查看: 3675|回復(fù): 1
關(guān)于C語言定時器重載值修正的問題
ID:204609 發(fā)表于 2017-7-24 10:28 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
只是一個PWM控制LED燈的小程序。我對于C語言的定時器修正值判斷不清楚,這里的修正值13,
不知道從哪里開始數(shù)機械周期的
#include <reg52.h>
sbit  PWMOUT = P0^0;
sbit  ADDR0 = P1^0;
sbit  ADDR1 = P1^1;
sbit  ADDR2 = P1^2;
sbit  ADDR3 = P1^3;
sbit  ENLED = P1^4;
unsigned char HReloadH = 0;  //高電平重載值的高字節(jié)
unsigned char HReloadL = 0;  //高電平重載值的低字節(jié)
unsigned char LReloadH = 0;  //低電平重載值的高字節(jié)
unsigned char LReloadL = 0;  //低電平重載值的低字節(jié)
void ConfigPWM(unsigned int fr, unsigned char dc);
void ClosePWM();
void main ()
    unsigned int i;
    P0 = 0xFF;  //P0口初始化
    ADDR0 = 0;  //選擇獨立LED
    ADDR1 = 1;
    ADDR2 = 1;
    ADDR3 = 1;
    ENLED = 0;  //LED總使能
    EA = 1;     //開總中斷
        ConfigPWM(100, 10);  //頻率100Hz,占空比10%
        for (i=0; i<40000; i++);
        ClosePWM();
        ConfigPWM(100, 40);  //頻率100Hz,占空比40%
        ClosePWM();
        ConfigPWM(100, 90);  //頻率100Hz,占空比90%
        ClosePWM();
void ConfigPWM(unsigned int fr, unsigned char dc)  //PWM配置函數(shù),fr-頻率,dc-占空比
    unsigned int  high, low;
    unsigned long tmp;
    tmp  = (11059200 / 12) / fr;  //計算一個周期所需的計數(shù)值
    high = (tmp * dc) / 100;      //計算高電平所需的計數(shù)值
    low  = tmp - high;            //計算低電平所需的計數(shù)值
    high = 65536 - high + 13;     //計算高電平的定時器重載值并修正
    low  = 65536 - low  + 13;     //計算低電平的定時器重載值并修正
    HReloadH = (unsigned char)(high >> 8);  //高電平重載值拆分為高低字節(jié)
    HReloadL = (unsigned char)high;
    LReloadH = (unsigned char)(low >> 8);   //低電平重載值拆分為高低字節(jié)
    LReloadL = (unsigned char)low;
    TMOD &= 0xF0;   //清零T0的控制位
    TMOD |= 0x01;   //配置T0為模式1
    TH0 = HReloadH; //加載T0重載值
    TL0 = HReloadL;
    ET0 = 1;        //使能T0中斷
    TR0 = 1;        //啟動T0
    PWMOUT = 1;     //輸出高電平
void ClosePWM()  //關(guān)閉PWM
    TR0 = 0;     //停止定時器
    ET0 = 0;
    PWMOUT = 1;  //輸出高電平
void InterruptTimer0() interrupt 1  //T0中斷服務(wù)函數(shù)
    if (PWMOUT == 1)  //當(dāng)前輸出為高電平時,裝載低電平值并輸出低電平
        TH0 = LReloadH;
        TL0 = LReloadL;
        PWMOUT = 0;
    else              //當(dāng)前輸出為低電平時,裝載高電平值并輸出高電平
        TH0 = HReloadH;
        TL0 = HReloadL;
        PWMOUT = 1;
ID:204609 發(fā)表于 2017-7-25 10:05 | 只看該作者
我能說我打錯字了嗎  “這是控制LED燈的程序”
