查看: 13725|回復(fù): 25
基于DAC0832的函數(shù)信號(hào)發(fā)生器仿真 程序及pcb與原理圖
采用STC89C52單片機(jī)設(shè)計(jì)的基于DAC0832的函數(shù)信號(hào)發(fā)生器,可輸出5種波形,三角函數(shù),方波,鋸齒波,三角波,梯形波。用4個(gè)按鍵分別實(shí)現(xiàn)頻率加、頻率減、波形切換和清屏功能。
附程序,仿真和AD原理圖
仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載):
  1. #include<reg52.h>                                           //包含頭文件
  2. #include<intrins.h>
  3. #include<absacc.h>
  4. #define uchar unsigned char                           //宏定義
  5. #define uint unsigned int
  6.
  7. sbit lcdrs=P3^0;                                           //液晶控制位
  8. sbit lcden=P3^1;
  9. sbit csda=P3^3;                                                   //DA控制位
  10. sbit wr=P3^4;
  11. char num,boxing,u;                                           //定義全局變量
  12. uint pinlv;
  13. uchar code table[]="0123456789";                //定義顯示的數(shù)組
  14. uchar code table1[]="frequence:boxing:";
  15. uchar code sin[64]={
  16. 135,145,158,167,176,188,199,209,218,226,234,240,245,249,252,254,254,253,251,247,243,237,230,222,213,204,193,182,170,158,
  17. 146,133,121,108,96,84,72,61,50,41,32,24,17,11,7,3,1,0,0,2,5,9,14,20,28,36,45,55,66,78,90,102,114,128
  18. };                                          //正弦波取碼
  19. uchar code juxing[64]={
  20. 255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,
  21. 255,255,255,255,255,255,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
  22. };                                          //矩形波取碼
  23. uchar code juchi[64]={
  24. 0,4,8,12,16,20,24,28,32,36,40,45,49,53,57,61,65,69,73,77,81,85,89,93,97,101,105,109,113,117,121,125,130,134,138,142,
  25. 146,150,154,158,162,166,170,174,178,182,186,190,194,198,202,206,210,215,219,223,227,231,235,239,243,247,251,255
  26. };                                          //鋸齒波取碼
  27. uchar code tixing[64]={
  28. 0,13,26,39,52,65,78,91,104,117,130,143,156,169,182,195,208,221,234,247,247,247,247,247,247,247,247,247,247,247,247,247,247,247,247,247,247,247,
  29. 247,247,247,247,247,247,247,242,229,216,203,190,177,164,151,138,125,112,99,86,73,60,47,34,21,8
  30. };                                           //梯形波取碼
  31. uchar code sanjiao[64]={
  32. 0,8,16,24,32,40,48,56,64,72,80,88,96,104,112,120,128,136,144,152,160,168,176,184,192,200,208,216,224,232,240,248,
  33. 248,240,232,224,216,208,200,192,184,176,168,160,152,144,136,128,120,112,104,96,88,80,72,64,56,48,40,32,24,16,8,0
  34. };                                                //三角波取碼
  35. void delay(uint xms)         //延時(shí)函數(shù)
  36. {
  37.         int a,b;
  38.         for(a=xms;a>0;a--)
  39.                 for(b=110;b>0;b--);
  40. }
  41. void write_com(uchar com)                //寫命令函數(shù)
  42. {
  43.         lcdrs=0;
  44.         P0=com;
  45.         delay(1);
  46.         lcden=1;
  47.         delay(1);
  48.         lcden=0;
  49. }
  50. void write_date(uchar date)                //寫數(shù)據(jù)函數(shù)
  51. {
  52.         lcdrs=1;
  53.         P0=date;
  54.         delay(1);
  55.         lcden=1;
  56.         delay(1);
  57.         lcden=0;
  58. }
  59. void init_lcd()                                        //初始化函數(shù)
  60. {
  61.         lcden=0;                                        //默認(rèn)開始狀態(tài)為關(guān)使能端,見時(shí)序圖
  62.         write_com(0x0f);
  63.         write_com(0x38);                        //顯示模式設(shè)置,默認(rèn)為0x38,不用變。
  64.         write_com(0x01);                        //顯示清屏,將上次的內(nèi)容清除,默認(rèn)為0x01.
  65.         write_com(0x0c);                        //顯示功能設(shè)置0x0f為開顯示,顯示光標(biāo),光標(biāo)閃爍;0x0c為開顯示,不顯光標(biāo),光標(biāo)不閃
  66.         write_com(0x06);                        //設(shè)置光標(biāo)狀態(tài)默認(rèn)0x06,為讀一個(gè)字符光標(biāo)加1.
