM);dis_off();
i = d & 0x04;
if(i == 0x04){
DY_LED1_L1 = 0;DY_LED1_H3 = 1;}delay(DY_PWM);dis_off();
i = d & 0x08;
if(i == 0x08){
DY_LED1_L1 = 0;DY_LED1_H4 = 1;}delay(DY_PWM);dis_off();
i = d & 0x10;
if(i == 0x10){
DY_LED1_L1 = 0;DY_LED1_H5 = 1;}delay(DY_PWM);dis_off();
i = d & 0x20;
if(i == 0x20){
DY_LED1_L1 = 0;DY_LED1_H6 = 1;}delay(DY_PWM);dis_off();
i = d & 0x40;
if(i == 0x40){
DY_LED1_L1 = 0;DY_LED1_H7 = 1;}delay(DY_PWM);dis_off();
i = d & 0x80;
if(i == 0x80){
DY_LED1_L1 = 0;DY_LED1_H8 = 1;}delay(DY_PWM);dis_off();
void displayHH2 (unsigned char d){ //第2列橫向顯示程序
unsigned char i;
i = d & 0x01;
if(i == 0x01){
DY_LED1_L2 = 0;DY_LED1_H1 = 1;}delay(DY_PWM);dis_off();
i = d & 0x02;
if(i == 0x02){
DY_LED1_L2 = 0;DY_LED1_H2 = 1;}delay(DY_PWM);dis_off();
i = d & 0x04;
if(i == 0x04){
DY_LED1_L2 = 0;DY_LED1_H3 = 1;}delay(DY_PWM);dis_off();
i = d & 0x08;
if(i == 0x08){
DY_LED1_L2 = 0;DY_LED1_H4 = 1;}delay(DY_PWM);dis_off();
i = d & 0x10;
if(i == 0x10){
DY_LED1_L2 = 0;DY_LED1_H5 = 1;}delay(DY_PWM);dis_off();
i = d & 0x20;
if(i == 0x20){
DY_LED1_L2 = 0;DY_LED1_H6 = 1;}delay(DY_PWM);dis_off();
i = d & 0x40;
if(i == 0x40){
DY_LED1_L2 = 0;DY_LED1_H7 = 1;}delay(DY_PWM);dis_off();
i = d & 0x80;
if(i == 0x80){
DY_LED1_L2 = 0;DY_LED1_H8 = 1;}delay(DY_PWM);dis_off();
void displayHH3 (unsigned char d){ //第3列橫向顯示程序
unsigned char i;
i = d & 0x01;
if(i == 0x01){
DY_LED1_L3 = 0;DY_LED1_H1 = 1;}delay(DY_PWM);dis_off();
i = d & 0x02;
if(i == 0x02){
DY_LED1_L3 = 0;DY_LED1_H2 = 1;}delay(DY_PWM);dis_off();
i = d & 0x04;
if(i == 0x04){
DY_LED1_L3 = 0;DY_LED1_H3 = 1;}delay(DY_PWM);dis_off();
i = d & 0x08;
if(i == 0x08){
DY_LED1_L3 = 0;DY_LED1_H4 = 1;}delay(DY_PWM);dis_off();
i = d & 0x10;
if(i == 0x10){
DY_LED1_L3 = 0;DY_LED1_H5 = 1;}delay(DY_PWM);dis_off();
i = d & 0x20;
if(i == 0x20){
DY_LED1_L3 = 0;DY_LED1_H6 = 1;}delay(DY_PWM);dis_off();
i = d & 0x40;
if(i == 0x40){
DY_LED1_L3 = 0;DY_LED1_H7 = 1;}delay(DY_PWM);dis_off();
i = d & 0x80;
if(i == 0x80){
DY_LED1_L3 = 0;DY_LED1_H8 = 1;}delay(DY_PWM);dis_off();
void displayHH4 (unsigned char d){ //第4列橫向顯示程序
unsigned char i;
i = d & 0x01;
if(i == 0x01){
DY_LED1_L4 = 0;DY_LED1_H1 = 1;}delay(DY_PWM);dis_off();
i = d & 0x02;
