查看: 3895|回復(fù): 1
通過(guò)單片機(jī)演奏音樂程序(八月桂花)
[文件名]  C51音樂程序(八月桂花)
[功能]    通過(guò)單片機(jī)演奏音樂
  1. /**********************************************************************/
  2. #include <REG52.H>
  3. #include <INTRINS.H>
  4. //本例采用89C52, 晶振為11.0592MHZ
  5. //關(guān)于如何編制音樂代碼, 其實(shí)十分簡(jiǎn)單,各位可以看以下代碼.
  6. //頻率常數(shù)即音樂術(shù)語(yǔ)中的音調(diào),而節(jié)拍常數(shù)即音樂術(shù)語(yǔ)中的多少拍;
  7. //所以拿出譜子, 試探編吧!
  8. sbit Beep =  P1^5 ;
  9. unsigned char n=0;  //n為節(jié)拍常數(shù)變量
  10. unsigned char code music_tab[] ={
  11. 0x18, 0x30, 0x1C , 0x10, //格式為: 頻率常數(shù), 節(jié)拍常數(shù), 頻率常數(shù), 節(jié)拍常數(shù),
  12. 0x20, 0x40, 0x1C , 0x10,
  13. 0x18, 0x10, 0x20 , 0x10,
  14. 0x1C, 0x10, 0x18 , 0x40,
  15. 0x1C, 0x20, 0x20 , 0x20,
  16. 0x1C, 0x20, 0x18 , 0x20,
  17. 0x20, 0x80, 0xFF , 0x20,
  18. 0x30, 0x1C, 0x10 , 0x18,
  19. 0x20, 0x15, 0x20 , 0x1C,
  20. 0x20, 0x20, 0x20 , 0x26,
  21. 0x40, 0x20, 0x20 , 0x2B,
  22. 0x20, 0x26, 0x20 , 0x20,
  23. 0x20, 0x30, 0x80 , 0xFF,
  24. 0x20, 0x20, 0x1C , 0x10,
  25. 0x18, 0x10, 0x20 , 0x20,
  26. 0x26, 0x20, 0x2B , 0x20,
  27. 0x30, 0x20, 0x2B , 0x40,
  28. 0x20, 0x20, 0x1C , 0x10,
  29. 0x18, 0x10, 0x20 , 0x20,
  30. 0x26, 0x20, 0x2B , 0x20,
  31. 0x30, 0x20, 0x2B , 0x40,
  32. 0x20, 0x30, 0x1C , 0x10,
  33. 0x18, 0x20, 0x15 , 0x20,
  34. 0x1C, 0x20, 0x20 , 0x20,
  35. 0x26, 0x40, 0x20 , 0x20,
  36. 0x2B, 0x20, 0x26 , 0x20,
  37. 0x20, 0x20, 0x30 , 0x80,
  38. 0x20, 0x30, 0x1C , 0x10,
  39. 0x20, 0x10, 0x1C , 0x10,
  40. 0x20, 0x20, 0x26 , 0x20,
  41. 0x2B, 0x20, 0x30 , 0x20,
  42. 0x2B, 0x40, 0x20 , 0x15,
  43. 0x1F, 0x05, 0x20 , 0x10,
  44. 0x1C, 0x10, 0x20 , 0x20,
  45. 0x26, 0x20, 0x2B , 0x20,
  46. 0x30, 0x20, 0x2B , 0x40,
  47. 0x20, 0x30, 0x1C , 0x10,
  48. 0x18, 0x20, 0x15 , 0x20,
  49. 0x1C, 0x20, 0x20 , 0x20,
  50. 0x26, 0x40, 0x20 , 0x20,
  51. 0x2B, 0x20, 0x26 , 0x20,
  52. 0x20, 0x20, 0x30 , 0x30,
  53. 0x20, 0x30, 0x1C , 0x10,
  54. 0x18, 0x40, 0x1C , 0x20,
  55. 0x20, 0x20, 0x26 , 0x40,
  56. 0x13, 0x60, 0x18 , 0x20,
  57. 0x15, 0x40, 0x13 , 0x40,
  58. 0x18, 0x80, 0x00
  59. };
  60. void int0()  interrupt 1   //采用中斷0 控制節(jié)拍
  61. {  TH0=0xd8;
  62.    TL0=0xef;
  63.    n--;
  64. }
  65. void delay (unsigned char m)   //控制頻率延時(shí)
  66. {
  67. unsigned i=3*m;
  68. while(--i);
  69. }
  70. void delayms(unsigned char a)  //豪秒延時(shí)子程序
  71. {
  72.   while(--a);                  //采用while(--a) 不要采用while(a--); 各位可編譯一下看看匯編結(jié)果就知道了!
  73. }
  74. void main()
  75. { unsigned char p,m;   //m為頻率常數(shù)變量
  76.   unsigned char i=0;
  77.   TMOD&=0x0f;
  78.   TMOD|=0x01;
  79.   TH0=0xd8;TL0=0xef;
  80.   IE=0x82;
  81. play:
  82.    while(1)
  83.     {
  84.     a: p=music_tab[i];
  85.        if(p==0x00)       { i=0, delayms(1000); goto play;}     //如果碰到結(jié)束符,延時(shí)1秒,回到開始再來(lái)一遍
  86.        else if(p==0xff)  { i=i+1;delayms(100),TR0=0; goto a;}  //若碰到休止符,延時(shí)100ms,繼續(xù)取下一音符
  87.             else         {m=music_tab[i++], n=music_tab[i++];}  //取頻率常數(shù) 和 節(jié)拍常數(shù)
  88.              TR0=1;                                             //開定時(shí)器1
  89.            while(n!=0) Beep=~Beep,delay(m);                         //等待節(jié)拍完成, 通過(guò)P1口輸出音頻(可多聲道哦!)
  90.        TR0=0;                                             //關(guān)定時(shí)器1
  91.     }
  92. }
ID:269533 發(fā)表于 2017-12-31 17:05 | 只看該作者
請(qǐng)問有做個(gè)程序完整的仿真圖嗎