  67.         write_com(0x80);                        //設(shè)置初始化數(shù)據(jù)指針,是在讀指令的操作里進(jìn)行的
  68. }
  69. void initclock()                           //時(shí)鐘初始化
  70. {
  71.         uint i;
  72.         TMOD=0x01;
  73.         TH0=(65536-1563)/256;
  74.         TL0=(65536-1563)%256;
  75.         EA=1;
  76.         ET0=1;
  77.         TR0=1;
  78.         for(i=10;i<17;i++)                           //顯示初始化
  79.         {
  80.                 write_date(table1[i]);
  81.                 delay(5);
  82.         }
  83.         write_com(0x80+0x40);
  84.         for(i=0;i<10;i++)
  85.         {
  86.                 write_date(table1[i]);
  87.                 delay(5);
  88.         }
  89.         write_com(0x80+7);
  90.                 write_date('s');
  91.                 write_date('i');
  92.                 write_date('n');
  93.                 write_date(' ');
  94.                 write_date(' ');
  95.                 write_date(' ');
  96.                 write_date(' ');
  97.                 write_com(0x80+0x40+0xa);
  98.                 write_date(' ');
  99.                 write_date('1');
  100.                 write_date('0');
  101.                 write_date('H');
  102.                 delay(5);
  103.                 write_date('Z');
  104.                 delay(5);
  105. }
  106. void display()                                   //顯示函數(shù)
  107. {
  108.         uchar bai,shi,ge;
  109.         if(num<10)
  110.         {
  111.                 pinlv=num*10+10;
  112.         }
  113.         if(num>9)
  114.         {
  115.                 pinlv=(num-9)*50+100;
  116.         }
  117.         bai=pinlv/100;
  118.         shi=pinlv%100/10;
  119.         ge=pinlv%100%10;
  120.         write_com(0x80+0x40+0xa);
  121.         if(bai<1)
  122.         {
  123.                   write_date(' ');
  124.                 delay(5);
  125.         }
  126.         if(bai!=0)
  127.         {
  128.                  write_date(table[bai]);
  129.                 delay(5);
  130.         }
  131.
  132.         write_date(table[shi]);
  133.         delay(5);
  134.         write_date(table[ge]);
  135.         delay(5);
  136.         write_date('H');
  137.         delay(5);
  138.         write_date('Z');
  139.         delay(5);
  140.         if(boxing==0)
  141.         {
  142.                 write_com(0x80+7);
  143.                 write_date('s');
  144.                 write_date('i');
  145.                 write_date('n');
  146.                 write_date(' ');
  147.                 write_date(' ');
  148.                 write_date(' ');
  149.                 write_date(' ');
  150.         }
  151.         if(boxing==1)
  152.         {
  153.                 write_com(0x80+7);
  154.                 write_date('j');
  155.                 write_date('u');
  156.                 write_date('x');
  157.                 write_date('i');
  158.                 write_date('n');
  159.                 write_date('g');
  160.         }
  161.         if(boxing==2)
  162.         {
  163.                 write_com(0x80+7);
  164.                 write_date('j');
  165.                 write_date('u');
  166.                 write_date('c');
  167.                 write_date('h');
  168.                 write_date('i');
  169.                 write_date(' ');
  170.
  171.         }
  172.         if(boxing==3)
  173.         {
  174.                 write_com(0x80+7);
  175.                 write_date('t');
  176.                 write_date('i');
  177.                 write_date('x');
  178.                 write_date('i');
  179.                 write_date('n');
  180.                 write_date('g');
  181.         }
  182.         if(boxing==4)
  183.         {
  184.                 write_com(0x80+7);
  185.                 write_date('s');
  186.                 write_date('a');
  187.                 write_date('n');
  188.                 write_date('j');
  189.                 write_date('i');
  190.                 write_date('a');
  191.                 write_date('o');
  192.         }
  193. }
  194. //kbscan(void)按鍵掃描程序
  195. uchar keyscan()                //鍵盤掃描
  196. {
  197.         uchar h,l,value;
  198.         P1=0xf0;                  //列置0
  199.         h=P1&0Xf0;                 //判斷哪一行按下
  200.         if(h!=0xf0)                  //判斷是否按下
  201.         {
  202.                 delay(10);   //消抖
  203.                 if(h!=0xf0)
  204.                 {
  205.
  206.                         l=P1|0x0f;         //把列置1
  207.                         P1=l;                 //把列狀態(tài)給P1口
  208.                         l=P1&0x0f;         //判斷那一列按下
  209.                         h=P1&0Xf0;         //判斷哪一行按下
  210.                         value=h+l;         //組合起來到底是那個(gè)按鍵按下
  211.                 }
  212.                 return value;
  213.         }
  214. }
  215. void keypros()                //按鍵處理
  216. {
  217.         uchar key=0;
  218.         key=keyscan();
  219.         if(key==0xee)
  220.         {
  221.             EA=0;
  222.                 delay(200);
  223.               num++;
  224.                 if(num==12)
  225.                 {
  226.                     num=0;
  227.             }
  228.                         display();
  229.                         EA=1;
  230.                 if(num>9)
  231.                 {
  232.                     EA=0;
  233.                 }
  234.          }
  235.         else if(key==0xde)
  236.     {
  237.             EA=0;
  238.                 delay(200);
  239.                 num--;
  240.                 if(num<0)
  241.                 {
  242.                     num=0;
  243.                 }
  244.                 display();
  245.                 EA=1;
  246.                 if(num>9)
  247.                 {
  248.                 EA=0;
  249.                 }
  250.         }
  251.     else if(key==0xbe)
  252.   {
  253.                 EA=0;
  254.                 delay(200);
  255.             boxing++;
  256.                 if(boxing==5)
  257.                 {
  258.                     boxing=0;
  259.                 }
  260.                     display();
  261.                         EA=1;
  262.    }
  263.    else if(key==0x7e)
  264.    {
  265.    EA=0;
  266.    write_com(0x01);
  267.