if(i == 0x02){
DY_LED1_L4 = 0;DY_LED1_H2 = 1;}delay(DY_PWM);dis_off();
i = d & 0x04;
if(i == 0x04){
DY_LED1_L4 = 0;DY_LED1_H3 = 1;}delay(DY_PWM);dis_off();
i = d & 0x08;
if(i == 0x08){
DY_LED1_L4 = 0;DY_LED1_H4 = 1;}delay(DY_PWM);dis_off();
i = d & 0x10;
if(i == 0x10){
DY_LED1_L4 = 0;DY_LED1_H5 = 1;}delay(DY_PWM);dis_off();
i = d & 0x20;
if(i == 0x20){
DY_LED1_L4 = 0;DY_LED1_H6 = 1;}delay(DY_PWM);dis_off();
i = d & 0x40;
if(i == 0x40){
DY_LED1_L4 = 0;DY_LED1_H7 = 1;}delay(DY_PWM);dis_off();
i = d & 0x80;
if(i == 0x80){
DY_LED1_L4 = 0;DY_LED1_H8 = 1;}delay(DY_PWM);dis_off();
void diplay_data (unsigned char l,unsigned char d){
switch (l){//顯示的列位置
case 1://
displayHH1(d); //將顯示數(shù)據(jù)送入
break;//
case 2://
displayHH2(d); //將顯示數(shù)據(jù)送入
break;//
case 3://
displayHH3(d); //將顯示數(shù)據(jù)送入
break;//
case 4://
displayHH4(d); //將顯示數(shù)據(jù)送入
break;//
bit IsLeapYear(void){ //計(jì)算本年是否是潤(rùn)年
unsigned int a;
a = 2000+TIME_YY;//加2000表示成完整的年
if((a%4==0 && a%100!=0)||(a%400==0)){ //潤(rùn)年的計(jì)算公式
return 1;//是潤(rùn)年返回1
}else{
return 0;//不是潤(rùn)年返回0
void month_day(void){
unsigned char mon_day[]={31,28,31,30,31,30,31,31,30,31,30,31};
TIME_DD++;//天加1
TIME_WW++;//星期值加1
if(TIME_WW > 7){
TIME_WW = 1;//時(shí)期值限定
if(TIME_DD > mon_day[TIME_MO-1]){//檢查天是否大于當(dāng)月的最大值
if(IsLeapYear()&&TIME_MO==2){ //計(jì)算本月是否是潤(rùn)年的2月份
TIME_DD = 29;//如果是潤(rùn)年又是2月,則天為29
}else{
TIME_DD = 1; //否則就等于1
TIME_MO++;//月加1
if(TIME_MO > 12){
TIME_MO = 1; //如果月大于12則月等于1
TIME_YY++;//年加1 (公歷年無限積加)
void xianshi() {
for(aa=0;aa<1000;aa++){
diplay_data (3,disdata[TIME_MM/10]);
diplay_data (4,disdata[TIME_MM%10]);
if(PD){
diplay_data (1,disdata[TIME_HH/10]);
diplay_data (2,disdata[TIME_HH%10]);
}else{
diplay_data (2,disdata[TIME_HH%10]+0x80);
for(aa=1000;aa<2000;aa++){
diplay_data (1,disdata[TIME_MO/10]);
diplay_data (2,disdata[TIME_MO%10]);
diplay_data (3,disdata[TIME_DD/10]);
diplay_data (4,disdata[TIME_DD%10]);
for(aa=2000;aa<3000;aa++){
diplay_data (2,disdata[10]);
diplay_data (3,disdata[TIME_WW]);
diplay_data (4,disdata[10]);
if(aa==3000)
aa=0;
void init (void){ //上電初始化
P1M0 = DY_P1M0SET;
P1M1 = DY_P1M1SET;
P3M0 = DY_P3M0SET;
P3M1 = DY_P3M1SET;
dis_off();
DY_PWM = DY_LI;
