查看: 4296|回復(fù): 0
基于MSP430F149單片機(jī)的ADC轉(zhuǎn)換
ID:207177 發(fā)表于 2017-7-29 11:40 | 只看該作者 回帖獎(jiǎng)勵(lì) |正序?yàn)g覽 |閱讀模式
程序功能:MCU的片內(nèi)ADC對P6.0端口,P6.1端口的電壓進(jìn)行轉(zhuǎn)換
          將模擬電壓值顯示在1602液晶上。
測試說明:調(diào)節(jié)電位器R7的旋鈕觀察液晶顯示數(shù)字變化。
#include  <msp430x14x.h>
#include  "BoardConfig.h"
#include  "cry1602.h"
#define   Num_of_Results   32
#define   keyin  (P1IN&0x0f)
uchar shuzi[] = {"0123456789."};
uchar tishi[] = {"The volt is:"};
static uint results[Num_of_Results],results1[Num_of_Results];    //保存ADC轉(zhuǎn)換結(jié)果的數(shù)組                                                     // is not used for anything.
void Trans_val(uint Hex_Val);
/************************主函數(shù)****************************/
void main(void)
  WDTCTL = WDTPW+WDTHOLD;                   //關(guān)閉看門狗
  BoardConfig(0xb8);                        //關(guān)閉數(shù)碼管、流水燈、4245
  LcdReset();                               //復(fù)位1602液晶
  DispNChar(2,0,12,tishi);                  //顯示提示信息
  Disp1Char(11,1,'V');                      //顯示電壓單位
  P6DIR|=BIT3;
  P6OUT|=BIT3;//背光顯示
  P6SEL|=0X03;
  ADC12CTL0 &= ~(ENC);        //設(shè)置ENC為0,從而修改ADC12寄存器的值
  ADC12CTL0 = ADC12ON+SHT0_2+MSC;           // 打開ADC,設(shè)置采樣時(shí)間
  //ADC12MCTL0=INCH_0;
  //ADC12MCTL1=INCH_1;
   if(keyin!=0x0f)
      ADC12CTL0 = ADC12ON+SHT0_2+MSC+REFON;
      ADC12CTL1 = SHP+CONSEQ_2+CSTARTADD_1;     // 使用采樣定時(shí)器
      ADC12MCTL1=INCH_1;
      ADC12IE = 0x02;                           // 使能ADC中斷
      static uint index = 0;
      results1[index++] = ADC12MEM1;               // Move results
      if(index == Num_of_Results)
            uchar i;
            unsigned long sum = 0;
            index = 0;
            for(i = 0; i < Num_of_Results; i++)
                sum += results1[i];
            sum >>= 5;                            //除以32
            Trans_val(sum);
    else if (keyin==0x0f)
      ADC12CTL1 = SHP+CONSEQ_2+CSTARTADD_0;     // 使用采樣定時(shí)器
      ADC12MCTL0=INCH_0;
      ADC12IE = 0x01;                           // 使能ADC中斷
      results[index++] = ADC12MEM0;               // Move results
            uchar i;
            index = 0;
                sum += results[i];
            sum >>= 5;                            //除以32
            Trans_val(sum);
    ADC12CTL0 |= ENC;                         // 使能轉(zhuǎn)換
    ADC12CTL0 |= ADC12SC;                     // 開始轉(zhuǎn)換
  //  _EINT();
  //  LPM0;