  268.    }
  269. }
  270. void delaym()                                //短暫延時(shí)
  271. {
  272.         _nop_();_nop_(); _nop_(); _nop_();_nop_();_nop_();
  273. }
  274. void main()                                         //主函數(shù)
  275. {
  276.         init_lcd();
  277.
  278. ……………………
  279. …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
函數(shù)信號(hào)發(fā)生器.zip (1.41 MB, 下載次數(shù): 534)
參與人數(shù) 3黑幣 +60 收起 理由
diudiubiu + 5 真的很需要了!
yuyu628 + 5 回帖助人的獎(jiǎng)勵(lì)!
收藏收藏14 分享淘帖 頂2 踩
ID:1 發(fā)表于 2017-7-22 17:50 | 只看該作者
樓主的Proteus仿真工程是Proteus8.8版本的
ID:302175 發(fā)表于 2018-4-5 10:22 | 只看該作者
非常棒,正是我需要的,可是幣不夠,無法下載。
ID:247623 發(fā)表于 2018-5-8 17:19 | 只看該作者
為什么我解壓失敗?
ID:1 發(fā)表于 2018-5-8 18:21 | 只看該作者
yilinghai 發(fā)表于 2018-5-8 17:19
為什么我解壓失�。�
我剛測(cè)試了一下 沒有問題啊 可以成功解壓
ID:247623 發(fā)表于 2018-5-15 14:17 | 只看該作者
換了個(gè)解壓軟件好了,不過仿真文件(.DSN)好像沒有,樓主可以加上去嗎
ID:335213 發(fā)表于 2018-6-4 17:04 | 只看該作者
仿真是8.8版本,你用的7.8版本 當(dāng)然不行啊 用錯(cuò)版本了
ID:358134 發(fā)表于 2018-6-25 09:17 | 只看該作者
可以,很好的東西 剛好急需
ID:277959 發(fā)表于 2018-6-25 14:07 | 只看該作者
好資料,51黑有你更精彩!!!
ID:264973 發(fā)表于 2018-6-25 20:10 | 只看該作者
好資料,51黑有你更精彩!!!
ID:266734 發(fā)表于 2018-7-4 13:22 | 只看該作者
確實(shí)沒有DSN文件
ID:364937 發(fā)表于 2018-7-4 16:19 | 只看該作者
感謝樓主分享,學(xué)習(xí)了
ID:463090 發(fā)表于 2019-1-6 16:22 | 只看該作者
好資料,51黑有你更精彩!!!
ID:452539 發(fā)表于 2019-1-9 19:49 | 只看該作者
好資料,51有你更精彩!!O(∩_∩)O謝謝
ID:537018 發(fā)表于 2019-5-13 16:00 | 只看該作者
為什么我解壓失敗?
第一,原本需要解壓的壓縮包已經(jīng)損壞,或者因?yàn)槭裁丛虮桓袷交�,所以解壓失�?br /> 第二,解壓的時(shí)候有密碼設(shè)定,密碼輸入錯(cuò)誤所以解壓失敗
第三,解壓文件的格式和解壓方式或者命令不匹配,也會(huì)造成解壓失敗
可以先直接雙擊源文件,進(jìn)去后直接解壓相關(guān)的文件夾,看看文件是否都被損壞;如果是第二種情況,那需要得到密碼;第三種情況一般出現(xiàn)在終端,每種格式的命令可以參考解壓命令大全
ID:537018 發(fā)表于 2019-5-15 17:12 | 只看該作者
剛好需要
ID:607321 發(fā)表于 2019-9-7 12:53 | 只看該作者
厲害了樓主
ID:79874 發(fā)表于 2019-9-26 15:41 | 只看該作者
樓主波型是怎樣取的碼
ID:79874 發(fā)表于 2019-9-26 15:42 | 只看該作者
波形是怎樣取的碼
ID:134271 發(fā)表于 2019-11-3 17:55 | 只看該作者
沒看到有DAC0832的操作函數(shù)呢。
ID:357402 發(fā)表于 2019-11-29 08:19 | 只看該作者
好資料,51黑有你更精彩!!!
ID:670766 發(fā)表于 2020-1-12 10:49 | 只看該作者
文件很好,只是仿真文件看不了,少了DSN文件,樓主能否補(bǔ)下?
ID:499661 發(fā)表于 2020-4-25 17:18 | 只看該作者
資料不錯(cuò),學(xué)習(xí)一下
ID:756748 發(fā)表于 2020-5-20 17:54 | 只看該作者
很強(qiáng),剛好非常需要,謝謝樓主
ID:714216 發(fā)表于 2020-6-7 18:26 | 只看該作者
ID:380985 發(fā)表于 2021-5-13 01:44 | 只看該作者
工程文件好評(píng)