TMOD = 0x11; // 定時(shí)/計(jì)數(shù)器0,1工作于方式1
TH0 = 0x3c; // 預(yù)置產(chǎn)生50ms時(shí)基信號(hào)
TL0 = 0xb0;
TH1=0x3c;
TL1=0xb0;
EA = 1; //中斷總開關(guān)
ET0 = 1; // 定時(shí)/計(jì)數(shù)器0允許中斷
TR0 = 1; // 開閉定時(shí)/計(jì)數(shù)器0
ET1 = 1; // 定時(shí)/計(jì)數(shù)器0允許中斷
TR1 = 1; // 開閉定時(shí)/計(jì)數(shù)器0
TIME_DD = 19; //時(shí)間在首次使用的值,之后會(huì)在EEPROM自動(dòng)記錄上一天的值
TIME_MO = 7; //初始時(shí)間:2009年5月18日周一,20時(shí)13分40秒
TIME_YY = 17;
TIME_WW = 3;
TIME_HH = 22;
TIME_MM = 40;
TIME_SS = 0;
void main (void){ //主程序
unsigned char s;
init();
MENU=0;
s=0;
aa=0;
while (1){
if(DAY_BIT == 1){ //檢查天數(shù)是否更新,是則計(jì)算公歷
month_day();//計(jì)算公歷日期
DAY_BIT = 0;//計(jì)算完成后將日期變更標(biāo)志位置0
if(MENU==0) //顯示正常走時(shí)主界面
xianshi();
if(DY_KEY==0){
EA = 0; //中斷總開關(guān)
TR1 = 0; // 關(guān)閉定時(shí)/計(jì)數(shù)器
s++;
if(s>200){
s=0;MENU++;
while(DY_KEY==0){
}//長(zhǎng)短按鍵處理//長(zhǎng)按轉(zhuǎn)到MENU1
if(DY_KEY==1 && s>10 && s<200){s=0;DY_PWM++;if(DY_PWM>4)DY_PWM=1;}//短按設(shè)置亮度
if(MENU==1){//設(shè)置時(shí)間:小時(shí)
diplay_data (3,0x80);
diplay_data (4,0x80);
if(DY_KEY==0){
s++;
if(s>200){
s=0;MENU++;
while(DY_KEY==0){
if(DY_KEY==1 && s>10 && s<200){s=0;TIME_HH++;if(TIME_HH>23)TIME_HH=0;}//短按設(shè)置亮度
if(MENU==2){//設(shè)置時(shí)間:分鐘
diplay_data (3,disdata[TIME_MM/10]+0x80);
diplay_data (4,disdata[TIME_MM%10]+0x80);
if(DY_KEY==0){
s++;
if(s>200){
s=0;MENU=0;
while(DY_KEY==0){
if(DY_KEY==1 && s>10 && s<200){s=0;TIME_MM++;TIME_SS=0;if(TIME_MM>59)TIME_MM=0;}//短按設(shè)置亮度
void tiem0(void) interrupt 1{ // T/C0中斷服務(wù)程序(產(chǎn)生50ms時(shí)基信號(hào))
cou++; // 軟計(jì)數(shù)器加1
if(cou > 19){ // 計(jì)數(shù)值到100(1s)
cou = 0; // 軟計(jì)數(shù)器清零
TIME_SS++; // 秒計(jì)數(shù)器加1(進(jìn)位10ms*100=1s)
PD =~ PD; //秒點(diǎn)閃爍
if(TIME_SS > 59){ // 秒計(jì)數(shù)值到60
TIME_SS = 0; // 秒計(jì)數(shù)器清零
TIME_MM++; // 分計(jì)數(shù)器加1(進(jìn)位60s=1m)
if(TIME_MM > 59){ // 分計(jì)數(shù)到60
TIME_MM = 0; // 分計(jì)數(shù)器清零
TIME_HH++; // 時(shí)計(jì)數(shù)器加1(進(jìn)位60m=1h)
if(TIME_HH > 23){ // 時(shí)計(jì)數(shù)到23
TIME_HH = 0; // 時(shí)計(jì)數(shù)器清零
DAY_BIT = 1; //天增加標(biāo)志位
TH0 = 0x3c; // 重置定時(shí)常數(shù)
TL0 = 0xb0;
void tiem1(void) interrupt 3{ // T/C0中斷服務(wù)程序(產(chǎn)生50ms時(shí)基信號(hào))
TH1=0x3c;
TL1=0xb0;
aa++ ;
