內(nèi)含圖像處理程序C++代碼:
全部資料下載地址:
圖像處理程序.rar
(1.45 MB, 下載次數(shù): 27)
2017-7-26 16:08 上傳
點擊文件名下載附件
MICROSOFT FOUNDATION CLASS LIBRARY : 002
AppWizard has created this 002 application for you. This application
not only demonstrates the basics of using the Microsoft Foundation classes
but is also a starting point for writing your application.
This file contains a summary of what you will find in each of the files that
make up your 002 application.
002.dsp
This file (the project file) contains information at the project level and
is used to build a single project or subproject. Other users can share the
project (.dsp) file, but they should export the makefiles locally.
002.h
This is the main header file for the application. It includes other
project specific headers (including Resource.h) and declares the
CMy002App application class.
002.cpp
This is the main application source file that contains the application
class CMy002App.
002.rc
This is a listing of all of the Microsoft Windows resources that the
program uses. It includes the icons, bitmaps, and cursors that are stored
in the RES subdirectory. This file can be directly edited in Microsoft
Visual C++.
002.clw
This file contains information used by ClassWizard to edit existing
classes or add new classes. ClassWizard also uses this file to store
information needed to create and edit message maps and dialog data
maps and to create prototype member functions.
res\002.ico
This is an icon file, which is used as the application's icon. This
icon is included by the main resource file 002.rc.
res\002.rc2
This file contains resources that are not edited by Microsoft
Visual C++. You should place all resources not editable by
the resource editor in this file.
For the main frame window:
MainFrm.h, MainFrm.cpp
These files contain the frame class CMainFrame, which is derived from
CMDIFrameWnd and controls all MDI frame features.
This bitmap file is used to create tiled images for the toolbar.
The initial toolbar and status bar are constructed in the CMainFrame
class. Edit this toolbar bitmap using the resource editor, and
update the IDR_MAINFRAME TOOLBAR array in 002.rc to add
toolbar buttons.
For the child frame window:
ChildFrm.h, ChildFrm.cpp
These files define and implement the CChildFrame class, which
supports the child windows in an MDI application.
AppWizard creates one document type and one view:
002Doc.h, 002Doc.cpp - the document
These files contain your CMy002Doc class. Edit these files to
add your special document data and to implement file saving and loading
(via CMy002Doc::Serialize).
002View.h, 002View.cpp - the view of the document
These files contain your CMy002View class.
CMy002View objects are used to view CMy002Doc objects.
res\002Doc.ico
This is an icon file, which is used as the icon for MDI child windows
for the CMy002Doc class. This icon is included by the main
Other standard files:
StdAfx.h, StdAfx.cpp
These files are used to build a precompiled header (PCH) file
named 002.pch and a precompiled types file named StdAfx.obj.
Resource.h
This is the standard header file, which defines new resource IDs.
Microsoft Visual C++ reads and updates this file.
Other notes:
AppWizard uses "TODO:" to indicate parts of the source code you
should add to or customize.
If your application uses MFC in a shared DLL, and your application is
in a language other than the operating system's current language, you
will need to copy the corresponding localized resources MFC42XXX.DLL
from the Microsoft Visual C++ CD-ROM onto the system or system32 directory,
and rename it to be MFCLOC.DLL. ("XXX" stands for the language abbreviation.
For example, MFC42DEU.DLL contains resources translated to German.) If you
don't do this, some of the UI elements of your application will remain in the
language of the operating system.
