#include <reg51.h>
#include <intrins.h>
#define uchar unsigned char //宏定義
/*-----------------------端口命名------------------------*/
sbit rs=P2^6; //LCD的數(shù)據(jù)/命令選擇端
sbit rw=P2^5; //LCD的讀寫選擇端
sbit e=P2^7; //LCD的使能信號(hào)端
sbit s=P3^4; //水流量信號(hào)端
unsigned char count;
/*-----------------------定義參數(shù)------------------------*/
uint i,sll,msec; //定義參數(shù)
long num;
uchar display[]={"s_liu= L/min"}; //定義顯示參數(shù)
/*-----------------------毫秒延時(shí)------------------------*/
void delay(uint ms)
uint i,j; //為延時(shí)引入i,j兩參數(shù)
for (j=0;j<ms;j++) //延時(shí)第一循環(huán)
for (i=0;i<120;i++); //延時(shí)第二循環(huán)
/*--------------------向LCD1602寫命令--------------------*/
void write_command(uchar command)
rs=0; //數(shù)據(jù)、命令選擇端0為命令
rw=0; //讀、寫選擇端0為寫
P0=command; //向LCD寫命令
delay(5); //稍做延遲,代替檢測(cè)忙狀態(tài)
e=1; //信號(hào)使能端高電平
e=0; //信號(hào)使能端低電平
/*--------------------向LCD1602寫數(shù)據(jù)--------------------*/
void write_data(uchar data0)
rs=1; //數(shù)據(jù)、命令選擇端 1為數(shù)據(jù)
rw=0; //讀、寫選擇端0為寫
P0=data0; //向LCD寫數(shù)據(jù)
/*-------------------外部中斷0計(jì)數(shù)程序-------------------*/
void counter(void) interrupt 0
num++; //脈沖計(jì)數(shù)加1
/*------------------------LCD顯示------------------------*/
void displaytolcd()
write_command(0x80); //向LCD1602寫命令80H
for (i=0;i<sizeof(display)-1;i++) //循環(huán)要傳輸?shù)淖址麄€(gè)數(shù)次,每一次傳一個(gè)字符
write_data(display);
delay(5);
/*-----------------內(nèi)部中斷0計(jì)時(shí)計(jì)數(shù)程序-----------------*/
void Timer_0(void) interrupt 1
TH0=0x65; //50ms定時(shí)
TL0=0xF3;
msec++;
if(msec==20) //50*20=1S
displaytolcd();
msec=0;
sll=num/450;
num=0;
/*----------------------端口初始化-----------------------*/
void int_all()
num=0; //初始化z的值
sll=0; //初始化轉(zhuǎn)的值
rw=0; //選擇LCD寫數(shù)據(jù)指令
delay(15); //延時(shí)15ms
write_command(0x38); //向LCD1602寫命令38H
delay(5); //延時(shí)5ms
write_command(0x0e); //向LCD1602寫命令0EH
write_command(0x06); //向LCD1602寫命令06H
TMOD=0x01; //內(nèi)部中斷定時(shí)器選擇
TH0=0x66; //50ms定時(shí)
TL0=0x50;
EA=1; //開(kāi)中斷總開(kāi)關(guān)
ET0=1; //開(kāi)內(nèi)部中斷0
TR0=1; //計(jì)時(shí)器開(kāi)始工作
IT0=1; //外部中斷0為下降沿觸發(fā)
EX0=1; //開(kāi)外部中斷0
/*-----------------------數(shù)據(jù)處理------------------------*/
void disp_count()
display[7]=(sll*100/1000+'0'); //轉(zhuǎn)換轉(zhuǎn)速的十位
display[8]=(sll*100/100%10+'0'); //轉(zhuǎn)換轉(zhuǎn)速的個(gè)位
display[9]=('.');
display[10]=(sll*100/10%10+'0'); //轉(zhuǎn)換轉(zhuǎn)速的十分位
display[11]=(sll*100%10+'0'); //轉(zhuǎn)換轉(zhuǎn)速的百分位
/*------------------------主函數(shù)-------------------------*/
int_all(); //全局初始化
disp_count(); //數(shù)據(jù)處理
displaytolcd(); //LCD顯示
水流量傳感器是產(chǎn)生方波,占空比40%-60%
file:///D:\467357729\Image\C2C\070CD36BECCFFE2C16B3C1A0D43D6DB7file:///D:\467357729\Image\C2C\D0D0468AD83DEAB7952BB6ABCBDC297D
